#include "base/cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <math.h>#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "base/cs_array.h"#include "base/cs_assert.h"#include "base/cs_field.h"#include "base/cs_field_pointer.h"#include "alge/cs_gradient.h"#include "base/cs_log.h"#include "base/cs_math.h"#include "base/cs_mem.h"#include "mesh/cs_mesh.h"#include "base/cs_parall.h"#include "mesh/cs_mesh_location.h"#include "turb/cs_turbulence_ke.h"#include "turb/cs_turbulence_model.h"#include "turb/cs_turbulence_rij.h"#include "turb/cs_turbulence_init.h"#include "base/cs_log_iteration.h"Functions | |
| void | cs_turbulence_init_by_ref_quantities (void) |
| First pass at initialization of turbulence variables. | |
| int | cs_turbulence_init_clip_and_verify (void) |
| Clipping of turbulence variables initialization. | |
Turbulence variables initialization for various models.
| void cs_turbulence_init_by_ref_quantities | ( | void | ) |
If the reference velocity is negative (incorrect or not initialized), values of k, Rij, epsilon, and omega are set to -10*cs_math_big_r. We will later test if those values were modified by user initialization or reading a restart file.
| int cs_turbulence_init_clip_and_verify | ( | void | ) |
If the user has prescribed "correct" values (in the sense that k, eps, Rii, ... > 0), we clip these values if needed for consistency.
If the prescribed values are manifestly incorrect (negative values), we assume this is an error, print warnings, and return a positive error count.
The same logic is applied to computation restarts.
