cs_boundary_conditions.h
1 #ifndef __CS_BOUNDARY_CONDITIONS_H__
2 #define __CS_BOUNDARY_CONDITIONS_H__
5  * Boundary condition handling.
35  * Local headers
38 #include <ple_locator.h>
40 #include "fvm_nodal.h"
41 #include "fvm_writer.h"
43 #include "cs_base.h"
44 #include "cs_field.h"
45 #include "cs_math.h"
46 #include "cs_mesh_location.h"
48 /*----------------------------------------------------------------------------*/
49
51
53  * Macro definitions
55
56 /*============================================================================
57  * Local type definitions
59
60 /*=============================================================================
61  * Global variables
62  *============================================================================*/
63
66 extern const int *cs_glob_bc_type;
67
71 extern const int *cs_glob_bc_face_zone;
72
73 /*============================================================================
74  * Public function prototypes
75  *============================================================================*/
76
77 /*----------------------------------------------------------------------------
78  * Handling of boundary condition definition errors and associated output.
79  *
80  * This function checks for errors, and simply returns if no errors are
81  * encountered. In case of error, it outputs helpful information so as to
82  * make it easier to locate the matching faces.
83  *
84  * For each boundary face, bc_type defines the boundary condition type.
85  * As a convention here, zero values correspond to undefined types,
86  * positive values to defined types (with no error), and negative values
87  * to defined types with inconsistent or incompatible values, the
88  * absolute value indicating the original boundary condition type.
89  *
90  * An optional label may be used if the error is related to another
91  * attribute than the boundary type, for appropriate error reporting.
92  *
93  * parameters:
94  * bc_flag <-- array of BC type ids
95  * type_name <-- name of attribute in error, or NULL
96  *----------------------------------------------------------------------------*/
97
98 void
99 cs_boundary_conditions_error(const int *bc_type,
100  const char *type_name);
101
102 /*----------------------------------------------------------------------------
103  * Locate shifted boundary face coordinates on possibly filtered
104  * cells or boundary faces for later interpolation.
105  *
106  * parameters:
107  * location_type <-- matching values location (CS_MESH_LOCATION_CELLS
108  * or CS_MESH_LOCATION_BOUNDARY_FACES)
109  * n_location_elts <-- number of selected location elements
110  * n_faces <-- number of selected boundary faces
111  * location_elts <-- list of selected location elements (0 to n-1),
112  * or NULL if no indirection is needed
113  * faces <-- list of selected boundary faces (0 to n-1),
114  * or NULL if no indirection is needed
115  * coord_shift <-- array of coordinates shift relative to selected
116  * boundary faces
117  * coord_stride <-- access stride in coord_shift: 0 for uniform
118  * shift, 1 for "per face" shift.
119  * tolerance <-- relative tolerance for point location.
120  *
121  * returns:
122  * associated locator structure
123  *----------------------------------------------------------------------------*/
124
125 ple_locator_t *
127  cs_lnum_t n_location_elts,
128  cs_lnum_t n_faces,
129  const cs_lnum_t *location_elts,
130  const cs_lnum_t *faces,
131  cs_real_3_t *coord_shift,
132  int coord_stride,
133  double tolerance);
134
135 /*----------------------------------------------------------------------------
136  * Set mapped boundary conditions for a given field and mapping locator.
137  *
138  * parameters:
139  * field <-- field whose boundary conditions are set
140  * locator <-- associated mapping locator, as returned
141  * by cs_boundary_conditions_map().
142  * location_type <-- matching values location (CS_MESH_LOCATION_CELLS or
143  * CS_MESH_LOCATION_BOUNDARY_FACES)
144  * normalize <-- normalization option:
145  * 0: values are simply mapped
146  * 1: values are mapped, then multiplied
147  * by a constant factor so that their
148  * surface integral on selected faces
149  * is preserved (relative to the
150  * input values)
151  * 2: as 1, but with a boundary-defined
152  * weight, defined by balance_w
153  * 3: as 1, but with a cell-defined
154  * weight, defined by balance_w
155  * interpolate <-- interpolation option:
156  * 0: values are simply based on matching
157  * cell or face center values
158  * 1: values are based on matching cell
159  * or face center values, corrected
160  * by gradient interpolation
161  * n_faces <-- number of selected boundary faces
162  * faces <-- list of selected boundary faces (0 to n-1),
163  * or NULL if no indirection is needed
164  * balance_w <-- optional balance weight, or NULL
165  * nvar <-- number of variables requiring BC's
166  * rcodcl <-> boundary condition values
167  *----------------------------------------------------------------------------*/
168
169 void
171  ple_locator_t *locator,
172  cs_mesh_location_type_t location_type,
173  int normalize,
174  int interpolate,
175  cs_lnum_t n_faces,
176  const cs_lnum_t *faces,
177  cs_real_t *balance_w,
178  int nvar,
179  cs_real_t rcodcl[]);
180
181 /*----------------------------------------------------------------------------
182  * Create the boundary conditions face type and face zone arrays
183  *----------------------------------------------------------------------------*/
184
185 void
187
188 /*----------------------------------------------------------------------------
189  * Free the boundary conditions face type and face zone arrays
190  *----------------------------------------------------------------------------*/
191
192 void
194
195 /*----------------------------------------------------------------------------*/
206 /*----------------------------------------------------------------------------*/
207
208 inline static void
210  cs_real_t *af,
211  cs_real_t *b,
212  cs_real_t *bf,
213  cs_real_t qimp,
214  cs_real_t hint)
215 {
216  /* Gradient BCs */
217  *a = -qimp/hint;
218  *b = 1.;
219
220  /* Flux BCs */
221  *af = qimp;
222  *bf = 0.;
223 }
224
225 /*----------------------------------------------------------------------------*/
238 /*----------------------------------------------------------------------------*/
239
240 inline static void
242  cs_real_t *af,
243  cs_real_t *b,
244  cs_real_t *bf,
245  cs_real_t pimp,
246  cs_real_t hint,
247  cs_real_t hext)
248 {
249  if (hext < 0.) {
250
251  /* Gradient BCs */
252  *a = pimp;
253  *b = 0.;
254
255  /* Flux BCs */
256  *af = -hint*pimp;
257  *bf = hint;
258
259  }
260  else {
261
262  /* Gradient BCs */
263  *a = hext*pimp/(hint + hext);
264  *b = hint /(hint + hext);
265
266  /* Flux BCs */
267  cs_real_t heq = hint*hext/(hint + hext);
268  *af = -heq*pimp;
269  *bf = heq;
270
271  }
272 }
273
274 /*----------------------------------------------------------------------------*/
287 /*----------------------------------------------------------------------------*/
288
289 inline static void
291  cs_real_3_t af,
292  cs_real_33_t b,
293  cs_real_33_t bf,
294  cs_real_3_t pimpv,
295  cs_real_t hint,
296  cs_real_3_t hextv)
297 {
298  for (int isou = 0 ; isou < 3; isou++) {
299  if (fabs(hextv[isou]) > 0.5*cs_math_infinite_r) {
300
301  /* Gradient BCs */
302  a[isou] = pimpv[isou];
303  for (int jsou = 0 ; jsou < 3 ; jsou++)
304  b[isou][jsou] = 0.;
305
306  /* Flux BCs */
307  af[isou] = -hint*pimpv[isou];
308  for (int jsou = 0; jsou < 3; jsou++) {
309  if (jsou == isou)
310  bf[isou][jsou] = hint;
311  else
312  bf[isou][jsou] = 0.;
313  }
314  } else {
315
316  cs_real_t heq = hint*hextv[isou]/(hint + hextv[isou]);
317
318  /* Gradient BCs */
319  a[isou] = hextv[isou]*pimpv[isou]/(hint + hextv[isou]);
320  for (int jsou = 0 ; jsou < 3 ; jsou++) {
321  if (jsou == isou)
322  b[isou][jsou] = hint/(hint + hextv[isou]);
323  else
324  b[isou][jsou] = 0.;
325  }
326
327  /* Flux BCs */
328  af[isou] = -heq*pimpv[isou];
329  for (int jsou = 0 ; jsou < 3 ; jsou++) {
330  if (jsou == isou)
331  bf[isou][jsou] = heq;
332  else
333  bf[isou][jsou] = 0.;
334  }
335  }
336  }
337 }
338
339 /*----------------------------------------------------------------------------*/
352 /*----------------------------------------------------------------------------*/
353
354 void
356  cs_real_t *cofaf,
357  cs_real_t *coefb,
358  cs_real_t *cofbf,
359  cs_real_t pimp,
360  cs_real_t cfl,
361  cs_real_t hint);
362
363 /*----------------------------------------------------------------------------*/
377 /*----------------------------------------------------------------------------*/
378
379 inline static void
381  cs_real_3_t af,
382  cs_real_33_t b,
383  cs_real_33_t bf,
384  cs_real_3_t pimpv,
385  cs_real_6_t hintt,
386  cs_real_3_t hextv)
387 {
388  for (int isou = 0 ; isou < 3 ; isou++) {
389  if (fabs(hextv[isou]) > 0.5*cs_math_infinite_r) {
390
391  /* Gradient BCs */
392  a[isou] = pimpv[isou];
393  for (int jsou = 0 ; jsou < 3 ; jsou++)
394  b[isou][jsou] = 0.;
395
396  } else {
397
398  cs_exit(1);
399
400  }
401  }
402
403  /* Flux BCs */
404  cs_math_sym_33_3_product(hintt, pimpv, af);
405  for (int isou = 0 ; isou < 3 ; isou++)
406  af[isou] = -af[isou];
407
408  bf[0][0] = hintt[0];
409  bf[1][1] = hintt[1];
410  bf[2][2] = hintt[2];
411  bf[0][1] = hintt[3];
412  bf[1][0] = hintt[3];
413  bf[1][2] = hintt[4];
414  bf[2][1] = hintt[4];
415  bf[0][2] = hintt[5];
416  bf[2][0] = hintt[5];
417 }
418
419 /*----------------------------------------------------------------------------*/
420
422
423 #endif /* __CS_BOUNDARY_CONDITIONS_H__ */
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:317
Definition: cs_field.h:124
Definition: cs_mesh_location.h:60
void cs_boundary_conditions_free(void)
Definition: cs_boundary_conditions.c:773
Definition: cs_defs.h:467
void cs_exit(int status)
Definition: cs_base.c:1401
void cs_boundary_conditions_create(void)
Definition: cs_boundary_conditions.c:743
void cs_boundary_conditions_mapped_set(const cs_field_t *f, ple_locator_t *locator, cs_mesh_location_type_t location_type, int normalize, int interpolate, cs_lnum_t n_faces, const cs_lnum_t *faces, cs_real_t *balance_w, int nvar, cs_real_t rcodcl[])
Definition: cs_boundary_conditions.c:553
const int * cs_glob_bc_face_zone
Definition: cs_defs.h:302
static void cs_boundary_conditions_set_dirichlet_scalar(cs_real_t *a, cs_real_t *af, cs_real_t *b, cs_real_t *bf, cs_real_t pimp, cs_real_t hint, cs_real_t hext)
Set Dirichlet BC for a scalar for a given face.
Definition: cs_boundary_conditions.h:241
void cs_boundary_conditions_set_convective_outlet_scalar(cs_real_t *coefa, cs_real_t *cofaf, cs_real_t *coefb, cs_real_t *cofbf, cs_real_t pimp, cs_real_t cfl, cs_real_t hint)
Set convective oulet boundary condition for a scalar.
Definition: cs_boundary_conditions.c:799
double precision, save a
integer, save nvar
number of solved variables (must be lower than nvarmx)
Definition: dimens.f90:42
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:315
static void cs_boundary_conditions_set_dirichlet_vector(cs_real_3_t a, cs_real_3_t af, cs_real_33_t b, cs_real_33_t bf, cs_real_3_t pimpv, cs_real_t hint, cs_real_3_t hextv)
Set Dirichlet BC for a vector for a given face.
Definition: cs_boundary_conditions.h:290
Definition: cs_defs.h:298
static void cs_boundary_conditions_set_dirichlet_vector_aniso(cs_real_3_t a, cs_real_3_t af, cs_real_33_t b, cs_real_33_t bf, cs_real_3_t pimpv, cs_real_6_t hintt, cs_real_3_t hextv)
Set Dirichlet BC for a vector for a given face with left anisotropic diffusion.
Definition: cs_boundary_conditions.h:380
Definition: cs_defs.h:468
double precision, dimension(nozppm), save qimp
Definition: coincl.f90:108
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:321
static void cs_math_sym_33_3_product(const cs_real_t m[6], const cs_real_t v[3], cs_real_t mv[restrict 3])
Compute the product of a symmetric matrix of 3x3 real values by a vector of 3 real values...
Definition: cs_math.h:561
void cs_boundary_conditions_error(const int *bc_type, const char *type_name)
Definition: cs_boundary_conditions.c:339
static void cs_boundary_conditions_set_neumann_scalar(cs_real_t *a, cs_real_t *af, cs_real_t *b, cs_real_t *bf, cs_real_t qimp, cs_real_t hint)
Set Neumann BC for a scalar for a given face.
Definition: cs_boundary_conditions.h:209
double precision hext
Definition: cs_tagmr.f90:100
const cs_real_t cs_math_infinite_r
ple_locator_t * cs_boundary_conditions_map(cs_mesh_location_type_t location_type, cs_lnum_t n_location_elts, cs_lnum_t n_faces, const cs_lnum_t *location_elts, const cs_lnum_t *faces, cs_real_3_t *coord_shift, int coord_stride, double tolerance)
Locate shifted boundary face coordinates on possibly filtered cells or boundary faces for later inter...
Definition: cs_boundary_conditions.c:393
const int * cs_glob_bc_type
double precision, save b
