| double precision, save | xkappa |
| | Karman constant. (= 0.42) Useful if and only if iturb >= 10. (mixing length, , , LES, v2f or ) More...
| double precision, save | cstlog |
| | constant of logarithmic law function: ( ) constant of the logarithmic wall function. Useful if and only if iturb >= 10 (mixing length, , , LES, v2f or ) More...
| real(c_double), pointer, save | ypluli |
| | limit value of for the viscous sublayer. ypluli depends on the chosen wall function: it is initialized to 10.88 for the scalable wall function (iwallf=4), otherwise it is initialized to . In LES, ypluli is taken by default to be 10.88. More...
| double precision, save | apow |
| | Werner and Wengle coefficient. More...
| double precision, save | bpow |
| double precision, save | cpow |
| double precision, save | dpow |
| real(c_double), pointer, save | cmu |
| | constant for all the RANS turbulence models except for the v2f model (see cv2fmu for the value of in case of v2f modelling). Useful if and only if iturb = 20, 21, 30, 31 or 60 ( , or ) More...
| real(c_double), pointer, save | cmu025 |
| | More...
| double precision, save | ce1 |
| | constant for all the RANS turbulence models except for the v2f and the models. Useful if and only if iturb= 20, 21, 30 or 31 ( or ) More...
| double precision, save | ce2 |
| | constant for the and LRR models. Useful if and only if iturb= 20, 21 or 30 ( or LRR) More...
| double precision, save | cnl1 |
| | constant for the model from Baglietto et al. (quadratric) Useful if and only if iturb= 23 More...
| double precision, save | cnl2 |
| double precision, save | cnl3 |
| double precision, save | cnl4 |
| double precision, save | cnl5 |
| double precision, save | ce4 |
| | Coefficient of interfacial coefficient in k-eps, used in Lagrange treatment. More...
| double precision, save | sigmak |
| | Prandtl number for with and v2f models. Useful if and only if iturb=20, 21 or 50 ( or v2f) More...
| real(c_double), pointer, save | sigmae |
| | Prandtl number for . Useful if and only if iturb= 20, 21, 30, 31 or 50 ( , or v2f) More...
| double precision, save | crij1 |
| | constant for the LRR model. Useful if and only if iturb=30 ( LRR) More...
| double precision, save | crij2 |
| double precision, save | crij3 |
| | constant for the buoyant production term models. More...
| double precision, save | crijp1 |
| | constant for the LRR model, corresponding to the wall echo terms. Useful if and only if iturb=30 and irijec=1 ( LRR) More...
| double precision, save | crijp2 |
| double precision, save | cssge2 |
| | constant for the SSG model. Useful if and only if iturb=31 ( SSG) More...
| double precision, save | cssgs1 |
| double precision, save | cssgs2 |
| double precision, save | cssgr1 |
| double precision, save | cssgr2 |
| double precision, save | cssgr3 |
| double precision, save | cssgr4 |
| double precision, save | cssgr5 |
| double precision, save | cebms1 |
| | constant of the Rij-epsilon EBRSM More...
| double precision, save | cebms2 |
| double precision, save | cebmr1 |
| double precision, save | cebmr2 |
| double precision, save | cebmr3 |
| double precision, save | cebmr4 |
| double precision, save | cebmr5 |
| double precision, save | csrij |
| | constant for the models. More...
| double precision, save | cebme2 |
| double precision, save | cebmmu |
| double precision, save | xcl |
| double precision, save | xa1 |
| | constant in the expression of Ce1' for the Rij-epsilon EBRSM More...
| double precision, save | xct |
| double precision, save | xceta |
| double precision, save | cpale1 |
| | specific constant of v2f "BL-v2k" (or phi-alpha) More...
| double precision, save | cpale2 |
| double precision, save | cpale3 |
| double precision, save | cpale4 |
| double precision, save | cpalse |
| double precision, save | cpalmu |
| double precision, save | cpalc1 |
| double precision, save | cpalc2 |
| double precision, save | cpalct |
| double precision, save | cpalcl |
| double precision, save | cpalet |
| double precision, save | ckwsk1 |
| | constant for the SST model. Useful if and only if iturb=60 More...
| double precision, save | ckwsk2 |
| double precision, save | ckwsw1 |
| | constant for the SST model. Useful if and only if iturb=60 ( SST) More...
| double precision, save | ckwsw2 |
| double precision, save | ckwbt1 |
| double precision, save | ckwbt2 |
| double precision, save | cddes |
| | constant for the SST model. Useful if and only if iturb=60 ( SST) and iddes=1 More...
| double precision, save | ckwgm1 |
| double precision, save | ckwgm2 |
| double precision, save | ckwa1 |
| | specific constant of k-omega SST constant for the SST model. Useful if and only if iturb=60 ( SST) More...
| double precision, save | ckwc1 |
| | constant for the SST model. Useful if and only if iturb=60 ( SST) specific constant of k-omega SST More...
| double precision, save | csab1 |
| | specific constant of Spalart-Allmaras More...
| double precision, save | csab2 |
| double precision, save | csasig |
| double precision, save | csav1 |
| double precision, save | csaw1 |
| double precision, save | csaw2 |
| double precision, save | csaw3 |
| double precision, save | cssr1 |
| | constant of the Spalart-Shur rotation/curvature correction More...
| double precision, save | cssr2 |
| double precision, save | cssr3 |
| double precision, save | ccaze2 |
| | constants of the Cazalbou rotation/curvature correction More...
| double precision, save | ccazsc |
| double precision, save | ccaza |
| double precision, save | ccazb |
| double precision, save | ccazc |
| double precision, save | ccazd |
| real(c_double), pointer, save | almax |
| | is a characteristic macroscopic length of the domain, used for the initialization of the turbulence and the potential clipping (with iclkep=1) More...
| real(c_double), pointer, save | uref |
| | the characteristic flow velocity, used for the initialization of the turbulence. Negative value: not initialized. More...
| real(c_double), pointer, save | xlomlg |
| | mixing length for the mixing length model More...
| double precision, save | xlesfl |
| | constant used in the definition of LES filtering diameter: xlesfl is a constant used to define, for each cell , the width of the (implicit) filter:
Useful if and only if iturb = 40 or 41 More...
| double precision, save | ales |
| | constant used to define, for each cell , the width of the (implicit) filter: More...
| double precision, save | bles |
| | constant used to define, for each cell , More...
| double precision, save | csmago |
| | Smagorinsky constant used in the Smagorinsky model for LES. The sub-grid scale viscosity is calculated by where is the width of the filter and the filtered strain rate. More...
| double precision, save | xlesfd |
| | ratio between explicit and explicit filter width for a dynamic model constant used to define, for each cell , the width of the explicit filter used in the framework of the LES dynamic model: . More...
| double precision, save | smagmx |
| | maximum allowed value for the variable appearing in the LES dynamic model. Any larger value yielded by the calculation procedure of the dynamic model will be clipped to . More...
| double precision, save | smagmn |
| | minimum allowed value for the variable appearing in the LES dynamic model. Any smaller value yielded by the calculation procedure of the dynamic model will be clipped to . More...
| double precision, save | cdries |
| | van Driest constant appearing in the van Driest damping function applied to the Smagorinsky constant: More...
| double precision, save | volmin |
| | minimal control volume More...
| double precision, save | volmax |
| | maximal control volume More...
| double precision, save | voltot |
| | total domain volume More...
| double precision, save | cv2fa1 |
| | constant for the v2f -model. Useful if and only if iturb=50 (v2f -model) More...
| double precision, save | cv2fe2 |
| double precision, save | cv2fmu |
| double precision, save | cv2fc1 |
| double precision, save | cv2fc2 |
| double precision, save | cv2fct |
| double precision, save | cv2fcl |
| double precision, save | cv2fet |
| double precision, save | cwale |
| | constant of the WALE LES method More...
| double precision, save | xiafm |
| | coefficient of turbulent AFM flow model More...
| double precision, save | etaafm |
| double precision, save | c1trit |
| | coefficient of turbulent DFM flow model More...
| double precision, save | c2trit |
| double precision, save | c3trit |
| double precision, save | c4trit |
| double precision, save | cthafm |
| | constant of GGDH and AFM on the thermal scalar More...
| double precision, save | cthdfm |
| double precision, save | xclt |
| | constant of EB-AFM and EB-DFM More...
| double precision, save | rhebdfm |
| | constant of EB-DFM More...
| double precision, save | cthebdfm |
