cs_lagr_particle.h
1 #ifndef __CS_LAGR_PARTICLE_H__
2 #define __CS_LAGR_PARTICLE_H__
5  * Lagrangian module particle model
30 #include "cs_defs.h"
32 #include "assert.h"
34 /*----------------------------------------------------------------------------*/
38 /*=============================================================================
39  * Macro definitions
40  *============================================================================*/
42 /*=============================================================================
43  * Macro definitions
45
51 #define CS_LAGR_PART_TO_DELETE (1 << 0)
52
54 #define CS_LAGR_PART_FIXED (1 << 1)
55
57 #define CS_LAGR_PART_DEPOSITED (1 << 2)
58
60 #define CS_LAGR_PART_ROLLING (1 << 3)
61
63 #define CS_LAGR_PART_IMPOSED_MOTION (1 << 4)
64
68 #define CS_LAGR_PART_DEPOSITION_FLAGS \
69  ( CS_LAGR_PART_TO_DELETE | CS_LAGR_PART_FIXED | CS_LAGR_PART_DEPOSITED \
70  | CS_LAGR_PART_ROLLING | CS_LAGR_PART_IMPOSED_MOTION)
71
72 /*============================================================================
73  * Type definitions
74  *============================================================================*/
75
77 /* ------------------------------- */
78
79 typedef enum {
80
98
104  /* Arrays for 2nd order scheme */
105
106  CS_LAGR_TURB_STATE_1, /* turbulence characteristics of first pass */
107  CS_LAGR_PRED_VELOCITY, /* 1st step prediction for particle velocity */
108  CS_LAGR_PRED_VELOCITY_SEEN, /* 1st step prediction for relative velocity */
109  CS_LAGR_V_GAUSS, /* 1st step Gaussian variable */
110  CS_LAGR_BR_GAUSS, /* 1st step Brownian motion Gaussian variable */
111
112  /* Deposition submodel additional parameters */
113
119
120  /* Resuspension model additional parameters */
121
127
128  /* Clogging model additional parameters */
129
134
135  /* Thermal model additional parameters */
136
140
141  /* Coal combustion additional parameters */
142
146
149
152
153  /* Radiative model additional parameters */
154
156
157  /* Statistical class */
158
160
162
163  /* User attributes */
164
166
167  /* End of attributes */
168
170
172
174 /* ------------------------------------- */
175
176 typedef struct {
177
178  size_t extents; /* size (in bytes) of particle
179  structure */
180  size_t lb; /* size (in bytes) of lower
181  bounds of particle data
182  (work area before) */
183
184  int n_time_vals; /* number of time values
185  handled */
186
187  size_t size[CS_LAGR_N_ATTRIBUTES]; /* size (in bytes) of
188  attributes in particle
189  structure for a given
190  time value */
191  cs_datatype_t datatype[CS_LAGR_N_ATTRIBUTES]; /* datatype of associated
192  attributes */
193  int (*count)[CS_LAGR_N_ATTRIBUTES]; /* number of values for each
194  attribute, per associated
195  time_id */
196  ptrdiff_t (*displ)[CS_LAGR_N_ATTRIBUTES]; /* displacement (in bytes) of
197  attributes in particle data,
198  per associated time_id*/
199
200  ptrdiff_t *source_term_displ; /* displacement (in bytes) of
201  source term values
202  for second-order scheme,
203  or NULL */
204
206
207 /* Particle set */
208 /* ------------ */
209
210 typedef struct {
211
212  cs_lnum_t n_particles; /* number of particle in domain */
215  cs_lnum_t n_part_merged; /* number of merged particles */
220
229
231
234  unsigned char *p_buffer;
237
238 /*=============================================================================
239  * Global variables
240  *============================================================================*/
241
244 extern const char *cs_lagr_attribute_name[];
245
249
250 /*============================================================================
251  * Public function prototypes for Fortran API
252  *============================================================================*/
253
254 /*============================================================================
255  * Public function prototypes
256  *============================================================================*/
257
258 /*----------------------------------------------------------------------------*/
262 /*----------------------------------------------------------------------------*/
263
264 void
266
267 /*----------------------------------------------------------------------------*/
273 /*----------------------------------------------------------------------------*/
274
277
278 /*----------------------------------------------------------------------------*/
282 /*----------------------------------------------------------------------------*/
283
284 void
286
287 /*----------------------------------------------------------------------------*/
291 /*----------------------------------------------------------------------------*/
292
293 void
295
296 /*----------------------------------------------------------------------------*/
305 /*----------------------------------------------------------------------------*/
306
307 void
309  cs_lnum_t src);
310
311 /*----------------------------------------------------------------------------*/
330 /*----------------------------------------------------------------------------*/
331
332 void
334  int time_id,
335  cs_lagr_attribute_t attr,
336  size_t *extents,
337  size_t *size,
338  ptrdiff_t *displ,
339  cs_datatype_t *datatype,
340  int *count);
341
342 /*----------------------------------------------------------------------------*/
355 /*----------------------------------------------------------------------------*/
356
357 int
359  cs_lagr_attribute_t attr,
360  cs_datatype_t datatype,
361  int stride,
362  int component_id);
363
364 /*----------------------------------------------------------------------------*/
372 /*----------------------------------------------------------------------------*/
373
374 void
376
377 /*----------------------------------------------------------------------------
378  * Return pointer to the main cs_lagr_particle_set_t structure.
379  *
380  * returns:
381  * pointer to current particle set, or NULL
382  *----------------------------------------------------------------------------*/
383
386
387 /*----------------------------------------------------------------------------*/
397 /*----------------------------------------------------------------------------*/
398
399 inline static void *
401  cs_lnum_t particle_id,
402  cs_lagr_attribute_t attr)
403 {
404  assert(particle_set->p_am->count[0][attr] > 0);
405
406  return (unsigned char *)particle_set->p_buffer
407  + particle_set->p_am->extents*particle_id
408  + particle_set->p_am->displ[0][attr];
409 }
410
411 /*----------------------------------------------------------------------------*/
422 /*----------------------------------------------------------------------------*/
423
424 inline static const void *
426  cs_lnum_t particle_id,
427  cs_lagr_attribute_t attr)
428 {
429  assert(particle_set->p_am->count[0][attr] > 0);
430
431  return particle_set->p_buffer
432  + particle_set->p_am->extents*particle_id
433  + particle_set->p_am->displ[0][attr];
434 }
435
436 /*----------------------------------------------------------------------------*/
448 /*----------------------------------------------------------------------------*/
449
450 inline static void *
452  cs_lnum_t particle_id,
453  int time_id,
454  cs_lagr_attribute_t attr)
455 {
456  assert(particle_set->p_am->count[time_id][attr] > 0);
457
458  return particle_set->p_buffer
459  + particle_set->p_am->extents*particle_id
460  + particle_set->p_am->displ[time_id][attr];
461 }
462
463 /*----------------------------------------------------------------------------*/
475 /*----------------------------------------------------------------------------*/
476
477 inline static const void *
479  cs_lnum_t particle_id,
480  int time_id,
481  cs_lagr_attribute_t attr)
482 {
483  assert(particle_set->p_am->count[time_id][attr] > 0);
484
485  return particle_set->p_buffer
486  + particle_set->p_am->extents*particle_id
487  + particle_set->p_am->displ[time_id][attr];
488 }
489
490 /*----------------------------------------------------------------------------*/
500 /*----------------------------------------------------------------------------*/
501
502 inline static int
504  cs_lnum_t particle_id,
505  int mask)
506 {
507  int flag
508  = *((const cs_lnum_t *)( particle_set->p_buffer
509  + particle_set->p_am->extents*particle_id
510  + particle_set->p_am->displ[0][CS_LAGR_P_FLAG]));
511
512  return (flag & mask);
513 }
514
515 /*----------------------------------------------------------------------------*/
523 /*----------------------------------------------------------------------------*/
524
525 inline static void
527  cs_lnum_t particle_id,
528  int mask)
529 {
530  int flag
531  = *((const cs_lnum_t *)( particle_set->p_buffer
532  + particle_set->p_am->extents*particle_id
533  + particle_set->p_am->displ[0][CS_LAGR_P_FLAG]));
534
535  flag = flag & mask;
536
537  *((cs_lnum_t *)( particle_set->p_buffer
538  + particle_set->p_am->extents*particle_id
539  + particle_set->p_am->displ[0][CS_LAGR_P_FLAG])) = flag;
540 }
541
542 /*----------------------------------------------------------------------------*/
550 /*----------------------------------------------------------------------------*/
551
552 inline static void
554  cs_lnum_t particle_id,
555  int mask)
556 {
557  int flag
558  = *((const cs_lnum_t *)( particle_set->p_buffer
559  + particle_set->p_am->extents*particle_id
560  + particle_set->p_am->displ[0][CS_LAGR_P_FLAG]));
561
562  flag = (flag | mask) - mask;
563
564  *((cs_lnum_t *)( particle_set->p_buffer
565  + particle_set->p_am->extents*particle_id
566  + particle_set->p_am->displ[0][CS_LAGR_P_FLAG])) = flag;
567 }
568
569 /*----------------------------------------------------------------------------*/
579 /*----------------------------------------------------------------------------*/
580
581 inline static cs_lnum_t
583  cs_lnum_t particle_id,
584  cs_lagr_attribute_t attr)
585 {
586  assert(particle_set->p_am->count[0][attr] > 0);
587
588  return *((const cs_lnum_t *)( particle_set->p_buffer
589  + particle_set->p_am->extents*particle_id
590  + particle_set->p_am->displ[0][attr]));
591 }
592
593 /*----------------------------------------------------------------------------*/
605 /*----------------------------------------------------------------------------*/
606
607 inline static cs_lnum_t
609  cs_lnum_t particle_id,
610  int time_id,
611  cs_lagr_attribute_t attr)
612 {
613  assert(particle_set->p_am->count[time_id][attr] > 0);
614
615  return *((const cs_lnum_t *)( particle_set->p_buffer
616  + particle_set->p_am->extents*particle_id
617  + particle_set->p_am->displ[time_id][attr]));
618 }
619
620 /*----------------------------------------------------------------------------*/
629 /*----------------------------------------------------------------------------*/
630
631 inline static void
633  cs_lnum_t particle_id,
634  cs_lagr_attribute_t attr,
635  cs_lnum_t value)
636 {
637  assert(particle_set->p_am->count[0][attr] > 0);
638
639  *((cs_lnum_t *)( particle_set->p_buffer
640  + particle_set->p_am->extents*particle_id
641  + particle_set->p_am->displ[0][attr])) = value;
642 }
643
644 /*----------------------------------------------------------------------------*/
655 /*----------------------------------------------------------------------------*/
656
657 inline static void
659  cs_lnum_t particle_id,
660  int time_id,
661  cs_lagr_attribute_t attr,
662  cs_lnum_t value)
663 {
664  assert(particle_set->p_am->count[time_id][attr] > 0);
665
666  *((cs_lnum_t *)( particle_set->p_buffer
667  + particle_set->p_am->extents*particle_id
668  + particle_set->p_am->displ[time_id][attr])) = value;
669 }
670
671 /*----------------------------------------------------------------------------*/
681 /*----------------------------------------------------------------------------*/
682
683 inline static cs_gnum_t
685  cs_lnum_t particle_id,
686  cs_lagr_attribute_t attr)
687 {
688  assert(particle_set->p_am->count[0][attr] > 0);
689
690  return *((const cs_gnum_t *)( particle_set->p_buffer
691  + particle_set->p_am->extents*particle_id
692  + particle_set->p_am->displ[0][attr]));
693 }
694
695 /*----------------------------------------------------------------------------*/
707 /*----------------------------------------------------------------------------*/
708
709 inline static cs_gnum_t
711  cs_lnum_t particle_id,
712  int time_id,
713  cs_lagr_attribute_t attr)
714 {
715  assert(particle_set->p_am->count[time_id][attr] > 0);
716
717  return *((const cs_gnum_t *)( particle_set->p_buffer
718  + particle_set->p_am->extents*particle_id
719  + particle_set->p_am->displ[time_id][attr]));
720 }
721
722 /*----------------------------------------------------------------------------*/
731 /*----------------------------------------------------------------------------*/
732
733 inline static void
735  cs_lnum_t particle_id,
736  cs_lagr_attribute_t attr,
737  cs_gnum_t value)
738 {
739  assert(particle_set->p_am->count[0][attr] > 0);
740
741  *((cs_gnum_t *)( particle_set->p_buffer
742  + particle_set->p_am->extents*particle_id
743  + particle_set->p_am->displ[0][attr])) = value;
744 }
745
746 /*----------------------------------------------------------------------------*/
757 /*----------------------------------------------------------------------------*/
758
759 inline static void
761  cs_lnum_t particle_id,
762  int time_id,
763  cs_lagr_attribute_t attr,
764  cs_gnum_t value)
765 {
766  assert(particle_set->p_am->count[time_id][attr] > 0);
767
768  *((cs_gnum_t *)( particle_set->p_buffer
769  + particle_set->p_am->extents*particle_id
770  + particle_set->p_am->displ[time_id][attr])) = value;
771 }
772
773 /*----------------------------------------------------------------------------*/
783 /*----------------------------------------------------------------------------*/
784
785 inline static cs_real_t
787  cs_lnum_t particle_id,
788  cs_lagr_attribute_t attr)
789 {
790  assert(particle_set->p_am->count[0][attr] > 0);
791
792  return *((const cs_real_t *)( particle_set->p_buffer
793  + particle_set->p_am->extents*particle_id
794  + particle_set->p_am->displ[0][attr]));
795 }
796
797 /*----------------------------------------------------------------------------*/
809 /*----------------------------------------------------------------------------*/
810
811 inline static cs_real_t
813  cs_lnum_t particle_id,
814  int time_id,
815  cs_lagr_attribute_t attr)
816 {
817  assert(particle_set->p_am->count[time_id][attr] > 0);
818
819  return *((const cs_real_t *)( particle_set->p_buffer
820  + particle_set->p_am->extents*particle_id
821  + particle_set->p_am->displ[time_id][attr]));
822 }
823
824 /*----------------------------------------------------------------------------*/
833 /*----------------------------------------------------------------------------*/
834
835 inline static void
837  cs_lnum_t particle_id,
838  cs_lagr_attribute_t attr,
839  cs_real_t value)
840 {
841  assert(particle_set->p_am->count[0][attr] > 0);
842
843  *((cs_real_t *)( particle_set->p_buffer
844  + particle_set->p_am->extents*particle_id
845  + particle_set->p_am->displ[0][attr])) = value;
846 }
847
848 /*----------------------------------------------------------------------------*/
859 /*----------------------------------------------------------------------------*/
860
861 inline static void
863  cs_lnum_t particle_id,
864  int time_id,
865  cs_lagr_attribute_t attr,
866  cs_real_t value)
867 {
868  assert(particle_set->p_am->count[time_id][attr] > 0);
869
870  *((cs_real_t *)( particle_set->p_buffer
871  + particle_set->p_am->extents*particle_id
872  + particle_set->p_am->displ[time_id][attr])) = value;
873 }
874
875 /*----------------------------------------------------------------------------*/
886 /*----------------------------------------------------------------------------*/
887
888 inline static cs_real_t *
890  cs_lnum_t particle_id,
891  cs_lagr_attribute_t attr)
892 {
893  assert(particle_set->p_am->source_term_displ != NULL);
894  assert(particle_set->p_am->source_term_displ[attr] >= 0);
895
896  return (cs_real_t *)( (unsigned char *)particle_set->p_buffer
897  + particle_set->p_am->extents*particle_id
898  + particle_set->p_am->source_term_displ[attr]);
899 }
900
901 /*----------------------------------------------------------------------------*/
912 /*----------------------------------------------------------------------------*/
913
914 inline static const cs_real_t *
916  cs_lnum_t particle_id,
917  cs_lagr_attribute_t attr)
918 {
919  assert(particle_set->p_am->source_term_displ != NULL);
920  assert(particle_set->p_am->source_term_displ[attr] >= 0);
921
922  return (const cs_real_t *)( (unsigned char *)particle_set->p_buffer
923  + particle_set->p_am->extents*particle_id
924  + particle_set->p_am->source_term_displ[attr]);
925 }
926
927 /*----------------------------------------------------------------------------*/
937 /*----------------------------------------------------------------------------*/
938
939 inline static void *
940 cs_lagr_particle_attr(void *particle,
941  const cs_lagr_attribute_map_t *attr_map,
942  cs_lagr_attribute_t attr)
943 {
944  assert(attr_map->count[0][attr] > 0);
945
946  return (unsigned char *)particle + attr_map->displ[0][attr];
947 }
948
949 /*----------------------------------------------------------------------------*/
959 /*----------------------------------------------------------------------------*/
960
961 inline static const void *
962 cs_lagr_particle_attr_const(const void *particle,
963  const cs_lagr_attribute_map_t *attr_map,
964  cs_lagr_attribute_t attr)
965 {
966  assert(attr_map->count[0][attr] > 0);
967
968  return (const unsigned char *)particle + attr_map->displ[0][attr];
969 }
970
971 /*----------------------------------------------------------------------------*/
982 /*----------------------------------------------------------------------------*/
983
984 inline static void *
985 cs_lagr_particle_attr_n(void *particle,
986  const cs_lagr_attribute_map_t *attr_map,
987  int time_id,
988  cs_lagr_attribute_t attr)
989 {
990  assert(attr_map->count[time_id][attr] > 0);
991
992  return (unsigned char *)particle + attr_map->displ[time_id][attr];
993 }
994
995 /*----------------------------------------------------------------------------*/
1006 /*----------------------------------------------------------------------------*/
1007
1008 inline static const void *
1009 cs_lagr_particle_attr_n_const(const void *particle,
1010  const cs_lagr_attribute_map_t *attr_map,
1011  int time_id,
1012  cs_lagr_attribute_t attr)
1013 {
1014  assert(attr_map->count[time_id][attr] > 0);
1015
1016  return (const unsigned char *)particle
1017  + attr_map->displ[time_id][attr];
1018 }
1019
1020 /*----------------------------------------------------------------------------*/
1030 /*----------------------------------------------------------------------------*/
1031
1032 inline static cs_lnum_t
1033 cs_lagr_particle_get_lnum(const void *particle,
1034  const cs_lagr_attribute_map_t *attr_map,
1035  cs_lagr_attribute_t attr)
1036 {
1037  assert(attr_map->count[0][attr] > 0);
1038
1039  return *((const cs_lnum_t *)( (const unsigned char *)particle
1040  + attr_map->displ[0][attr]));
1041 }
1042
1043 /*----------------------------------------------------------------------------*/
1055 /*----------------------------------------------------------------------------*/
1056
1057 inline static cs_lnum_t
1058 cs_lagr_particle_get_lnum_n(const void *particle,
1059  const cs_lagr_attribute_map_t *attr_map,
1060  int time_id,
1061  cs_lagr_attribute_t attr)
1062 {
1063  assert(attr_map->count[time_id][attr] > 0);
1064
1065  return *((const cs_lnum_t *)( (const unsigned char *)particle
1066  + attr_map->displ[time_id][attr]));
1067 }
1068
1069 /*----------------------------------------------------------------------------*/
1078  /*----------------------------------------------------------------------------*/
1079
1080 inline static void
1082  const cs_lagr_attribute_map_t *attr_map,
1083  cs_lagr_attribute_t attr,
1084  cs_lnum_t value)
1085 {
1086  assert(attr_map->count[0][attr] > 0);
1087
1088  *((cs_lnum_t *)((unsigned char *)particle + attr_map->displ[0][attr]))
1089  = value;
1090 }
1091
1092 /*----------------------------------------------------------------------------*/
1103  /*----------------------------------------------------------------------------*/
1104
1105 inline static void
1107  const cs_lagr_attribute_map_t *attr_map,
1108  int time_id,
1109  cs_lagr_attribute_t attr,
1110  cs_lnum_t value)
1111 {
1112  assert(attr_map->count[time_id][attr] > 0);
1113
1114  *((cs_lnum_t *)( (unsigned char *)particle
1115  + attr_map->displ[time_id][attr])) = value;
1116 }
1117
1118 /*----------------------------------------------------------------------------*/
1128 /*----------------------------------------------------------------------------*/
1129
1130 inline static cs_gnum_t
1131 cs_lagr_particle_get_gnum(const void *particle,
1132  const cs_lagr_attribute_map_t *attr_map,
1133  cs_lagr_attribute_t attr)
1134 {
1135  assert(attr_map->count[0][attr] > 0);
1136
1137  return *((const cs_gnum_t *)( (const unsigned char *)particle
1138  + attr_map->displ[0][attr]));
1139 }
1140
1141 /*----------------------------------------------------------------------------*/
1153 /*----------------------------------------------------------------------------*/
1154
1155 inline static cs_gnum_t
1156 cs_lagr_particle_get_gnum_n(const void *particle,
1157  const cs_lagr_attribute_map_t *attr_map,
1158  int time_id,
1159  cs_lagr_attribute_t attr)
1160 {
1161  assert(attr_map->count[time_id][attr] > 0);
1162
1163  return *((const cs_gnum_t *)( (const unsigned char *)particle
1164  + attr_map->displ[time_id][attr]));
1165 }
1166
1167 /*----------------------------------------------------------------------------*/
1176  /*----------------------------------------------------------------------------*/
1177
1178 inline static void
1180  const cs_lagr_attribute_map_t *attr_map,
1181  cs_lagr_attribute_t attr,
1182  cs_gnum_t value)
1183 {
1184  assert(attr_map->count[0][attr] > 0);
1185
1186  *((cs_gnum_t *)((unsigned char *)particle + attr_map->displ[0][attr]))
1187  = value;
1188 }
1189
1190 /*----------------------------------------------------------------------------*/
1201  /*----------------------------------------------------------------------------*/
1202
1203 inline static void
1205  const cs_lagr_attribute_map_t *attr_map,
1206  int time_id,
1207  cs_lagr_attribute_t attr,
1208  cs_gnum_t value)
1209 {
1210  assert(attr_map->count[time_id][attr] > 0);
1211
1212  *((cs_gnum_t *)( (unsigned char *)particle
1213  + attr_map->displ[time_id][attr])) = value;
1214 }
1215
1216 /*----------------------------------------------------------------------------*/
1226 /*----------------------------------------------------------------------------*/
1227
1228 inline static cs_real_t
1229 cs_lagr_particle_get_real(const void *particle,
1230  const cs_lagr_attribute_map_t *attr_map,
1231  cs_lagr_attribute_t attr)
1232 {
1233  assert(attr_map->count[0][attr] > 0);
1234
1235  return *((const cs_real_t *)( (const unsigned char *)particle
1236  + attr_map->displ[0][attr]));
1237 }
1238
1239 /*----------------------------------------------------------------------------*/
1251 /*----------------------------------------------------------------------------*/
1252
1253 inline static cs_real_t
1254 cs_lagr_particle_get_real_n(const void *particle,
1255  const cs_lagr_attribute_map_t *attr_map,
1256  int time_id,
1257  cs_lagr_attribute_t attr)
1258 {
1259  assert(attr_map->count[time_id][attr] > 0);
1260
1261  return *((const cs_real_t *)( (const unsigned char *)particle
1262  + attr_map->displ[time_id][attr]));
1263 }
1264
1265 /*----------------------------------------------------------------------------*/
1274  /*----------------------------------------------------------------------------*/
1275
1276 inline static void
1278  const cs_lagr_attribute_map_t *attr_map,
1279  cs_lagr_attribute_t attr,
1280  cs_real_t value)
1281 {
1282  assert(attr_map->count[0][attr] > 0);
1283
1284  *((cs_real_t *)((unsigned char *)particle + attr_map->displ[0][attr]))
1285  = value;
1286 }
1287
1288 /*----------------------------------------------------------------------------*/
1299  /*----------------------------------------------------------------------------*/
1300
1301 inline static void
1303  const cs_lagr_attribute_map_t *attr_map,
1304  int time_id,
1305  cs_lagr_attribute_t attr,
1306  cs_real_t value)
1307 {
1308  assert(attr_map->count[time_id][attr] > 0);
1309
1310  *((cs_real_t *)( (unsigned char *)particle
1311  + attr_map->displ[time_id][attr])) = value;
1312 }
1313
1314 /*----------------------------------------------------------------------------*/
1324 /*----------------------------------------------------------------------------*/
1325
1326 inline static cs_real_t *
1328  const cs_lagr_attribute_map_t *attr_map,
1329  cs_lagr_attribute_t attr)
1330 {
1331  assert(attr_map->source_term_displ != NULL);
1332  assert(attr_map->source_term_displ[attr] >= 0);
1333
1334  return (cs_real_t *)( (unsigned char *)particle
1335  + attr_map->source_term_displ[attr]);
1336 }
1337
1338 /*----------------------------------------------------------------------------*/
1348 /*----------------------------------------------------------------------------*/
1349
1350 inline static const cs_real_t *
1352  const cs_lagr_attribute_map_t *attr_map,
1353  cs_lagr_attribute_t attr)
1354 {
1355  assert(attr_map->source_term_displ != NULL);
1356  assert(attr_map->source_term_displ[attr] >= 0);
1357
1358  return (const cs_real_t *)( (unsigned char *)particle
1359  + attr_map->source_term_displ[attr]);
1360 }
1361
1362 /*----------------------------------------------------------------------------
1363  * Resize particle set buffers if needed.
1364  *
1365  * parameters:
1366  * n_particles <-- minumum number of particles required
1367  *
1368  *
1369  * returns:
1370  * 1 if resizing was required, 0 otherwise
1371  *----------------------------------------------------------------------------*/
1372
1373 int
1374 cs_lagr_particle_set_resize(cs_lnum_t n_min_particles);
1375
1376 /*----------------------------------------------------------------------------
1377  * Set reallocation factor for particle sets.
1378  *
1379  * This factor determines the multiplier used for reallocations when
1380  * the particle set's buffers are too small to handle the new number of
1381  * particles.
1382  *
1383  * parameters:
1384  * f <-- reallocation size multiplier
1385  *----------------------------------------------------------------------------*/
1386
1387 void
1389
1390 /*----------------------------------------------------------------------------*/
1399 /*----------------------------------------------------------------------------*/
1400
1401 unsigned long long
1403
1404 /*----------------------------------------------------------------------------*/
1413 /*----------------------------------------------------------------------------*/
1414
1415 void
1416 cs_lagr_set_n_g_particles_max(unsigned long long n_g_particles_max);
1417
1418 /*----------------------------------------------------------------------------*/
1425 /*----------------------------------------------------------------------------*/
1426
1427 void
1429  cs_lnum_t particle_id);
1430
1431 /*----------------------------------------------------------------------------*/
1437 /*----------------------------------------------------------------------------*/
1438
1439 void
1441
1442 /*----------------------------------------------------------------------------*/
1448 /*----------------------------------------------------------------------------*/
1449
1450 void
1451 cs_lagr_set_n_user_variables(int n_user_variables);
1452
1453 /*----------------------------------------------------------------------------*/
1454
1456
1457 #endif /* __CS_LAGR_PARTICLE_H__ */
static cs_gnum_t cs_lagr_particle_get_gnum(const void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get attribute value of type cs_gnum_t of a given particle in a set.
Definition: cs_lagr_particle.h:1131
Definition: cs_lagr_particle.h:97
cs_lnum_t n_part_out
Definition: cs_lagr_particle.h:214
static void * cs_lagr_particles_attr_n(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
Get pointer to attribute data of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:451
void cs_lagr_particle_finalize(void)
Destroy main particle set and map if they exist.
Definition: cs_lagr_particle.c:927
static cs_real_t * cs_lagr_particle_source_term(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get pointer to 2nd order scheme attribute source terms of a particle.
Definition: cs_lagr_particle.h:1327
cs_datatype_t
Definition: cs_defs.h:260
static cs_lnum_t cs_lagr_particles_get_lnum_n(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_lnum_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:608
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:286
Definition: cs_lagr_particle.h:122
cs_lagr_particle_set_t * cs_glob_lagr_particle_set
static const cs_real_t * cs_lagr_particle_source_term_const(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Definition: cs_lagr_particle.h:1351
cs_lnum_t n_part_fou
Definition: cs_lagr_particle.h:217
static void cs_lagr_particle_set_real_n(void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr, cs_real_t value)
Set attribute value of type cs_real_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1302
static void * cs_lagr_particle_attr_n(void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr)
Get pointer to attribute data of a particle at a given time.
Definition: cs_lagr_particle.h:985
static void cs_lagr_particle_set_lnum_n(void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr, cs_lnum_t value)
Set attribute value of type cs_lnum_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1106
static cs_real_t cs_lagr_particles_get_real_n(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_real_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:812
void cs_lagr_particle_attr_initialize(void)
Define particle map based on defined options.
Definition: cs_lagr_particle.c:639
Definition: cs_lagr_particle.h:159
ptrdiff_t * source_term_displ
Definition: cs_lagr_particle.h:200
static cs_lnum_t cs_lagr_particle_get_lnum(const void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get attribute value of type cs_lnum_t of a given particle in a set.
Definition: cs_lagr_particle.h:1033
static const void * cs_lagr_particle_attr_const(const void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get const pointer to current attribute data of a particle.
Definition: cs_lagr_particle.h:962
Definition: cs_lagr_particle.h:148
cs_lnum_t n_part_resusp
Definition: cs_lagr_particle.h:218
static const void * cs_lagr_particles_attr_const(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Get const pointer to current attribute data of a given particle in a set.
Definition: cs_lagr_particle.h:425
static cs_gnum_t cs_lagr_particle_get_gnum_n(const void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_gnum_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1156
Definition: cs_lagr_particle.h:100
Definition: cs_defs.h:467
static cs_real_t cs_lagr_particles_get_real(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_real_t of a given particle in a set.
Definition: cs_lagr_particle.h:786
Definition: cs_lagr_particle.h:145
cs_real_t weight_new
Definition: cs_lagr_particle.h:222
Definition: cs_lagr_particle.h:210
static cs_real_t * cs_lagr_particles_source_terms(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Get pointer to 2nd order scheme source terms for an attribute of a given particle in a set...
Definition: cs_lagr_particle.h:889
cs_lagr_attribute_t
Definition: cs_lagr_particle.h:79
static void cs_lagr_particles_set_real(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr, cs_real_t value)
Set attribute value of type cs_real_t of a given particle in a set.
Definition: cs_lagr_particle.h:836
cs_real_t weight_resusp
Definition: cs_lagr_particle.h:227
void cs_lagr_particles_current_to_previous(cs_lagr_particle_set_t *particles, cs_lnum_t particle_id)
Copy current attributes to previous attributes.
Definition: cs_lagr_particle.c:1201
Definition: cs_lagr_particle.h:108
cs_lagr_particle_set_t * cs_lagr_get_particle_set(void)
Definition: cs_lagr_particle.c:1100
cs_real_t weight_fou
Definition: cs_lagr_particle.h:226
Definition: cs_lagr_particle.h:155
Definition: cs_lagr_particle.h:99
Definition: cs_lagr_particle.h:90
Definition: cs_lagr_particle.h:161
int cs_lagr_particle_set_resize(cs_lnum_t n_min_particles)
Definition: cs_lagr_particle.c:1120
const cs_lagr_attribute_map_t * p_am
Definition: cs_lagr_particle.h:232
static void cs_lagr_particles_set_gnum_n(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr, cs_gnum_t value)
Set attribute value of type cs_gnum_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:760
cs_real_t weight_failed
Definition: cs_lagr_particle.h:228
static cs_gnum_t cs_lagr_particles_get_gnum(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Definition: cs_lagr_particle.h:684
Definition: cs_lagr_particle.h:86
cs_real_t weight_dep
Definition: cs_lagr_particle.h:225
static void cs_lagr_particle_set_gnum_n(void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr, cs_gnum_t value)
Set attribute value of type cs_gnum_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1204
Definition: cs_defs.h:302
Definition: cs_lagr_particle.h:84
Definition: cs_lagr_particle.h:117
unsigned char * p_buffer
Definition: cs_lagr_particle.h:234
static void cs_lagr_particles_set_lnum_n(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr, cs_lnum_t value)
Set attribute value of type cs_lnum_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:658
void cs_lagr_set_reallocation_factor(double f)
Definition: cs_lagr_particle.c:1151
static int cs_lagr_particles_get_flag(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int mask)
Get flag value with a selected mask for a given particle in a set.
Definition: cs_lagr_particle.h:503
ptrdiff_t(* displ)[CS_LAGR_N_ATTRIBUTES]
Definition: cs_lagr_particle.h:196
static const void * cs_lagr_particle_attr_n_const(const void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr)
Get const pointer to attribute data of a particle at a given time.
Definition: cs_lagr_particle.h:1009
cs_real_t weight_out
Definition: cs_lagr_particle.h:223
Definition: cs_lagr_particle.h:138
static void * cs_lagr_particle_attr(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get pointer to current attribute data of a particle.
Definition: cs_lagr_particle.h:940
Definition: cs_lagr_particle.h:123
const char * cs_lagr_attribute_name[]
void cs_lagr_particle_attr_in_range(int attr)
Check if a particle attribute is in a valid range.
Definition: cs_lagr_particle.c:1083
Definition: cs_lagr_particle.h:215
static void cs_lagr_particles_set_real_n(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr, cs_real_t value)
Set attribute value of type cs_real_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:862
cs_lnum_t n_part_dep
Definition: cs_lagr_particle.h:216
cs_lnum_t n_particles_max
Definition: cs_lagr_particle.h:230
Definition: cs_lagr_particle.h:107
void cs_lagr_set_n_user_variables(int n_user_variables)
Set number of user particle variables.
Definition: cs_lagr_particle.c:1256
Definition: cs_lagr_particle.h:143
static void cs_lagr_particles_set_gnum(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr, cs_gnum_t value)
Set attribute value of type cs_gnum_t of a given particle in a set.
Definition: cs_lagr_particle.h:734
Definition: cs_lagr_particle.h:139
Definition: cs_lagr_particle.h:118
static const void * cs_lagr_particles_attr_n_const(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
Get const pointer to attribute data of a given particle in a set at a given time. ...
Definition: cs_lagr_particle.h:478
Definition: cs_lagr_particle.h:151
Definition: cs_lagr_particle.h:109
static void cs_lagr_particles_set_flag(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int mask)
Set flag value with a selected mask for a given particle in a set.
Definition: cs_lagr_particle.h:526
static cs_real_t cs_lagr_particle_get_real_n(const void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_real_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1254
Definition: cs_lagr_particle.h:91
cs_lnum_t n_part_new
Definition: cs_lagr_particle.h:213
Definition: cs_lagr_particle.h:212
cs_lnum_t n_failed_part
Definition: cs_lagr_particle.h:219
Definition: cs_lagr_particle.h:150
static void cs_lagr_particles_set_lnum(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr, cs_lnum_t value)
Set attribute value of type cs_lnum_t of a given particle in a set.
Definition: cs_lagr_particle.h:632
void cs_lagr_particle_set_create(void)
Definition: cs_lagr_particle.c:910
static void * cs_lagr_particles_attr(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Get pointer to a current attribute of a given particle in a set.
Definition: cs_lagr_particle.h:400
static void cs_lagr_particle_set_real(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr, cs_real_t value)
Set attribute value of type cs_real_t of a given particle.
Definition: cs_lagr_particle.h:1277
int cs_lagr_check_attr_query(const cs_lagr_particle_set_t *particles, cs_lagr_attribute_t attr, cs_datatype_t datatype, int stride, int component_id)
Check that query for a given particle attribute is valid.
Definition: cs_lagr_particle.c:1018
Definition: cs_lagr_particle.h:93
static const cs_real_t * cs_lagr_particles_source_terms_const(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Get const pointer to 2nd order scheme source terms an attribute of a given particle in a set...
Definition: cs_lagr_particle.h:915
unsigned long long cs_lagr_get_n_g_particles_max(void)
Get global maximum number of particles.
Definition: cs_lagr_particle.c:1169
Definition: cs_lagr_particle.h:147
Definition: cs_defs.h:298
static cs_real_t cs_lagr_particle_get_real(const void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Definition: cs_lagr_particle.h:1229
static cs_gnum_t cs_lagr_particles_get_gnum_n(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_gnum_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:710
int n_time_vals
Definition: cs_lagr_particle.h:184
Definition: cs_lagr_particle.h:133
Definition: cs_lagr_particle.h:116
size_t lb
Definition: cs_lagr_particle.h:180
Definition: cs_defs.h:468
size_t extents
Definition: cs_lagr_particle.h:178
Definition: cs_lagr_particle.h:137
Definition: cs_lagr_particle.h:144
const cs_lagr_attribute_map_t * cs_lagr_particle_get_attr_map(void)
Return const pointer to the main particle attribute map structure.
Definition: cs_lagr_particle.c:897
void cs_lagr_set_n_g_particles_max(unsigned long long n_g_particles_max)
Set global maximum number of particles.
Definition: cs_lagr_particle.c:1186
Definition: cs_lagr_particle.h:95
cs_real_t weight
Definition: cs_lagr_particle.h:221
cs_real_t weight_merged
Definition: cs_lagr_particle.h:224
void cs_lagr_part_copy(cs_lnum_t dest, cs_lnum_t src)
Copy attributes from one particle to another.
Definition: cs_lagr_particle.c:946
Definition: cs_lagr_particle.h:165
static cs_lnum_t cs_lagr_particles_get_lnum(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Definition: cs_lagr_particle.h:582
Definition: cs_lagr_particle.h:92
void cs_lagr_particle_set_dump(const cs_lagr_particle_set_t *particles)
Dump a cs_lagr_particle_set_t structure.
Definition: cs_lagr_particle.c:1228
Definition: cs_lagr_particle.h:176
static cs_lnum_t cs_lagr_particle_get_lnum_n(const void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_lnum_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1058
static void cs_lagr_particles_unset_flag(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int mask)
Unset flag value with a selected mask for a given particle in a set.
Definition: cs_lagr_particle.h:553
void cs_lagr_get_attr_info(const cs_lagr_particle_set_t *particles, int time_id, cs_lagr_attribute_t attr, size_t *extents, size_t *size, ptrdiff_t *displ, cs_datatype_t *datatype, int *count)
Get data extents for a given particle attribute.
Definition: cs_lagr_particle.c:981
Definition: cs_lagr_particle.h:126
Definition: cs_lagr_particle.h:124
static void cs_lagr_particle_set_lnum(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr, cs_lnum_t value)
Set attribute value of type cs_lnum_t of a given particle.
Definition: cs_lagr_particle.h:1081
Definition: cs_lagr_particle.h:106
static void cs_lagr_particle_set_gnum(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr, cs_gnum_t value)
Set attribute value of type cs_gnum_t of a given particle.
Definition: cs_lagr_particle.h:1179
Definition: cs_lagr_particle.h:114
int(* count)[CS_LAGR_N_ATTRIBUTES]
Definition: cs_lagr_particle.h:193
Definition: cs_lagr_particle.h:131
Definition: cs_lagr_particle.h:169
