#include "cs_defs.h"#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <assert.h>#include <math.h>#include <mpi.h>#include <ple_locator.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_base.h"#include "cs_coupling.h"#include "cs_gradient.h"#include "cs_gui_util.h"#include "cs_field.h"#include "cs_field_operator.h"#include "cs_flag_check.h"#include "cs_halo.h"#include "cs_math.h"#include "cs_mesh.h"#include "cs_mesh_connect.h"#include "cs_mesh_quantities.h"#include "cs_parall.h"#include "cs_parameters.h"#include "cs_physical_model.h"#include "cs_prototypes.h"#include "cs_post.h"#include "fvm_nodal.h"#include "cs_boundary_conditions.h"
| void | cs_boundary_conditions_error (const int *bc_flag, const char *type_name) |
| Handling of boundary condition definition errors and associated output. More... | |
| ple_locator_t * | cs_boundary_conditions_map (cs_mesh_location_type_t location_type, cs_lnum_t n_location_elts, cs_lnum_t n_faces, const cs_lnum_t *location_elts, const cs_lnum_t *faces, cs_real_3_t *coord_shift, int coord_stride, double tolerance) |
| Locate shifted boundary face coordinates on possibly filtered cells or boundary faces for later interpolation. More... | |
| void | cs_boundary_conditions_mapped_set (const cs_field_t *f, ple_locator_t *locator, cs_mesh_location_type_t location_type, int normalize, int interpolate, cs_lnum_t n_faces, const cs_lnum_t *faces, cs_real_t *balance_w, int nvar, cs_real_t rcodcl[]) |
| Set mapped boundary conditions for a given field and mapping locator. More... | |
| void | cs_boundary_conditions_create (void) |
| void | cs_boundary_conditions_free (void) |
| void | cs_boundary_conditions_set_convective_outlet_scalar (cs_real_t *coefa, cs_real_t *cofaf, cs_real_t *coefb, cs_real_t *cofbf, cs_real_t pimp, cs_real_t cfl, cs_real_t hint) |
| Set convective oulet boundary condition for a scalar. More... | |
Boundary condition handling.
| void cs_boundary_conditions_create | ( | void | ) |
| void cs_boundary_conditions_error | ( | const int * | bc_flag, |
| const char * | type_name | ||
This function checks for errors, and simply returns if no errors are encountered. In case of error, it outputs helpful information so as to make it easier to locate the matching faces.
| [in] | bc_flag | array of BC type ids |
| [in] | type_name | name of attribute in error, or NULL |
| void cs_boundary_conditions_free | ( | void | ) |
| ple_locator_t* cs_boundary_conditions_map | ( | cs_mesh_location_type_t | location_type, |
| cs_lnum_t | n_location_elts, | ||
| cs_lnum_t | n_faces, | ||
| const cs_lnum_t * | location_elts, | ||
| const cs_lnum_t * | faces, | ||
| cs_real_3_t * | coord_shift, | ||
| int | coord_stride, | ||
| double | tolerance | ||
| [in] | location_type | matching values location (CS_MESH_LOCATION_CELLS or CS_MESH_LOCATION_BOUNDARY_FACES) |
| [in] | n_location_elts | number of selected location elements |
| [in] | n_faces | number of selected boundary faces |
| [in] | location_elts | list of selected location elements (0 to n-1), or NULL if no indirection is needed |
| [in] | faces | list of selected boundary faces (0 to n-1), or NULL if no indirection is needed |
| [in] | coord_shift | array of coordinates shift relative to selected boundary faces |
| [in] | coord_stride | access stride in coord_shift: 0 for uniform shift, 1 for "per face" shift. |
| [in] | tolerance | relative tolerance for point location. |
| void cs_boundary_conditions_mapped_set | ( | const cs_field_t * | f, |
| ple_locator_t * | locator, | ||
| cs_mesh_location_type_t | location_type, | ||
| int | normalize, | ||
| int | interpolate, | ||
| cs_real_t * | balance_w, | ||
| int | nvar, | ||
| cs_real_t | rcodcl[] | ||
| [in] | f | field whose boundary conditions are set |
| [in] | locator | associated mapping locator, as returned by cs_boundary_conditions_map. |
| [in] | normalize | normalization option: 0: values are simply mapped 1: values are mapped, then multiplied by a constant factor so that their surface integral on selected faces is preserved (relative to the input values) 2: as 1, but with a boundary-defined weight, defined by balance_w 3: as 1, but with a cell-defined weight, defined by balance_w |
| [in] | interpolate | interpolation option: 0: values are simply based on matching cell or face center values 1: values are based on matching cell or face center values, corrected by gradient interpolation |
| [in] | balance_w | optional balance weight, or NULL |
| [in] | nvar | number of variables requiring BC's |
| [in,out] | rcodcl | boundary condition values |
| void cs_boundary_conditions_set_convective_outlet_scalar | ( | cs_real_t * | coefa, |
| cs_real_t * | cofaf, | ||
| cs_real_t * | coefb, | ||
| cs_real_t * | cofbf, | ||
| cs_real_t | pimp, | ||
| cs_real_t | cfl, | ||
| cs_real_t | hint | ||
Parameters:
| [out] | coefa | explicit BC coefficient for gradients |
| [out] | cofaf | explicit BC coefficient for diffusive flux |
| [out] | coefb | implicit BC coefficient for gradients |
| [out] | cofbf | implicit BC coefficient for diffusive flux |
| [in] | pimp | Flux value to impose |
| [in] | cfl | Local Courant number used to convect |
| [in] | hint | Internal exchange coefficient |
