cs_field_pointer.h
1 #ifndef __CS_FIELD_POINTER_H__
2 #define __CS_FIELD_POINTER_H__
5  * Field pointers and ids for standard and model fields
31  * Local headers
34 #include "cs_defs.h"
35 #include "cs_field.h"
36
38
41 /*=============================================================================
42  * Macro definitions
45 /* Macro used for scoping of field pointer enums */
46
47 #define CS_ENUMF_(e) CS_FIELD_POINTER_ ## e
48
49 /* Macro used to return a field pointer by its enumerated value */
50
51 #define CS_F_(e) cs_glob_field_pointers[CS_FIELD_POINTER_ ## e].f
52
53 #define CS_FI_(e, i) cs_glob_field_pointers[CS_FIELD_POINTER_ ## e].a->p[i]
54
55 /*============================================================================
56  * Type definitions
58
61 typedef enum {
62
63  /* Base variables and properties */
64
119  /* Specific physics variables and properties */
120
200  /* Cooling tower fields */
210  /* NCFD fields */
242  /* Added variables (scalars) */
245  /* User-defined arrays */
247
248  /* End of attributes */
249
251
253
257  int n;
259 };
260
266 };
267
268 /*============================================================================
269  * Global variables
270  *============================================================================*/
271
272 /* Pointers */
273
275
276 /*=============================================================================
277  * Public function prototypes
278  *============================================================================*/
279
280 /*----------------------------------------------------------------------------
281  * Free all field pointer data.
282  *----------------------------------------------------------------------------*/
283
284 void
286
287 /*----------------------------------------------------------------------------
288  * Map a simple field to an enumerated pointer.
289  *
290  * The associated field pointer may then be retreived using \ref CS_F_(e).
291  *
292  * parameters:
293  * e <-- field enumerator value
294  * f <-- pointer to field structure
295  *----------------------------------------------------------------------------*/
296
297 void
299  cs_field_t *f);
300
301 /*----------------------------------------------------------------------------
302  * Map a field to an (enumerated pointer, index) couple.
303  *
304  * This sort of mapping may be used for sets of fields whose size
305  * is not known in advance.
306  *
307  * The associated field pointer may then be retreived using \ref CS_F_(e, i).
308  *
309  * parameters:
310  * e <-- field enumerator value
311  * index <-- field enumerator index
312  * f <-- pointer to field structure
313  *----------------------------------------------------------------------------*/
314
315 void
317  int index,
318  cs_field_t *f);
319
320 /*----------------------------------------------------------------------------
321  * Map base fields to enumerated pointers.
322  *----------------------------------------------------------------------------*/
323
324 void
326
327 /*----------------------------------------------------------------------------
328  * Map some boundary fields to enumerated pointers.
329  *----------------------------------------------------------------------------*/
330
331 void
333
334 /*----------------------------------------------------------------------------
335  * Map base fields to enumerated pointers for atmospheric models
336  *
337  * parameters:
338  * n_chem_species <-- number of chemical species
339  * species_f_if <-- field id for each chemical species
340  *----------------------------------------------------------------------------*/
341
342 void
343 cs_field_pointer_map_atmospheric(int n_chem_species,
344  const int species_f_id[]);
345
346 /*----------------------------------------------------------------------------
347  * Map base fields to enumerated pointers for atmospheric models
348  *
349  * parameters:
350  * n_coals <-- number of coals
351  * n_classes <-- number of coal classes
352  *----------------------------------------------------------------------------*/
353
354 void
356  int n_classes);
357
358 /*----------------------------------------------------------------------------*
359  * Map base fields to enumerated pointers for compressible model
360  *----------------------------------------------------------------------------*/
361
362 void
364
365 /*----------------------------------------------------------------------------*
366  * Map base fields to enumerated pointers for gas mix model
367  *----------------------------------------------------------------------------*/
368
369 void
371
372 /*----------------------------------------------------------------------------
373  * Map base fields to enumerated pointers for gas combustion.
374  *----------------------------------------------------------------------------*/
375
376 void
378
379 /*----------------------------------------------------------------------------*/
380 /*
381  * Map base fields to enumerated pointers for groundwater flows
382  *----------------------------------------------------------------------------*/
383
384 void
386
387 /*----------------------------------------------------------------------------*/
388
390
391 #endif /* __CS_FIELD_POINTER_H__ */
Definition: cs_field_pointer.h:170
Definition: cs_field_pointer.h:198
Definition: cs_field_pointer.h:226
Definition: cs_field_pointer.h:171
Definition: cs_field_pointer.h:166
Definition: cs_field_pointer.h:181
Definition: cs_field_pointer.h:206
Definition: cs_field_pointer.h:263
void cs_field_pointer_map_base(void)
Definition: cs_field_pointer.c:289
Definition: cs_field_pointer.h:110
Definition: cs_field_pointer.h:156
Definition: cs_field_pointer.h:175
Definition: cs_field_pointer.h:145
Definition: cs_field_pointer.h:172
Definition: cs_field.h:124
Definition: cs_field_pointer.h:178
Definition: cs_field_pointer.h:112
Definition: cs_field_pointer.h:149
Definition: cs_field_pointer.h:83
Definition: cs_field_pointer.h:231
void cs_field_pointer_destroy_all(void)
Definition: cs_field_pointer.c:172
Definition: cs_field_pointer.h:229
Definition: cs_field_pointer.h:217
Definition: cs_field_pointer.h:204
Definition: cs_field_pointer.h:157
Definition: cs_field_pointer.h:167
Definition: cs_field_pointer.h:90
Definition: cs_field_pointer.h:238
Definition: cs_defs.h:467
Definition: cs_field_pointer.h:130
Definition: cs_field_pointer.h:218
Definition: cs_field_pointer.h:230
cs_field_t * f
Definition: cs_field_pointer.h:264
Definition: cs_field_pointer.h:79
Macro used for scoping of field pointer enums.
Definition: cs_field_pointer.h:47
Definition: cs_field_pointer.h:185
Definition: cs_field_pointer.h:139
Definition: cs_field_pointer.h:168
Definition: cs_field_pointer.h:232
Definition: cs_field_pointer.h:233
void cs_field_pointer_map_boundary(void)
Definition: cs_field_pointer.c:364
Definition: cs_field_pointer.h:216
Definition: cs_field_pointer.h:132
Definition: cs_field_pointer.h:151
void cs_field_pointer_map_gas_mix(void)
Map base fields to enumerated pointers for gas mix model.
Definition: cs_field_pointer.c:514
Definition: cs_field_pointer.h:67
Definition: cs_field_pointer.h:184
Definition: cs_field_pointer.h:106
void cs_field_pointer_map_compressible(void)
Map base fields to enumerated pointers for compressible model.
Definition: cs_field_pointer.c:477
Definition: cs_field_pointer.h:142
Definition: cs_field_pointer.h:214
int n
Definition: cs_field_pointer.h:257
Definition: cs_field_pointer.h:78
Definition: cs_field_pointer.h:219
Definition: cs_field_pointer.h:202
Definition: cs_field_pointer.h:240
Definition: cs_field_pointer.h:225
Definition: cs_field_pointer.h:148
Definition: cs_field_pointer.h:160
Definition: cs_field_pointer.h:159
void cs_field_pointer_map_coal_combustion(int n_coals, int n_classes)
Map base fields to enumerated pointers for coal combustion.
Definition: cs_field_pointer.c:410
Definition: cs_field_pointer.h:115
Definition: cs_field_pointer.h:183
Definition: cs_field_pointer.h:165
Definition: cs_field_pointer.h:194
Definition: cs_field_pointer.h:113
Definition: cs_field_pointer.h:250
void cs_field_pointer_map_groundwater(void)
Map base fields to enumerated pointers for groundwater flows.
Definition: cs_field_pointer.c:561
Definition: cs_field_pointer.h:208
Definition: cs_field_pointer.h:101
Definition: cs_field_pointer.h:134
Definition: cs_field_pointer.h:121
Definition: cs_field_pointer.h:104
Definition: cs_field_pointer.h:203
Definition: cs_field_pointer.h:182
Definition: cs_field_pointer.h:220
Definition: cs_field_pointer.h:224
Definition: cs_field_pointer.h:205
Definition: cs_field_pointer.h:129
Definition: cs_field_pointer.h:212
Definition: cs_field_pointer.h:211
Definition: cs_field_pointer.h:173
void cs_field_pointer_map_indexed(cs_field_pointer_id_t e, int index, cs_field_t *f)
Definition: cs_field_pointer.c:225
Definition: cs_field_pointer.h:158
void cs_field_pointer_map(cs_field_pointer_id_t e, cs_field_t *f)
Definition: cs_field_pointer.c:196
Definition: cs_field_pointer.h:191
Definition: cs_field_pointer.h:147
Definition: cs_field_pointer.h:99
Definition: cs_field_pointer.h:228
Definition: cs_field_pointer.h:246
Definition: cs_field_pointer.h:95
Definition: cs_field_pointer.h:223
Definition: cs_field_pointer.h:239
Definition: cs_field_pointer.h:87
Definition: cs_field_pointer.h:126
Definition: cs_field_pointer.h:227
Definition: cs_field_pointer.h:196
Definition: cs_field_pointer.h:117
Definition: cs_field_pointer.h:107
Definition: cs_field_pointer.h:100
Definition: cs_field_pointer.h:188
Definition: cs_field_pointer.h:215
Definition: cs_field_pointer.h:221
Definition: cs_field_pointer.h:235
Definition: cs_field_pointer.h:187
Definition: cs_field_pointer.h:201
Definition: cs_field_pointer.h:150
Definition: cs_field_pointer.h:189
Definition: cs_field_pointer.h:75
Definition: cs_field_pointer.h:176
Definition: cs_field_pointer.h:162
struct cs_field_pointer_array_t * a
Definition: cs_field_pointer.h:265
Definition: cs_field_pointer.h:236
Definition: cs_field_pointer.h:234
Definition: cs_field_pointer.h:143
Definition: cs_field_pointer.h:86
Definition: cs_field_pointer.h:77
Definition: cs_field_pointer.h:243
Definition: cs_field_pointer.h:192
Definition: cs_field_pointer.h:256
Definition: cs_defs.h:468
Definition: cs_field_pointer.h:152
Definition: cs_field_pointer.h:73
Definition: cs_field_pointer.h:81
Definition: cs_field_pointer.h:207
Definition: cs_field_pointer.h:137
Definition: cs_field_pointer.h:169
Definition: cs_field_pointer.h:163
Definition: cs_field_pointer.h:153
Definition: cs_field_pointer.h:127
Definition: cs_field_pointer.h:154
Definition: cs_field_pointer.h:141
Definition: cs_field_pointer.h:155
Definition: cs_field_pointer.h:213
Definition: cs_field_pointer.h:103
Definition: cs_field_pointer.h:74
Definition: cs_field_pointer.h:109
Definition: cs_field_pointer.h:135
Definition: cs_field_pointer.h:61
Definition: cs_field_pointer.h:131
Definition: cs_field_pointer.h:94
Definition: cs_field_pointer.h:161
Definition: cs_field_pointer.h:193
Definition: cs_field_pointer.h:116
Definition: cs_field_pointer.h:71
Definition: cs_field_pointer.h:174
Definition: cs_field_pointer.h:222
Definition: cs_field_pointer.h:125
Definition: cs_field_pointer.h:179
void cs_field_pointer_map_atmospheric(int n_chem_species, const int species_f_id[])
Map base fields to enumerated pointers for atmospheric models.
Definition: cs_field_pointer.c:383
cs_field_t * p[]
Definition: cs_field_pointer.h:258
Definition: cs_field_pointer.h:138
Definition: cs_field_pointer.h:146
Definition: cs_field_pointer.h:82
Definition: cs_field_pointer.h:237
Definition: cs_field_pointer.h:190
Definition: cs_field_pointer.h:76
void cs_field_pointer_map_gas_combustion(void)
Definition: cs_field_pointer.c:527
union cs_field_pointer_val_t * cs_glob_field_pointers
Definition: cs_field_pointer.c:130
Definition: cs_field_pointer.h:123
