cs_navsto_projection_t Struct Reference
Set of parameters specific for solving the Navier-Stokes system with an incremental projection algorithm. More...
#include <cs_navsto_coupling.h>
Collaboration diagram for cs_navsto_projection_t:
Data Fields
cs_equation_tprediction
cs_equation_tcorrection
cs_real_tdiv_st
cs_real_tbdy_pressure_incr
cs_field_tpredicted_velocity
cs_field_tphi
cs_field_tpressure_incr_gradient
All equations are not always created. It depends on the choice of the model
Field Documentation
◆ bdy_pressure_incr
cs_real_t* bdy_pressure_incr
Pressure increment at the boundary. Used as an array to set the boundary condition arising from a Dirichlet on the pressure.
◆ correction
cs_equation_t* correction
Pressure correction step related to the mass balance equation (scalar-valued)
◆ div_st
cs_real_t* div_st
Source term on the correction step stemming from the divergence of the predicted velocity
◆ phi
cs_field_t* phi
◆ predicted_velocity
cs_field_t* predicted_velocity
Predicted velocity field (value of the velocity at cells after the prediction step). This values may not be divergence-free.
◆ prediction
cs_equation_t* prediction
Velocity prediction step related to the momentum balance equation (vector-valued)
◆ pressure_incr_gradient
cs_field_t* pressure_incr_gradient
Gradient of pressure increment. Used to store the gradient pressure increment. Only available with verbosity > 1.
