Here is a list of all variables with links to the structures/unions they belong to:
- c -
- c1 : cs_coal_model_t
- c2 : cs_coal_model_t
- c2e : cs_cdo_connect_t
- c2f : cs_cdo_connect_t, cs_mesh_adjacencies_t
- c2v : cs_cdo_connect_t, cs_mesh_adjacencies_t
- c_bulk : cs_solidification_binary_alloy_t
- c_disable_flag : cs_mesh_quantities_t
- c_domain_rank : cs_halo_t
- c_eut : cs_solidification_binary_alloy_t
- c_id : cs_cell_mesh_t, cs_cell_sys_t, cs_face_mesh_light_t, cs_face_mesh_t, cs_macfb_builder_t
- c_l_cells : cs_solidification_binary_alloy_t
- c_l_faces : cs_solidification_binary_alloy_t
- c_pressure : cs_gwf_tpf_t
- c_tag : cs_internal_coupling_t
- c_w_dist_inv : cs_mesh_quantities_t
- c_w_face_cog : cs_mesh_quantities_t
- c_w_face_normal : cs_mesh_quantities_t
- c_w_face_surf : cs_mesh_quantities_t
- capacity_field : cs_gwf_uspf_t
- case_name : cs_domain_t
- category : cs_boundary_t
- cb_scheme_flag : cs_domain_cdo_context_t
- cch : cs_coal_model_t
- cck : cs_coal_model_t
- cdest : cs_cavitation_parameters_t
- cdo_context : cs_domain_t
- cdo_quantities : cs_domain_t
- cdrift : cs_vof_parameters_t
- cebu : cs_combustion_gas_model_t
- cell_b_faces : cs_mesh_adjacencies_t
- cell_b_faces_idx : cs_mesh_adjacencies_t
- cell_basis : cs_hho_builder_t
- cell_bi : cs_mesh_builder_t
- cell_cells : cs_mesh_adjacencies_t
- cell_cells_e : cs_mesh_adjacencies_t
- cell_cells_e_idx : cs_mesh_adjacencies_t
- cell_cells_idx : cs_mesh_adjacencies_t, cs_mesh_t
- cell_cells_lst : cs_mesh_t
- cell_cen : cs_mesh_quantities_t
- cell_centers : cs_cdo_quantities_t
- cell_connect : cs_interpol_grid_t
- cell_family : cs_mesh_t
- cell_field_id : cs_adv_field_t
- cell_flag : cs_cdo_connect_t, cs_cell_builder_t
- cell_gc_id : cs_mesh_builder_t
- cell_hb_faces : cs_mesh_adjacencies_t
- cell_hb_faces_idx : cs_mesh_adjacencies_t
- cell_i_faces : cs_mesh_adjacencies_t
- cell_i_faces_sgn : cs_mesh_adjacencies_t
- cell_ids : cs_solid_selection_t, cs_volume_zone_t
- cell_info : cs_cdo_quantities_t
- cell_is_solid : cs_solid_selection_t
- cell_numbering : cs_mesh_t
- cell_rank : cs_mesh_builder_t
- cell_s_cen : cs_mesh_quantities_t
- cell_state : cs_solidification_t
- cell_type : cs_cdo_connect_t
- cell_values : cs_cdovb_vecteq_t
- cell_vol : cs_cdo_quantities_t, cs_mesh_quantities_t
- cell_weight : cs_gwf_tpf_t
- cells_criteria : cs_internal_coupling_t
- center : cs_basis_func_t, cs_quant_t
- cfd_root : cs_sys_cpl_t
- cfd_weight : cs_cfd2sys_intersection_t
- cflmmx : cs_time_step_options_t
- cflp : cs_thermal_model_t
- cflt : cs_thermal_model_t
- chain_id : cs_gwf_tracer_t
- chain_position_id : cs_gwf_tracer_t
- chem_conc_file_name : cs_atmo_chemistry_t
- chemistry_sep_mode : cs_atmo_chemistry_t
- chemistry_with_photolysis : cs_atmo_chemistry_t
- chempoint : cs_atmo_chemistry_t
- chi2 : cs_coal_model_t
- children : cs_tree_node_t
- chx1 : cs_coal_model_t
- chx2 : cs_coal_model_t
- ci_cj_vect : cs_internal_coupling_t
- cip_scaling_coef : cs_equation_param_t
- circulation_ids : cs_cdo_bc_face_t
- ck_bulk : cs_solidification_binary_alloy_t
- ckabs : cs_combustion_gas_model_t
- ckabs0 : cs_coal_model_t
- ckabsg : cs_combustion_gas_model_t
- class_defs : cs_mesh_t
- clatev : cs_fluid_properties_t
- climgr : var_cal_opt, cs_equation_param_t
- cliq_minus_cbulk : cs_solidification_binary_alloy_t
- clogging : cs_lagr_model_t
- cloud_type : cs_atmo_option_t
- cluster : cs_lagr_injection_set_t
- cmu : cs_lagr_extra_module_t
- coal_number : cs_lagr_injection_set_t
- coarse_max_iter : cs_param_amg_inhouse_t
- coarse_poly_degree : cs_param_amg_inhouse_t
- coarse_rtol_mult : cs_param_amg_inhouse_t
- coarse_solver : cs_param_amg_boomer_t, cs_param_amg_gamg_t, cs_param_amg_hmg_t, cs_param_amg_inhouse_t
- coarsen_algo : cs_param_amg_boomer_t, cs_param_amg_inhouse_t
- coef : cs_hodge_param_t
- coefeg : cs_combustion_gas_model_t
- coeff1 : cs_libby_williams_params_t
- coeff2 : cs_libby_williams_params_t
- coeff3 : cs_libby_williams_params_t
- coeff_therm : cs_combustion_gas_model_t
- coejou : cs_elec_option_t
- cog : cs_zone_t
- cog_location : cs_porosity_from_scan_opt_t
- col_block_sizes : cs_cdo_system_helper_t
- col_g_id : cs_cdo_assembly_row_t
- col_id : cs_matrix_row_info_t
- col_idx : cs_cdo_assembly_row_t
- comp_ids : cs_measures_set_t
- compog : cs_combustion_gas_model_t
- compute : cs_turbulence_t, cs_navsto_system_t
- compute_balance : cs_equation_t
- compute_diff_hodge : cs_cdocb_scaleq_t
- compute_factorization : cs_basis_func_t
- compute_porosity_from_scan : cs_porosity_from_scan_opt_t
- compute_projector : cs_basis_func_t
- compute_source : cs_equation_builder_t
- compute_steady : cs_turbulence_t, cs_navsto_system_t
- compute_z_ground : cs_atmo_option_t
- conc_l_star : cs_gwf_tracer_default_context_t
- conc_profiles : cs_atmo_chemistry_t
- conc_site2 : cs_gwf_tracer_default_context_t
- condition : cs_gui_boundary_meg_context_t
- connect : cs_domain_t
- connectivity_size : fvm_nodal_section_t
- consolidation : cs_lagr_model_t
- constant_value : cs_meg_xdef_input_t
- context : cs_turbulence_t, cs_gwf_tracer_t, cs_equation_system_t, cs_iter_algo_t, cs_param_saddle_t, cs_saddle_solver_t, cs_xdef_t
- context_param : cs_param_sles_t
- continues_previous : fvm_writer_section_t
- control_func : cs_time_control_t
- control_input : cs_time_control_t
- conv_factor_jac : cs_atmo_chemistry_t
- convection_porosity_threshold : cs_porosity_from_scan_opt_t
- convij : cs_les_balance_rij_t
- convti : cs_les_balance_tui_t
- convvar : cs_les_balance_tui_t
- coord_shift : cs_mesh_extrude_vectors_t
- coords : cs_interpol_grid_t, cs_measures_set_t, cs_stl_mesh_t
- coords_ini : cs_stl_mesh_t
- corr_grad_lin : cs_mesh_quantities_t
- corr_grad_lin_det : cs_mesh_quantities_t
- correction : cs_navsto_projection_t
- couimp : cs_elec_option_t
- coumax : cs_time_step_options_t
- count : cs_lagr_attribute_map_t, cs_lagr_event_attribute_map_t
- coupled_faces : cs_internal_coupling_t
- coupling : cs_navsto_param_t
- coupling_context : cs_navsto_system_t
- coyfp : cs_combustion_gas_model_t
- cp : cs_gas_mix_species_prop_t, cs_lagr_injection_set_t, cs_solidification_t, cs_thermal_system_t
- cp0 : cs_fluid_properties_t
- cp2ch : cs_coal_model_t
- cp_a : cs_air_fluid_props_t
- cp_gas_g : cs_combustion_gas_model_t
- cp_l : cs_air_fluid_props_t
- cp_v : cs_air_fluid_props_t
- cpashc : cs_coal_model_t
- cpel : cs_data_elec_t
- cplbc : cs_sys_cpl_t
- cppart : cs_lagr_specific_physics_t
- cpro_cp : cs_lagr_extra_module_t
- cpro_viscls : cs_lagr_extra_module_t
- cprod : cs_cavitation_parameters_t
- cpv0 : cs_fluid_properties_t
- crepn1 : cs_coal_model_t
- crepn2 : cs_coal_model_t
- cressman_eps : cs_atmo_imbrication_t
- cressman_nc : cs_atmo_imbrication_t
- cressman_qw : cs_atmo_imbrication_t
- cressman_theta : cs_atmo_imbrication_t
- cressman_tke : cs_atmo_imbrication_t
- cressman_u : cs_atmo_imbrication_t
- cressman_v : cs_atmo_imbrication_t
- crit_reca : cs_elec_option_t
- criteria : cs_ctwr_zone_t
- cromf : cs_lagr_extra_module_t
- cs1 : cs_solidification_binary_alloy_t
- cs_used : cs_lagr_model_t
- cstham : cs_lagr_clogging_param_t, cs_lagr_dlvo_param_t, cs_lagr_physico_chemical_t, cs_lagr_roughness_param_t
- csthpp : cs_lagr_clogging_model_t, cs_lagr_clogging_param_t, cs_lagr_dlvo_param_t
- curlcurl_hodge : cs_cdoeb_vecteq_t
- curlcurl_hodgep : cs_equation_param_t
- curlcurl_property : cs_equation_param_t
- curlcurl_pty_uniform : cs_equation_builder_t
- current_state : cs_time_control_t
- current_time_step : cs_time_control_t
- current_to_previous : cs_equation_t
- cutcell_func : cs_ibm_object_t
- cv : cs_stiffened_gas_t
- cv0 : cs_fluid_properties_t
- cvar_ep : cs_lagr_extra_module_t
- cvar_gradk : cs_lagr_extra_module_t
- cvar_gradrij : cs_lagr_extra_module_t
- cvar_k : cs_lagr_extra_module_t
- cvar_omg : cs_lagr_extra_module_t
- cvar_rij : cs_lagr_extra_module_t
- cvg_param : cs_iter_algo_t, cs_param_saddle_t, cs_param_sles_t
- cvg_status : cs_iter_algo_aac_t, cs_iter_algo_default_t
- cvl : cs_fluid_properties_t
- cx_bulk : cs_solidification_binary_alloy_t
