cs_physical_constants.h
1 #ifndef __CS_PHYSICAL_CONSTANTS_H__
2 #define __CS_PHYSICAL_CONSTANTS_H__
5  * Base physical constants data.
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
45  * Type definitions
48 /* physical constants descriptor */
49 /*-------------------------------*/
50
51 typedef struct {
52
53  cs_real_3_t gravity; /* gravity vector */
54  int icorio; /* Coriolis source terms indicator */
55
57
58 /* fluid properties descriptor */
59 /*-----------------------------*/
60
61 typedef struct {
62
63  int ixyzp0; /* indicator for filling of reference point for
64  total pressure */
65  int icp; /* property index of the isobaric specific heat */
66  int icv; /* property index of the isochoric specific
67  heat */
68  int irovar; /* variable density field */
69  int ivivar; /* variable viscosity field */
70  int ivsuth; /* Sutherland law for laminar viscosity and
71  thermal conductivity in gas mix spec. phys. */
72  double ro0; /* reference density */
73  double viscl0; /* reference molecular dynamic viscosity */
74  double p0; /* reference pressure for the total pressure */
75  double pred0; /* reference value for the reduced pressure */
76  double xyzp0[3]; /* reference point coordinates for the total
77  pressure */
78  double t0; /* reference temperature */
79  double cp0; /* reference specific heat */
80  double cv0; /* reference specific heat */
81  double xmasmr; /* molar mass of the perfect gas in kg/mol
82  (if ieos=1) */
83  int ipthrm; /* Uniform variable thermodynamic pressure for the
84  low-Mach algorithm */
85  double pther; /* uniform thermodynamic pressure for the low-Mach
86  algorithm */
87  double pthera; /* thermodynamic pressure for the previous time
88  step */
89  double pthermax; /* thermodynamic maximum pressure for user
90  clipping, used to model a venting effect */
91  double sleak; /* Leak surface */
92  double kleak; /* Leak head loss (2.9 by default, from Idelcick) */
93  double roref; /* Initial reference density */
94
96
97 /*============================================================================
98  * Static global variables
99  *============================================================================*/
100
101 /* Physical constants */
102
103 extern const double cs_physical_constants_r; /* Ideal gas constant (J/mol/K) */
104 extern const double cs_physical_constants_kb; /* Boltzmann constant (J/K) */
105 extern const double cs_physical_constants_celsius_to_kelvin; /* Celsius to
106  Kelvin*/
107 extern const double cs_physical_constants_stephan; /* Stephan constant
108  (W/m2/K4)*/
109
110 /* Pointer to main physical constants structure */
111
113
114 /* Pointer to main fluid properties structure */
115
117
118 /*=============================================================================
119  * Public function prototypes
120  *============================================================================*/
121
122 /*----------------------------------------------------------------------------
123  * Provide access to cs_glob_physical_constants
124  *
125  * needed to initialize structure with GUI
126  *----------------------------------------------------------------------------*/
127
130
131 /*----------------------------------------------------------------------------
132  * Provide access to cs_glob_fluid_properties
133  *
134  * needed to initialize structure with GUI
135  *----------------------------------------------------------------------------*/
136
139
140 /*----------------------------------------------------------------------------
141  * Print the physical constants structure to setup.log.
142  *----------------------------------------------------------------------------*/
143
144 void
146
147 /*----------------------------------------------------------------------------
148  * Print the fluid properties structure to setup.log.
149  *----------------------------------------------------------------------------*/
150
151 void
153
154 /*----------------------------------------------------------------------------*/
155
157
158 #endif /* __CS_PHYSICAL_CONSTANTS_H__ */
Definition: cs_physical_constants.c:336
Fluid properties descriptor.
int ixyzp0
Definition: cs_physical_constants.h:63
double cp0
Definition: cs_physical_constants.h:79
cs_fluid_properties_t * cs_get_glob_fluid_properties(void)
Definition: cs_physical_constants.c:524
real(c_double), dimension(:), pointer, save xyzp0
coordinates of the reference point for the total pressure.
Definition: cstphy.f90:202
double sleak
Definition: cs_physical_constants.h:91
Definition: cs_defs.h:467
Definition: cs_physical_constants.c:341
double xmasmr
Definition: cs_physical_constants.h:81
double kleak
Definition: cs_physical_constants.h:92
const cs_physical_constants_t * cs_glob_physical_constants
Definition: cs_physical_constants.c:343
cs_physical_constants_t * cs_get_glob_physical_constants(void)
Definition: cs_physical_constants.c:511
double t0
Definition: cs_physical_constants.h:78
double pthermax
Definition: cs_physical_constants.h:89
int icv
Definition: cs_physical_constants.h:66
void cs_fluid_properties_log_setup(void)
Definition: cs_physical_constants.c:564
Definition: cs_physical_constants.c:346
int irovar
Definition: cs_physical_constants.h:68
Ideal gas constant ( )
Definition: cs_physical_constants.c:328
int icorio
Definition: cs_physical_constants.h:54
double pther
Definition: cs_physical_constants.h:85
Definition: cs_physical_constants.c:332
double viscl0
Definition: cs_physical_constants.h:73
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:315
void cs_physical_constants_log_setup(void)
Definition: cs_physical_constants.c:536
int icp
Definition: cs_physical_constants.h:65
double cv0
Definition: cs_physical_constants.h:80
cs_real_3_t gravity
Definition: cs_physical_constants.h:53
int ipthrm
Definition: cs_physical_constants.h:83
Definition: cs_defs.h:468
double pthera
Definition: cs_physical_constants.h:87
double p0
Definition: cs_physical_constants.h:74
Physical constants descriptor.
Definition: cs_physical_constants.h:51
int ivsuth
Definition: cs_physical_constants.h:70
int ivivar
Definition: cs_physical_constants.h:69
double roref
Definition: cs_physical_constants.h:93
double pred0
Definition: cs_physical_constants.h:75
double ro0
Definition: cs_physical_constants.h:72
