1 #ifndef __CS_GRADIENT_H__ 2 #define __CS_GRADIENT_H__ Definition: cs_gradient.h:56
#define restrict
Definition: cs_defs.h:127
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:317
void cs_gradient_finalize(void)
Finalize gradient computation API.
Definition: cs_gradient.c:7361
cs_real_t cs_real_66_t[6][6]
6x6 matrix of floating-point values
Definition: cs_defs.h:322
void cs_gradient_type_by_imrgra(int imrgra, cs_gradient_type_t *gradient_type, cs_halo_type_t *halo_type)
Definition: cs_gradient.c:7995
Definition: cs_internal_coupling.h:62
Definition: cs_defs.h:467
int cs_int_t
Fortran-compatible integer.
Definition: cs_defs.h:301
void cs_gradient_scalar_synced_input(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, bool recompute_cocg, int n_r_sweeps, int tr_dim, int hyd_p_flag, int w_stride, int verbosity, int clip_mode, double epsilon, double extrap, double clip_coeff, cs_real_t f_ext[][3], const cs_real_t bc_coeff_a[], const cs_real_t bc_coeff_b[], const cs_real_t var[restrict], const cs_real_t c_weight[restrict], const cs_internal_coupling_t *cpl, cs_real_t grad[restrict][3])
Compute cell gradient of scalar field or component of vector or tensor field.
Definition: cs_gradient.c:7743
Definition: cs_gradient.h:60
void cgdts(const cs_int_t *const f_id, const cs_int_t *const imrgra, const cs_int_t *const inc, const cs_int_t *const n_r_sweeps, const cs_int_t *const iwarnp, const cs_int_t *const imligp, const cs_real_t *const epsrgp, const cs_real_t *const climgp, const cs_real_6_t coefav[], const cs_real_66_t coefbv[], cs_real_6_t pvar[], cs_real_63_t grad[])
Definition: cs_gradient.c:7281
Definition: cs_defs.h:302
void cs_gradient_scalar(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, bool recompute_cocg, int n_r_sweeps, int tr_dim, int hyd_p_flag, int w_stride, int verbosity, int clip_mode, double epsilon, double extrap, double clip_coeff, cs_real_3_t f_ext[], const cs_real_t bc_coeff_a[], const cs_real_t bc_coeff_b[], cs_real_t *restrict var, cs_real_t *restrict c_weight, cs_internal_coupling_t *cpl, cs_real_3_t *restrict grad)
Definition: cs_gradient.c:7420
void cs_gradient_vector(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, int clip_mode, double epsilon, double clip_coeff, const cs_real_3_t bc_coeff_a[], const cs_real_33_t bc_coeff_b[], cs_real_3_t *restrict var, cs_real_t *restrict c_weight, cs_internal_coupling_t *cpl, cs_real_33_t *restrict gradv)
Compute cell gradient of vector field.
Definition: cs_gradient.c:7542
void cs_gradient_vector_synced_input(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, int clip_mode, double epsilon, double clip_coeff, const cs_real_t bc_coeff_a[][3], const cs_real_t bc_coeff_b[][3][3], const cs_real_t var[restrict][3], const cs_real_t c_weight[restrict], const cs_internal_coupling_t *cpl, cs_real_33_t *restrict gradv)
Definition: cs_gradient.c:7851
cs_halo_type_t
Definition: cs_halo.h:50
void grdpor(const cs_int_t *const inc)
Definition: cs_gradient.c:6948
Definition: cs_gradient.h:58
cs_gradient_type_t
Definition: cs_gradient.h:54
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:315
Definition: cs_defs.h:468
void cgdvec(const cs_int_t *const f_id, const cs_int_t *const imrgra, const cs_int_t *const inc, const cs_int_t *const n_r_sweeps, const cs_int_t *const iwarnp, const cs_int_t *const imligp, const cs_real_t *const epsrgp, const cs_real_t *const climgp, const cs_real_3_t coefav[], const cs_real_33_t coefbv[], cs_real_3_t pvar[], cs_real_33_t gradv[])
Definition: cs_gradient.c:7215
void cgdcel(const cs_int_t *const f_id, const cs_int_t *const imrgra, const cs_int_t *const inc, const cs_int_t *const iccocg, const cs_int_t *const n_r_sweeps, const cs_int_t *const idimtr, const cs_int_t *const iphydp, const cs_int_t *const ipond, const cs_int_t *const iwarnp, const cs_int_t *const imligp, const cs_real_t *const epsrgp, const cs_real_t *const extrap, const cs_real_t *const climgp, cs_real_3_t f_ext[], const cs_real_t coefap[], const cs_real_t coefbp[], cs_real_t pvar[], cs_real_t ktvar[], cs_real_3_t grad[])
Definition: cs_gradient.c:7126
Definition: cs_gradient.h:57
#define CS_PROCF(x, y)
Definition: cs_defs.h:481
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:321
void cs_gradient_tensor(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, int clip_mode, double epsilon, double clip_coeff, const cs_real_6_t bc_coeff_a[], const cs_real_66_t bc_coeff_b[], cs_real_6_t *restrict var, cs_real_63_t *restrict grad)
Compute cell gradient of tensor.
Definition: cs_gradient.c:7639
cs_real_t cs_real_63_t[6][3]
Definition: cs_defs.h:327
const char * cs_gradient_type_name[]
void cs_gradient_tensor_synced_input(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, int clip_mode, double epsilon, double clip_coeff, const cs_real_t bc_coeff_a[][6], const cs_real_t bc_coeff_b[][6][6], const cs_real_t var[restrict][6], cs_real_63_t *restrict grad)
Definition: cs_gradient.c:7931
void cs_gradient_initialize(void)
Initialize gradient computation API.
Definition: cs_gradient.c:7340
integer(c_int), pointer, save imrgra
type of gradient reconstruction
Definition: optcal.f90:286
