cs_turbulence_model.h
1 #ifndef __CS_TURBULENCE_MODEL_H__
2 #define __CS_TURBULENCE_MODEL_H__
5  * Base turbulence model data.
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
45  * Type definitions
48 /*----------------------------------------------------------------------------
49  * turbulence models
50  *----------------------------------------------------------------------------*/
51
52 enum {
69 };
70
71
72 /* turbulence model general options descriptor */
73 /*---------------------------------------------*/
74
75 typedef struct {
76
77  int iturb; /* turbulence model
78  CS_TURB_NONE: no turbulence model (laminar flow)
79  CS_TURB_MIXING_LENGTH: mixing length model
80  CS_TURB_K_EPSILON: standard k-epsilon model
81  CS_TURB_K_EPSILON_LIN_PROD: k-epsilon model with
82  Linear Production (LP) correction
83  CS_TURB_K_EPSILON_LS: Launder-Sharma low Re
84  k-epsilon model
85  CS_TURB_K_EPSILON_QUAD : Baglietto et al. low Re
86  k epsilon model
87  CS_TURB_RIJ_EPSILON_LRR: Rij-epsilon (LRR)
88  CS_TURB_RIJ_EPSILON_SSG: Rij-epsilon (SSG)
89  CS_TURB_RIJ_EPSILON_EBRSM: Rij-epsilon (EBRSM)
90  CS_TURB_LES_SMAGO_CONST: LES
91  (constant Smagorinsky model)
92  CS_TURB_LES_SMAGO_DYN: LES ("classical" dynamic
93  Smagorisky model)
94  CS_TURB_LES_WALE: LES (WALE)
95  CS_TURB_V2F_PHI: v2f phi-model
96  CS_TURB_V2F_BL_V2K: v2f BL-v2-k
97  CS_TURB_K_OMEGA: k-omega SST
98  CS_TURB_SPALART_ALLMARAS: Spalart-Allmaras model */
99  int itytur; /* class of turbulence model (integer value
100  iturb/10) */
102
103
104 /* Reference values for turbulence structure and associated pointer */
105 /*------------------------------------------------------------------*/
106
107 typedef struct {
108  double almax; /* characteristic macroscopic length of the
109  domain */
110  double uref; /* characteristic flow velocity */
112
113
114 /* rans turbulence model descriptor */
115 /*----------------------------------*/
116
117 typedef struct {
118
119  int irccor; /* activation of rotation/curvature correction for
120  an eddy viscosity turbulence models
121  - 0: false
122  - 1: true */
123  int itycor; /* type of rotation/curvature correction for an
124  eddy viscosity turbulence models
125  - 1: Cazalbou correction (default when irccor=1
126  and itytur=2 or 5)
127  - 2: Spalart-Shur correction (default when
128  irccor=1 and iturb=60 or 70) */
129  int idirsm; /* turbulent diffusion model for second moment
130  closure
131  - 0: scalar diffusivity (Shir model)
132  - 1: tensorial diffusivity (Daly and Harlow
133  model, default model) */
134  int iclkep; /* clipping of k and epsilon
135  - 0: absolute value clipping
136  - 1: coupled clipping based on physical
137  relationships */
138  int igrhok; /* take (2/3 rho grad k) in the momentum
139  equation
140  - 1: true
141  - 0: false (default) */
142  int igrake; /* buoyant term in k-epsilon
143  - 1: true (default if rho is variable)
144  - 0: false */
145  int igrari; /* buoyant term in Rij-epsilon
146  - 1: true (default if rho is variable)
147  - 0: false */
148  int ikecou; /* partially coupled version of
149  k-epsilon (only for iturb=20)
150  - 1: true (default)
151  - 0: false */
152  int reinit_turb; /* Advanced re-init for EBRSM and k-omega models
153  - 1: true (default)
154  - 0: false */
155  int irijco; /* coupled solving of Rij
156  - 1: true
157  - 0: false (default) */
158  int iddes; /* delayed detached eddy simulation
159  - 1: true
160  - 0: false (default) */
161  int irijnu; /* pseudo eddy viscosity in the matrix of momentum
162  equation to partially implicit div( rho R )
163  - 1: true
164  - 0: false (default) */
165  int irijrb; /* accurate treatment of R at the boundary (see
166  \ref condli)
167  - 1: true
168  - 0: false (default) */
169  int irijec; /* wall echo term of R
170  - 1: true
171  - 0: false (default) */
172  int idifre; /* whole treatment of the diagonal part of the
173  diffusion tensor of R and epsilon
174  - 1: true (default)
175  - 0: simplified treatment */
176  int iclsyr; /* partial implicitation of symmetry BCs of R
177  - 1: true (default)
178  - 0: false */
179  int iclptr; /* partial implicitation of wall BCs of R
180  - 1: true
181  - 0: false (default) */
182  double xlomlg; /* mixing length */
183
185
186 /* LES turbulence model descriptor */
187 /*---------------------------------*/
188
189 typedef struct {
190
191  int idries; /* Van Driest smoothing at the wall (only for
192  itytur=4)
193  - 1: true
194  - 0: false */
195  int ivrtex; /* vortex method (in LES)
196  - 1: true
197  - 0: false (default) */
198
200
201 /*============================================================================
202  * Static global variables
203  *============================================================================*/
204
205 /* Pointer to main turbulence model descriptor structure */
206
207 extern const cs_turb_model_t *cs_glob_turb_model;
208
209 /* Pointer to reference values for turbulence descriptor structure */
210
212
213 /* Pointer to RANS turbulence model descriptor structure */
214
216
217 /* Pointer to LES turbulence model descriptor structure */
218
220
221 /* Constant for turbulence models */
222
223 extern const double cs_turb_xkappa;
224 extern const double cs_turb_vdriest;
225 extern const double cs_turb_cstlog;
226 extern const double cs_turb_cstlog_rough;
227 extern double cs_turb_cstlog_alpha;
228 extern const double cs_turb_apow;
229 extern const double cs_turb_bpow;
230 extern double cs_turb_dpow;
231 extern double cs_turb_cmu;
232 extern double cs_turb_cmu025;
233 extern const double cs_turb_ce1;
234 extern const double cs_turb_ce2;
235 extern const double cs_turb_ce4;
236 extern const double cs_turb_sigmak;
237 extern double cs_turb_sigmae;
238 extern double cs_turb_crij1;
239 extern double cs_turb_crij2;
240 extern double cs_turb_crij3;
241 extern const double cs_turb_crijp1;
242 extern const double cs_turb_crijp2;
243 extern const double cs_turb_cssge2;
244 extern const double cs_turb_cssgs1;
245 extern const double cs_turb_cssgs2;
246 extern const double cs_turb_cssgr1;
247 extern const double cs_turb_cssgr2;
248 extern const double cs_turb_cssgr3;
249 extern const double cs_turb_cssgr4;
250 extern const double cs_turb_cssgr5;
251 extern const double cs_turb_cebms1;
252 extern const double cs_turb_cebms2;
253 extern const double cs_turb_cebmr1, cebmr2, cebmr3, cebmr4, cebmr5;
254 extern double cs_turb_csrij;
255 extern const double cs_turb_cebme2;
256 extern const double cs_turb_cebmmu;
257 extern const double cs_turb_xcl;
258 extern const double cs_turb_xa1;
259 extern const double cs_turb_xct;
260 extern const double cs_turb_xceta;
261 extern const double cs_turb_cpale1;
262 extern const double cs_turb_cpale2;
263 extern const double cs_turb_cpale3;
264 extern const double cs_turb_cpale4;
265 extern const double cs_turb_cpalse;
266 extern const double cs_turb_cpalmu;
267 extern const double cs_turb_cpalc1;
268 extern const double cs_turb_cpalc2;
269 extern const double cs_turb_cpalct;
270 extern const double cs_turb_cpalcl;
271 extern const double cs_turb_cpalet;
272 extern const double cs_turb_ckwsk1;
273 extern const double cs_turb_ckwsk2;
274 extern const double cs_turb_ckwsw1;
275 extern const double cs_turb_ckwsw2;
276 extern const double cs_turb_ckwbt1;
277 extern const double cs_turb_ckwbt2;
278 extern double cs_turb_ckwgm1;
279 extern double cs_turb_ckwgm2;
280 extern const double cs_turb_ckwa1;
281 extern const double cs_turb_ckwc1;
282 extern const double cs_turb_csab1;
283 extern const double cs_turb_csab2;
284 extern const double cs_turb_csasig;
285 extern const double cs_turb_csav1;
286 extern double cs_turb_csaw1;
287 extern const double cs_turb_csaw2;
288 extern const double cs_turb_csaw3;
289 extern const double cs_turb_cssr1;
290 extern const double cs_turb_cssr2;
291 extern const double cs_turb_cssr3;
292 extern const double cs_turb_ccaze2;
293 extern const double cs_turb_ccazsc;
294 extern const double cs_turb_ccaza;
295 extern const double cs_turb_ccazb;
296 extern const double cs_turb_ccazc;
297 extern const double cs_turb_ccazd;
298 extern const double cs_turb_xlesfl;
299 extern const double cs_turb_ales;
300 extern const double cs_turb_bles;
301 extern double cs_turb_csmago;
302 extern const double cs_turb_xlesfd;
303 extern double cs_turb_smagmx;
304 extern double cs_turb_smagmn;
305 extern const double cs_turb_cdries;
306 extern const double cs_turb_cv2fa1;
307 extern const double cs_turb_cv2fe2;
308 extern const double cs_turb_cv2fmu;
309 extern const double cs_turb_cv2fc1;
310 extern const double cs_turb_cv2fc2;
311 extern const double cs_turb_cv2fct;
312 extern const double cs_turb_cv2fcl;
313 extern const double cs_turb_cv2fet;
314 extern double cs_turb_cwale;
315 extern const double cs_turb_xiafm;
316 extern const double cs_turb_etaafm;
317 extern const double cs_turb_c1trit;
318 extern const double cs_turb_c2trit;
319 extern const double cs_turb_c3trit;
320 extern const double cs_turb_c4trit;
321 extern const double cs_turb_cthafm;
322 extern const double cs_turb_cthdfm;
323
324 /*=============================================================================
325  * Public function prototypes
326  *============================================================================*/
327
328 /*----------------------------------------------------------------------------
329  * Provide acces to cs_glob_turb_model
330  *
331  * needed to initialize structure with GUI
332  *----------------------------------------------------------------------------*/
333
336
337 /*----------------------------------------------------------------------------
338  * Compute turbulence model constants,
339  * some of which may depend on the model choice.
340  *----------------------------------------------------------------------------*/
341
342 void
344
345 /*----------------------------------------------------------------------------
346  * Provide acces to cs_glob_turb_ref_values
347  *
348  * needed to initialize structure with GUI
349  *----------------------------------------------------------------------------*/
350
353
354 /*----------------------------------------------------------------------------
355  * Provide acces to cs_glob_turb_rans_model
356  *
357  * needed to initialize structure with GUI
358  *----------------------------------------------------------------------------*/
359
362
363 /*----------------------------------------------------------------------------
364  * Provide acces to cs_glob_turb_les_model
365  *
366  * needed to initialize structure with GUI
367  *----------------------------------------------------------------------------*/
368
371
372 /*----------------------------------------------------------------------------*
373  * Print the turbulence model parameters to setup.log.
374  *----------------------------------------------------------------------------*/
375
376 void
378
379 /*----------------------------------------------------------------------------*
380  * Print the turbulent constants to setup.log.
381  *----------------------------------------------------------------------------*/
382
383 void
385
386 /*----------------------------------------------------------------------------*/
387
389
390 #endif /* __CS_TURBULENCE_MODEL_H__ */
Definition: cs_turbulence_model.c:717
Definition: cs_turbulence_model.c:876
Definition: cs_turbulence_model.c:642
Definition: cs_turbulence_model.c:393
Definition: cs_turbulence_model.h:53
Definition: cs_turbulence_model.c:573
int itytur
Definition: cs_turbulence_model.h:99
Definition: cs_turbulence_model.c:648
const cs_turb_rans_model_t * cs_glob_turb_rans_model
Definition: cs_turbulence_model.c:563
Definition: cs_turbulence_model.c:549
Definition: cs_turbulence_model.h:62
Definition: cs_turbulence_model.h:64
Definition: cs_turbulence_model.h:54
Definition: cs_turbulence_model.c:537
void cs_turb_constants_log_setup(void)
Definition: cs_turbulence_model.c:1579
Definition: cs_turbulence_model.c:683
Definition: cs_turbulence_model.h:61
const double cebmr5
Definition: cstphy.f90:447
Definition: cs_turbulence_model.c:618
double xlomlg
Definition: cs_turbulence_model.h:182
Definition: cs_turbulence_model.c:936
int irijec
Definition: cs_turbulence_model.h:169
Definition: cs_turbulence_model.c:777
Definition: cs_turbulence_model.h:56
Definition: cs_turbulence_model.c:507
Definition: cs_turbulence_model.c:870
Definition: cs_defs.h:467
cs_turb_les_model_t * cs_get_glob_turb_les_model(void)
Provide acces to cs_glob_turb_les_model.
Definition: cs_turbulence_model.c:1253
Definition: cs_turbulence_model.c:752
Turbulence model general options descriptor.
Definition: cs_turbulence_model.h:75
int idries
Definition: cs_turbulence_model.h:191
int irijrb
Definition: cs_turbulence_model.h:165
Definition: cs_turbulence_model.c:484
Definition: cs_turbulence_model.c:796
double almax
Definition: cs_turbulence_model.h:108
Definition: cs_turbulence_model.c:478
Definition: cs_turbulence_model.c:747
const double cebmr2
Definition: cs_turbulence_model.c:591
int igrari
Definition: cs_turbulence_model.h:145
int irccor
Definition: cs_turbulence_model.h:119
int iddes
Definition: cs_turbulence_model.h:158
Definition: cs_turbulence_model.c:459
Definition: cs_turbulence_model.c:472
Definition: cs_turbulence_model.h:60
Definition: cs_turbulence_model.c:636
int itycor
Definition: cs_turbulence_model.h:123
Definition: cs_turbulence_model.c:543
Definition: cs_turbulence_model.h:65
int igrake
Definition: cs_turbulence_model.h:142
Definition: cs_turbulence_model.c:916
const cs_turb_les_model_t * cs_glob_turb_les_model
Definition: cs_turbulence_model.h:107
Definition: cs_turbulence_model.c:499
Definition: cs_turbulence_model.c:465
Definition: cs_turbulence_model.c:615
Definition: cs_turbulence_model.c:597
int irijnu
Definition: cs_turbulence_model.h:161
Definition: cs_turbulence_model.c:417
Definition: cs_turbulence_model.h:68
int reinit_turb
Definition: cs_turbulence_model.h:152
int iclptr
Definition: cs_turbulence_model.h:179
Definition: cs_turbulence_model.c:600
void cs_turb_model_log_setup(void)
Definition: cs_turbulence_model.c:1265
Definition: cs_turbulence_model.c:911
Definition: cs_turbulence_model.c:585
Definition: cs_turbulence_model.c:579
Definition: cs_turbulence_model.c:690
Definition: cs_turbulence_model.c:434
Definition: cs_turbulence_model.c:561
Definition: cs_turbulence_model.h:58
Definition: cs_turbulence_model.c:882
Definition: cs_turbulence_model.c:864
Definition: cs_turbulence_model.c:787
Definition: cs_turbulence_model.c:606
Definition: cs_turbulence_model.c:490
const double cebmr3
Definition: cs_turbulence_model.c:926
Definition: cs_turbulence_model.c:805
RANS turbulence model descriptor.
Definition: cs_turbulence_model.h:117
void cs_turb_compute_constants(void)
Compute turbulence model constants, some of which may depend on the model choice. ...
Definition: cs_turbulence_model.c:1180
const cs_turb_ref_values_t * cs_glob_turb_ref_values
Definition: cs_turbulence_model.c:732
Definition: cs_turbulence_model.c:894
Definition: cs_turbulence_model.h:57
Definition: cs_turbulence_model.c:519
Definition: cs_turbulence_model.c:906
Definition: cs_turbulence_model.c:888
Definition: cs_turbulence_model.c:404
Definition: cs_turbulence_model.c:373
Definition: cs_turbulence_model.c:672
Definition: cs_turbulence_model.c:707
Definition: cs_turbulence_model.c:702
Definition: cs_turbulence_model.c:772
Definition: cs_turbulence_model.c:757
int ikecou
Definition: cs_turbulence_model.h:148
Definition: cs_turbulence_model.c:555
Definition: cs_turbulence_model.c:767
Definition: cs_turbulence_model.c:839
Definition: cs_turbulence_model.c:660
Definition: cs_turbulence_model.c:621
cs_turb_ref_values_t * cs_get_glob_turb_ref_values(void)
Provide acces to cs_glob_turb_ref_values.
Definition: cs_turbulence_model.c:1225
int idifre
Definition: cs_turbulence_model.h:172
int iturb
Definition: cs_turbulence_model.h:77
Definition: cs_turbulence_model.c:630
Definition: cs_turbulence_model.c:624
LES turbulence model descriptor.
Definition: cs_turbulence_model.h:189
const double cebmr4
Definition: cs_turbulence_model.c:382
Definition: cs_defs.h:468
Definition: cs_turbulence_model.c:594
Definition: cs_turbulence_model.c:946
Definition: cs_turbulence_model.c:849
cs_turb_model_t * cs_get_glob_turb_model(void)
Provide access to global turbulence model structure cs_glob_turb_model.
Definition: cs_turbulence_model.c:1167
Definition: cs_turbulence_model.c:442
Definition: cs_turbulence_model.c:712
Definition: cs_turbulence_model.c:941
Definition: cs_turbulence_model.c:525
Definition: cs_turbulence_model.c:858
int iclsyr
Definition: cs_turbulence_model.h:176
Definition: cs_turbulence_model.h:59
Definition: cs_turbulence_model.c:576
Definition: cs_turbulence_model.c:609
int iclkep
Definition: cs_turbulence_model.h:134
Definition: cs_turbulence_model.c:900
Definition: cs_turbulence_model.c:819
Definition: cs_turbulence_model.h:67
Definition: cs_turbulence_model.c:654
Definition: cs_turbulence_model.c:582
const cs_turb_model_t * cs_glob_turb_model
Definition: cs_turbulence_model.c:931
double uref
Definition: cs_turbulence_model.h:110
Definition: cs_turbulence_model.c:829
Definition: cs_turbulence_model.c:531
Definition: cs_turbulence_model.c:921
int igrhok
Definition: cs_turbulence_model.h:138
Definition: cs_turbulence_model.h:55
double cs_turb_cmu
Definition: cs_turbulence_model.c:431
Definition: cs_turbulence_model.c:762
Definition: cs_turbulence_model.c:722
cs_turb_rans_model_t * cs_get_glob_turb_rans_model(void)
Provide acces to cs_glob_turb_rans_model.
Definition: cs_turbulence_model.c:1239
int idirsm
Definition: cs_turbulence_model.h:129
Definition: cs_turbulence_model.c:697
Definition: cs_turbulence_model.c:513
double cs_turb_dpow
Definition: cs_turbulence_model.c:423
int irijco
Definition: cs_turbulence_model.h:155
Definition: cs_turbulence_model.c:612
Definition: cs_turbulence_model.c:727
Definition: cs_turbulence_model.h:63
Definition: cs_turbulence_model.h:66
Definition: cs_turbulence_model.c:737
int ivrtex
Definition: cs_turbulence_model.h:195
Definition: cs_turbulence_model.c:420
Definition: cs_turbulence_model.c:558
Definition: cs_turbulence_model.c:588
Definition: cs_turbulence_model.c:414
Definition: cs_turbulence_model.c:951
Definition: cs_turbulence_model.c:450
Definition: cs_turbulence_model.c:742
Definition: cs_turbulence_model.c:603
