src
base
cs_post_default.h
1
#ifndef __CS_POST_DEFAULT_H__
2
#define __CS_POST_DEFAULT_H__
4
5
* Post-processing management
6
8
9
This file is part of Code_Saturne, a general-purpose CFD tool.
11
Copyright (C) 1998-2019 EDF S.A.
13
14
15
16
version.
18
19
20
21
details.
23
24
25
26
28
30
* Standard C library headers
32
34
* Local headers
36
38
#include "
cs_base.h
BEGIN_C_DECLS
45
* Macro definitions
46
48
49
* Local type definitions
50
51
52
53
* Global variables
54
55
56
57
* Public Fortran function prototypes
58
59
60
61
* Loop on post-processing meshes to output variables
62
63
* Fortran interface:
64
65
* subroutine pstvar
66
67
* ( nvar, nscal )
68
69
* integer nvar : <-- : number of variables
70
* integer nscal : <-- : number of scalars
71
72
73
void
CS_PROCF
pstvar
, PSTVAR)
74
75
const
cs_int_t
nvar
76
const
cs_int_t
nscal
77
78
79
80
* Public function prototypes
81
82
83
84
* Output post-processing meshes using associated writers.
85
86
87
void
88
cs_post_default_write_meshes
void
89
90
91
92
END_C_DECLS
93
94
#endif
/* __CS_POST_DEFAULT_H__ */
cs_base.h
void cs_post_default_write_meshes(void)
Definition:
cs_post_default.c:412
BEGIN_C_DECLS
Definition:
cs_defs.h:467
cs_int_t
int cs_int_t
Fortran-compatible integer.
Definition:
cs_defs.h:301
pstvar
void pstvar(const cs_int_t *nvar, const cs_int_t *nscal)
Definition:
cs_post_default.c:367
dimens::nvar
integer, save nvar
number of solved variables (must be lower than nvarmx)
Definition:
dimens.f90:42
END_C_DECLS
Definition:
cs_defs.h:468
dimens::nscal
integer, save nscal
number of solved user scalars effective number of scalars solutions of an advection equation...
Definition:
dimens.f90:55
CS_PROCF
#define CS_PROCF(x, y)
Definition:
cs_defs.h:481
Generated on Tue Sep 24 2019 16:18:04 by
