1 #ifndef __CS_MESH_QUANTITIES_H__ 2 #define __CS_MESH_QUANTITIES_H__ 57 #define CS_BAD_CELLS_WARPED_CORRECTION (1 << 0) 60 #define CS_BAD_CELLS_REGULARISATION (1 << 1) 63 #define CS_CELL_FACE_CENTER_CORRECTION (1 << 2) 66 #define CS_CELL_CENTER_CORRECTION (1 << 3) 69 #define CS_FACE_DISTANCE_CLIP (1 << 4) 72 #define CS_FACE_RECONSTRUCTION_CLIP (1 << 5) 75 #define CS_CELL_VOLUME_RATIO_CORRECTION (1 << 6) 80 #define CS_FACE_CENTER_REFINE (1 << 7) void cs_mesh_quantities_check_vol(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, int allow_error)
Definition: cs_mesh_quantities.c:3735
cs_real_33_t * cocgb_s_lsq
Definition: cs_mesh_quantities.h:141
void cs_mesh_quantities_reduce_extended(const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
Definition: cs_mesh_quantities.c:3787
void cs_mesh_quantities_dump(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities)
Definition: cs_mesh_quantities.c:3997
cs_real_t cs_real_2_t[2]
Definition: cs_defs.h:314
cs_real_t * b_dist
Definition: cs_mesh_quantities.h:124
void cs_mesh_quantities_b_thickness_v(const cs_mesh_t *m, const cs_mesh_quantities_t *mq, int n_passes, cs_real_t b_thickness[])
Determine local boundary thickness around each vertex.
Definition: cs_mesh_quantities.c:3820
cs_real_t * corr_grad_lin_det
Definition: cs_mesh_quantities.h:149
cs_real_t * cell_f_vol
Definition: cs_mesh_quantities.h:94
cs_real_t * b_face_surf
Definition: cs_mesh_quantities.h:108
cs_real_t * cs_mesh_quantities_cell_volume(const cs_mesh_t *mesh)
Definition: cs_mesh_quantities.c:3694
cs_real_t * djjpf
Definition: cs_mesh_quantities.h:120
void cs_mesh_quantities_compute_preprocess(const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
Compute mesh quantities needed for preprocessing.
Definition: cs_mesh_quantities.c:2867
cs_real_t min_f_vol
Definition: cs_mesh_quantities.h:133
cs_int_t * c_solid_flag
Definition: cs_mesh_quantities.h:155
Definition: cs_internal_coupling.h:62
cs_real_t max_f_vol
Definition: cs_mesh_quantities.h:134
Definition: cs_defs.h:467
int cs_int_t
Fortran-compatible integer.
Definition: cs_defs.h:301
void cs_compute_cell_cocg_it_coupling(const cs_mesh_t *m, cs_mesh_quantities_t *fvq, cs_internal_coupling_t *ce)
Definition: cs_mesh_quantities.c:4112
cs_real_33_t * corr_grad_lin
Definition: cs_mesh_quantities.h:151
cs_mesh_quantities_t * cs_mesh_quantities_destroy(cs_mesh_quantities_t *mesh_quantities)
Destroy a mesh quantities structure.
Definition: cs_mesh_quantities.c:2797
int cs_mesh_quantities_face_cog_choice(int algo_choice)
Query or modification of the option for computing face centers.
Definition: cs_mesh_quantities.c:2658
cs_real_t * diipf
Definition: cs_mesh_quantities.h:119
cs_real_t * dofij
Definition: cs_mesh_quantities.h:118
cs_real_t * b_face_cog
Definition: cs_mesh_quantities.h:105
Definition: cs_defs.h:302
void cs_mesh_quantities_face_normal(const cs_mesh_t *mesh, cs_real_t *p_i_face_normal[], cs_real_t *p_b_face_normal[])
Definition: cs_mesh_quantities.c:3443
cs_real_t max_vol
Definition: cs_mesh_quantities.h:130
unsigned * bad_cell_flag
Definition: cs_mesh_quantities.h:156
void cs_mesh_quantities_free_all(cs_mesh_quantities_t *mq)
Reset a mesh quantities structure to its empty initial state.
Definition: cs_mesh_quantities.c:2815
cs_real_33_t * cocg_s_it
Definition: cs_mesh_quantities.h:139
cs_real_t * i_f_face_normal
Definition: cs_mesh_quantities.h:100
void cs_mesh_init_fluid_sections(const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
Definition: cs_mesh_quantities.c:3362
void cs_mesh_quantities_fluid_vol_reductions(const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
Definition: cs_mesh_quantities.c:3322
int cs_mesh_quantities_cell_cen_choice(int algo_choice)
Query or modification of the option for computing cell centers.
Definition: cs_mesh_quantities.c:2636
cs_real_t tot_vol
Definition: cs_mesh_quantities.h:131
cs_real_t tot_f_vol
Definition: cs_mesh_quantities.h:135
void cs_mesh_quantities_set_cocg_options(int gradient_option)
Definition: cs_mesh_quantities.c:2674
cs_real_t * dijpf
Definition: cs_mesh_quantities.h:116
void cs_mesh_quantities_b_faces(const cs_mesh_t *mesh, cs_real_t *p_b_face_cog[], cs_real_t *p_b_face_normal[])
Definition: cs_mesh_quantities.c:3523
cs_real_t * cell_cen
cs_real_t * i_dist
Definition: cs_mesh_quantities.h:122
cs_real_t * i_face_normal
Definition: cs_mesh_quantities.h:96
Definition: cs_mesh_quantities.h:90
cs_real_2_t * i_f_face_factor
Definition: cs_mesh_quantities.h:113
cs_real_33_t * cocgb_s_it
Definition: cs_mesh_quantities.h:137
cs_mesh_quantities_t * cs_mesh_quantities_create(void)
Create a mesh quantities structure.
Definition: cs_mesh_quantities.c:2743
void comcoc(const cs_int_t *const imrgra)
Definition: cs_mesh_quantities.c:2576
unsigned cs_glob_mesh_quantities_flag
void cs_mesh_quantities_log_setup(void)
Log mesh quantities options to setup file.
Definition: cs_mesh_quantities.c:3952
cs_real_t * b_f_face_surf
Definition: cs_mesh_quantities.h:111
cs_real_t * weight
Definition: cs_mesh_quantities.h:127
cs_real_t * b_f_face_factor
Definition: cs_mesh_quantities.h:114
cs_real_t min_vol
Definition: cs_mesh_quantities.h:129
Definition: cs_defs.h:468
cs_real_33_t * cocg_it
Definition: cs_mesh_quantities.h:144
void cs_mesh_quantities_cell_faces_cog(const cs_mesh_t *mesh, const cs_real_t i_face_norm[], const cs_real_t i_face_cog[], const cs_real_t b_face_norm[], const cs_real_t b_face_cog[], cs_real_t cell_cen[])
Compute approximate cells centers as the mean of the given face centers weighted by the associated su...
Definition: cs_mesh_quantities.c:3566
cs_real_t * i_f_face_surf
Definition: cs_mesh_quantities.h:110
void cs_compute_cell_cocg_lsq_coupling(const cs_mesh_t *m, cs_mesh_quantities_t *fvq, cs_internal_coupling_t *ce)
Definition: cs_mesh_quantities.c:4094
#define CS_PROCF(x, y)
Definition: cs_defs.h:481
void cs_mesh_quantities_fluid_compute(const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
Definition: cs_mesh_quantities.c:3306
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:321
cs_real_t * b_face_normal
Definition: cs_mesh_quantities.h:98
cs_real_t * diipb
Definition: cs_mesh_quantities.h:117
cs_real_t * cell_vol
Definition: cs_mesh_quantities.h:93
void cs_mesh_quantities_b_thickness_f(const cs_mesh_t *m, const cs_mesh_quantities_t *mq, int n_passes, cs_real_t b_thickness[])
Determine local boundary thickness around each boundary face.
Definition: cs_mesh_quantities.c:3910
void cs_mesh_quantities_compute(const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
Compute mesh quantities.
Definition: cs_mesh_quantities.c:3101
void cs_mesh_quantities_sup_vectors(const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
Definition: cs_mesh_quantities.c:3408
cs_real_t * i_face_surf
Definition: cs_mesh_quantities.h:107
int cs_mesh_quantities_compute_count(void)
Definition: cs_mesh_quantities.c:3802
cs_real_t * i_face_cog
Definition: cs_mesh_quantities.h:104
cs_int_t * b_sym_flag
Definition: cs_mesh_quantities.h:154
integer(c_int), pointer, save imrgra
type of gradient reconstruction
Definition: optcal.f90:286
cs_real_33_t * cocg_lsq
Definition: cs_mesh_quantities.h:146
cs_real_t * b_f_face_normal
Definition: cs_mesh_quantities.h:102
void cs_mesh_quantities_set_porous_model(int porous_model)
Definition: cs_mesh_quantities.c:2729
void cs_mesh_quantities_i_faces(const cs_mesh_t *mesh, cs_real_t *p_i_face_cog[], cs_real_t *p_i_face_normal[])
Definition: cs_mesh_quantities.c:3490
