Structure to handle the convergence of an iterative algorithm. More...
#include <cs_iter_algo.h>
Data Fields | |
cs_iter_algo_type_t | type |
cs_param_convergence_t | cvg_param |
int | verbosity |
void * | context |
Metadata to manage an iterative algorithm such as Picard or Uzawa for instance. This structure can handle a two-level (i.e. outer/inner) iterative algorithm since the notion of inner and outer iterations is defined. Nevertheless, only the outer iterative algorithm is managed (information about inner iterations are only for monitoring purposes).
void* context |
pointer to structure cast on the fly
cs_param_convergence_t cvg_param |
structure storing the main settings
cs_iter_algo_type_t type |
Type of iterative algorithm to consider. Useful to cast on-the-fly the context structure
int verbosity |
Level of printed information
