#include "cs_defs.h"#include <limits.h>#include <stdio.h>#include <stddef.h>#include <stdlib.h>#include <string.h>#include <math.h>#include <ctype.h>#include <float.h>#include <assert.h>#include "bft_mem.h"#include "bft_printf.h"#include "cs_base.h"#include "cs_field.h"#include "cs_field_pointer.h"#include "cs_math.h"#include "cs_mesh_location.h"#include "cs_boundary_conditions.h"#include "cs_boundary_zone.h"#include "cs_volume_zone.h"#include "cs_parameters.h"#include "cs_prototypes.h"#include "cs_time_step.h"#include "cs_physical_constants.h"#include "cs_thermal_model.h"#include "cs_turbulence_model.h"#include "cs_physical_model.h"#include "cs_parall.h"#include "cs_post.h"#include "cs_post_default.h"#include "cs_gui_particles.h"#include "cs_gui_util.h"#include "cs_lagr.h"#include "cs_lagr_lec.h"#include "cs_lagr_geom.h"#include "cs_lagr_dlvo.h"#include "cs_lagr_roughness.h"#include "cs_lagr_clogging.h"#include "cs_lagr_injection.h"#include "cs_lagr_gradients.h"#include "cs_lagr_car.h"#include "cs_lagr_coupling.h"#include "cs_lagr_new.h"#include "cs_lagr_particle.h"#include "cs_lagr_resuspension.h"#include "cs_lagr_stat.h"#include "cs_lagr_tracking.h"#include "cs_lagr_print.h"#include "cs_lagr_poisson.h"#include "cs_lagr_post.h"#include "cs_lagr_sde.h"#include "cs_lagr_sde_model.h"#include "cs_lagr_prototypes.h"#include "cs_lagr_agglo.h"#include "cs_lagr_fragmentation.h"#include "cs_random.h"
| cs_lagr_boundary_interactions_t* cs_get_lagr_boundary_interactions | ( | void | ) |
| cs_lagr_brownian_t* cs_get_lagr_brownian | ( | void | ) |
| cs_lagr_clogging_model_t* cs_get_lagr_clogging_model | ( | void | ) |
| cs_lagr_consolidation_model_t* cs_get_lagr_consolidation_model | ( | void | ) |
| cs_lagr_encrustation_t* cs_get_lagr_encrustation | ( | void | ) |
| cs_lagr_extra_module_t* cs_get_lagr_extra_module | ( | void | ) |
| cs_lagr_physico_chemical_t* cs_get_lagr_physico_chemical | ( | void | ) |
| cs_lagr_precipitation_model_t* cs_get_lagr_precipitation_model | ( | void | ) |
Provide access to cs_lagr_precipitation_model_t.
| cs_lagr_reentrained_model_t* cs_get_lagr_reentrained_model | ( | void | ) |
Provide access to cs_lagr_reentrained_model_t.
| cs_lagr_source_terms_t* cs_get_lagr_source_terms | ( | void | ) |
| cs_lagr_specific_physics_t* cs_get_lagr_specific_physics | ( | void | ) |
Provide access to cs_lagr_specific_physics_t.
| cs_lagr_time_step_t* cs_get_lagr_time_step | ( | void | ) |
| void cs_lagr_finalize | ( | void | ) |
| void cs_lagr_finalize_internal_cond | ( | void | ) |
| void cs_lagr_finalize_zone_conditions | ( | void | ) |
Return pointer to the main internal conditions structure.
Finalize the global boundary and volume condition structures.
| cs_lagr_zone_data_t* cs_lagr_get_boundary_conditions | ( | void | ) |
Return pointer to the main boundary conditions structure.
| cs_lagr_injection_set_t* cs_lagr_get_injection_set | ( | cs_lagr_zone_data_t * | zone_data, |
| int | zone_id, | ||
| int | set_id | ||
Provide access to injection set structure.
This access method ensures the strucure is initialized for the given zone and injection set.
| [in] | zone_data | pointer to boundary or volume conditions structure |
| [in] | zone_id | zone id |
| [in] | set_id | injection set id |
| cs_lagr_internal_condition_t* cs_lagr_get_internal_conditions | ( | void | ) |
| cs_lagr_particle_counter_t* cs_lagr_get_particle_counter | ( | void | ) |
Get read/write pointer to global particle counter.
| cs_lagr_zone_data_t* cs_lagr_get_volume_conditions | ( | void | ) |
Return pointer to the main volume conditions structure.
| void cs_lagr_init_c_arrays | ( | int | dim_cs_glob_lagr_source_terms[2], |
| cs_real_t ** | p_cs_glob_lagr_source_terms | ||
| void cs_lagr_injection_set_default | ( | cs_lagr_injection_set_t * | zis | ) |
Initialize injection set data structure fields to defaults.
| [in,out] | zis | pointer to structure to initialize |
| void cs_lagr_solve_initialize | ( | const cs_real_t * | dt | ) |
| void cs_lagr_solve_time_step | ( | const int | itypfb[], |
| const cs_real_t * | dt | ||
| cs_lagr_particle_counter_t* cs_lagr_update_particle_counter | ( | void | ) |
Update global particle counter.
All fields handled in the local particle set are updated relative to that data (using global sums).
