7.1
cs_parameters_check.c File Reference
#include <stdarg.h>
#include "cs_1d_wall_thermal.h"
#include "cs_ale.h"
#include "cs_domain.h"
#include "cs_field_pointer.h"
#include "cs_lagr.h"
#include "cs_les_balance.h"
#include "cs_math.h"
#include "cs_parameters.h"
#include "cs_porous_model.h"
#include "cs_rad_transfer.h"
#include "cs_restart_default.h"
#include "cs_thermal_model.h"
#include "cs_time_step.h"
#include "cs_syr_coupling.h"
#include "cs_wall_functions.h"
#include "cs_velocity_pressure.h"
#include "cs_parameters_check.h"
+ Include dependency graph for cs_parameters_check.c:
void cs_parameters_error (cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *format,...)
 Print general parameters error or warning info. More...
void cs_parameters_error_header (cs_parameter_error_behavior_t err_behavior, const char *section_desc)
 Print header for a given parameters error message type. More...
void cs_parameters_error_footer (cs_parameter_error_behavior_t err_behavior)
 Print footer for a given parameters error message type. More...
void cs_parameters_is_in_range_int (cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int range_l, int range_u)
 Check that a given integer keyword has values in a specified range. More...
void cs_parameters_is_not_in_range_int (cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int range_l, int range_u)
 Check that a given integer keyword has not values in a specified range. More...
void cs_parameters_is_in_list_int (cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int enum_size, const int *enum_values, const char *enum_names[])
 Check that a given integer keyword has values in a specified list. More...
void cs_parameters_is_not_in_list_int (cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int enum_size, const int *enum_values, const char *enum_names[])
 Check that a given integer keyword does not have values in a specified list. More...
void cs_parameters_is_equal_int (cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int std_value)
 Check that a given integer keyword is equal to a specified value. More...
void cs_parameters_is_not_equal_int (cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int fbd_value)
 Check that a given integer keyword is not equal to a specified value. More...
void cs_parameters_is_positive_int (cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value)
 Check that a given integer keyword is strictly positive. More...
void cs_parameters_is_greater_int (cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, int param_value, int ib_value)
 Check that a given int keyword is greater than a specified value. More...
void cs_parameters_is_in_range_double (cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, double param_value, double range_l, double range_u)
 Check that a given double keyword has values in a specified range. More...
void cs_parameters_is_in_list_double (cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, double param_value, int enum_size, const double *enum_values, const char *enum_names[])
 Check that a given double keyword has values in a specified list. More...
void cs_parameters_is_equal_double (cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, double param_value, double std_value)
 Check that a given double keyword is equal to a specified value. More...
void cs_parameters_is_greater_double (cs_parameter_error_behavior_t err_behavior, const char *section_desc, const char *param_name, double param_value, double ib_value)
 Check that a given double keyword is greater than a specified value. More...
void cs_parameters_error_barrier (void)
 Abort if the the parameter errors count is nonzero. More...
void cs_parameters_check (void)
 Check computation parameters after user modification. More...
Parameters and options management check.
◆ cs_parameters_check()
void cs_parameters_check ( void  )
◆ cs_parameters_error()
void cs_parameters_error ( cs_parameter_error_behavior_t  err_behavior,
const char *  section_desc,
const char *  format,
[in]err_behaviorwarn or abort ?
[in]section_descoptional description of code section containing this parameter, or NULL
[in]formatformat string, as printf() and family.
[in]...variable arguments based on format string.
◆ cs_parameters_error_barrier()
void cs_parameters_error_barrier ( void  )
◆ cs_parameters_error_footer()
void cs_parameters_error_footer ( cs_parameter_error_behavior_t  err_behavior)
◆ cs_parameters_error_header()
void cs_parameters_error_header ( cs_parameter_error_behavior_t  err_behavior,
◆ cs_parameters_is_equal_double()
void cs_parameters_is_equal_double ( cs_parameter_error_behavior_t  err_behavior,
const char *  param_name,
double  param_value,
double  std_value
[in]param_namename of parameter whose value we are checking
[in]param_valueparameter's current_value
[in]std_valuecompulsory or recommended parameter's value
◆ cs_parameters_is_equal_int()
void cs_parameters_is_equal_int ( cs_parameter_error_behavior_t  err_behavior,
int  param_value,
int  std_value
◆ cs_parameters_is_greater_double()
void cs_parameters_is_greater_double ( cs_parameter_error_behavior_t  err_behavior,
double  param_value,
double  ib_value
[in]ib_valueinferior bound value
◆ cs_parameters_is_greater_int()
void cs_parameters_is_greater_int ( cs_parameter_error_behavior_t  err_behavior,
int  param_value,
int  ib_value
◆ cs_parameters_is_in_list_double()
void cs_parameters_is_in_list_double ( cs_parameter_error_behavior_t  err_behavior,
double  param_value,
int  enum_size,
const double *  enum_values,
const char *  enum_names[]
[in]enum_sizesize of possible enumeration
[in]enum_valueslist of enumerated values
[in]enum_namesoptional list of value names, or NULL
◆ cs_parameters_is_in_list_int()
void cs_parameters_is_in_list_int ( cs_parameter_error_behavior_t  err_behavior,
int  param_value,
int  enum_size,
const int *  enum_values,
[in]enum_valuesoptional list of enumerated values, or NULL (in which case {0, ... enum_sizes-1} assumed
◆ cs_parameters_is_in_range_double()
void cs_parameters_is_in_range_double ( cs_parameter_error_behavior_t  err_behavior,
double  param_value,
double  range_l,
double  range_u
[in]range_lrange lower bound (included)
[in]range_urange upper bound (included)
◆ cs_parameters_is_in_range_int()
void cs_parameters_is_in_range_int ( cs_parameter_error_behavior_t  err_behavior,
int  param_value,
int  range_l,
int  range_u
[in]range_urange upper bound (excluded)
◆ cs_parameters_is_not_equal_int()
void cs_parameters_is_not_equal_int ( cs_parameter_error_behavior_t  err_behavior,
int  param_value,
int  fbd_value
[in]fbd_valueforbidden value
◆ cs_parameters_is_not_in_list_int()
void cs_parameters_is_not_in_list_int ( cs_parameter_error_behavior_t  err_behavior,
int  param_value,
int  enum_size,
◆ cs_parameters_is_not_in_range_int()
void cs_parameters_is_not_in_range_int ( cs_parameter_error_behavior_t  err_behavior,
int  param_value,
int  range_l,
int  range_u
◆ cs_parameters_is_positive_int()
void cs_parameters_is_positive_int ( cs_parameter_error_behavior_t  err_behavior,
int  param_value
