#include <assert.h>#include <ctype.h>#include <float.h>#include <math.h>#include <stdlib.h>#include <string.h>#include "bft/bft_mem.h"#include "bft/bft_printf.h"#include "base/cs_array.h"#include "base/cs_field.h"#include "gwf/cs_gwf_soil.h"#include "cdo/cs_hodge.h"#include "base/cs_log.h"#include "base/cs_math.h"#include "mesh/cs_mesh_location.h"#include "base/cs_parall.h"#include "base/cs_post.h"#include "cdo/cs_reco.h"#include "alge/cs_sles_it.h"#include "gwf/cs_gwf_tracer.h"Macros | |
| #define | CS_GWF_TRACER_DBG 0 |
| static void | _get_time_pty4std_sat_tracer (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t t_eval, void *context, cs_real_t *result) |
| Define the coefficient appearing in time-dependent term of the simulation of tracer equations. Case of a fully saturated model. This function fits the generic prototype of cs_xdef_eval_t. | |
| static void | _get_time_pty4std_sat_tracer_cw (const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_real_t *result) |
| Define the coefficient appearing in time-dependent term of the simulation of tracer equations. Case of a fully saturated model. This function fits the generic prototype of cs_xdef_cell_eval_cw_t. | |
| static void | _get_time_pty4std_tracer (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t t_eval, void *context, cs_real_t *result) |
| Define the coefficient appearing in time-dependent term of the simulation of tracer equations This function fits the generic prototype of cs_xdef_eval_t. | |
| static void | _get_time_pty4std_tracer_cw (const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_real_t *result) |
| Define the coefficient appearing in time-dependent term of the simulation of tracer equations This function fits the generic prototype of cs_xdef_cell_eval_cw_t. | |
| static void | _get_reaction_pty4std_sat_tracer (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t t_eval, void *context, cs_real_t *result) |
| Define the coefficient appearing in the reaction term for the simulation of standard tracer equations. Case of a fully saturated model This function fits the generic prototype of cs_xdef_cell_eval_t. | |
| static void | _get_reaction_pty4std_sat_tracer_cw (const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_real_t *result) |
| Define the coefficient appearing in the reaction term for the simulation of standard tracer equations. Case of a fully saturated model. This function fits the generic prototype of cs_xdef_cell_eval_cw_t. | |
| static void | _get_reaction_pty4std_tracer (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t t_eval, void *context, cs_real_t *result) |
| Define the coefficient appearing in the reaction term for the simulation of standard tracer equations. This function fits the generic prototype of cs_xdef_cell_eval_t. | |
| static void | _get_reaction_pty4std_tracer_cw (const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_real_t *result) |
| Define the coefficient appearing in the reaction term for the simulation of standard tracer equations. This function fits the generic prototype of cs_xdef_cell_eval_cw_t. | |
| static void | _update_diff_value (cs_gwf_tracer_t *tracer, void *context, const cs_time_step_t *ts, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| Update the diffusion property for a (non-user) tracer model. Only the diffusivity is updated (reaction property and time property are defined and updated thanks to a function). Case of a diffusity defined by a value. Generic function relying on the prototype cs_gwf_tracer_update_t. | |
| static void | _update_diff_tensor (cs_gwf_tracer_t *tracer, void *context, const cs_time_step_t *ts, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| Update physical properties for a (non-user) tracer model. Only the diffusivity is updated (reaction property and time property are defined by function). Case of an unsaturated model and diffusity defined by a tensor. Generic function relying on the prototype cs_gwf_tracer_update_t. | |
| static void | _update_precipitation_vb (cs_gwf_tracer_t *tracer, void *context, const cs_time_step_t *ts, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| Update physical properties for a non-user tracer model. Case of a tracer with the precipitation/dissolution modelling and a vertex-based scheme. Generic function relying on the prototype cs_gwf_tracer_update_t. | |
| static void | _add_precipitation (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_gwf_tracer_t *tracer) |
| Add and initialize quantities related to the precipitation model. | |
| static void | _integrate_sat_precip_tracer (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_equation_t *eq, const cs_zone_t *z, void *context, double results[]) |
| Compute the integral of the molar concentration of a tracer field over a given set of cells. This integral turns out to be exact for linear functions. A parallel operation (a sum reduction) is performed inside this function. Case of a fully saturated hydraulic model with precipitation effects. | |
| static void | _integrate_sat_tracer (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_equation_t *eq, const cs_zone_t *z, void *context, double results[]) |
| Compute the integral of the molar concentration of a tracer field over a given set of cells. This integral turns out to be exact for linear functions. Case of a fully saturated hydraulic model. Parallel synchronized is done inside this function. | |
| static void | _integrate_tracer (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_equation_t *eq, const cs_zone_t *z, void *context, double results[]) |
| Compute the integral of the molar concentration of a tracer field over a given set of cells. This integral turns out to be exact for linear functions. Case of a single-phase unsaturated hydraulic model without precipitation. Parallel synchronized is done inside this function. | |
| static void | _integrate_precip_tracer (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_equation_t *eq, const cs_zone_t *z, void *context, double results[]) |
| Compute the integral of the molar concentration of a tracer field over a given set of cells. This integral turns out to be exact for linear functions. Case of a single-phase unsaturated hydraulic model with precipitation. Parallel synchronized is done inside this function. | |
| static void | _free_default_tracer_context (cs_gwf_tracer_t *tracer) |
| Free the context related to a standard tracer equation Rely on the generic prototype cs_gwf_tracer_free_context_t. | |
| static void | _create_default_tracer_context (cs_gwf_tracer_t *tracer, double lambda) |
| Create and initialize the context by default for a "standard" tracer. | |
| static cs_gwf_tracer_t * | _create_tracer (cs_gwf_tracer_model_t tr_model, cs_gwf_model_type_t gwf_model, const char *eq_name, const char *var_name, cs_adv_field_t *adv_field) |
| Create a new cs_gwf_tracer_t structure and initialize its members by default. | |
| static void | _vb_sat_decay_chain_molar_st (cs_gwf_tracer_t *tracer, void *context, const cs_time_step_t *ts, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| Update the source term taking into account the decay chain for the current tracer Case of CDO-Vb schemes with saturated soils and mole unit. Generic function relying on the prototype cs_gwf_tracer_update_t. | |
| static void | _vb_decay_chain_molar_st (cs_gwf_tracer_t *tracer, void *context, const cs_time_step_t *ts, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| Update the source term taking into account the decay chain for the current tracer Case of CDO-Vb schemes with unsaturated soils and mole unit. Generic function relying on the prototype cs_gwf_tracer_update_t. | |
| static void | _vb_sat_decay_chain_becqu_st (cs_gwf_tracer_t *tracer, void *context, const cs_time_step_t *ts, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| Update the source term taking into account the decay chain for the current tracer. Case of CDO-Vb schemes with saturated soils and Becquerel unit. Generic function relying on the prototype cs_gwf_tracer_update_t. | |
| static void | _vb_decay_chain_becqu_st (cs_gwf_tracer_t *tracer, void *context, const cs_time_step_t *ts, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| Update the source term taking into account the decay chain for the current tracer. Case of CDO-Vb schemes with unsaturated soils and Becquerel unit. Generic function relying on the prototype cs_gwf_tracer_update_t. | |
| static void | _set_decay_chain_members (cs_gwf_tracer_t *tracer, int chain_id, int chain_position) |
| Set the members related to a tracer belonging to a decay chain. | |
| static void | _log_decay_chains (void) |
| Display the main features related to each tracer. | |
| static void | _free_all_decay_chains (void) |
| Free all decay chain structures used to manage several linked tracers. | |
| cs_gwf_tracer_t * | cs_gwf_tracer_by_name (const char *eq_name) |
| Retrieve the pointer to the cs_gwf_tracer_t structure associated to the name given as parameter. | |
| cs_gwf_tracer_t * | cs_gwf_tracer_add (cs_gwf_tracer_model_t tr_model, cs_gwf_model_type_t gwf_model, const char *eq_name, const char *var_name, cs_adv_field_t *adv_field, double lambda, int chain_position, int chain_id, cs_gwf_tracer_init_setup_t *init_setup, cs_gwf_tracer_finalize_setup_t *finalize_setup) |
| Create a new cs_gwf_tracer_t structure and initialize its members. This creation of a new tracer is fully done in the case of a default tracer. Additional settings has to be done in the case of a user-defined tracer. | |
| void | cs_gwf_tracer_free_all (void) |
| Free all tracer structures and all decay chains. | |
| cs_real_t | cs_gwf_tracer_get_time_theta_max (void) |
| Retrieve the max. value of the theta parameter associated to a time scheme. Loop on all tracer equations. | |
| void | cs_gwf_tracer_set_soil_param (cs_gwf_tracer_t *tracer, const char *soil_name, double wmd, double alpha_l, double alpha_t, double distrib_coef) |
| Set the main parameters corresponding to a default modelling of a tracer transport equation for a specified soil. | |
| void | cs_gwf_tracer_set_precip_param (cs_gwf_tracer_t *tracer, const char *soil_name, double conc_l_star) |
| For a specified soil set the parameters corresponding to a precipitation modelling of a tracer transport. | |
| void | cs_gwf_tracer_init_setup (void) |
| Initial setup step for tracer equations. Soils and equation parameters are defined at this stage. Create new cs_field_t structures according to the setting. | |
| void | cs_gwf_tracer_finalize_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| Finalize the tracer setup. | |
| void | cs_gwf_tracer_update_diff_pty (const cs_time_step_t *ts, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant) |
| Update the diffusion property related to each tracer equation The update strategy depends on the soil/tracer features and also on the hydraulic model. | |
| void | cs_gwf_tracer_log_all (void) |
| void | cs_gwf_tracer_compute_steady_all (const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq) |
| Compute the steady-state for all tracer equations. Nothing is done if all equations are unsteady. | |
| void | cs_gwf_tracer_compute_all (const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq) |
| Compute the new (unsteady) state for all tracer equations. Nothing is done if all equations are steady. | |
| void | cs_gwf_tracer_default_init_setup (cs_gwf_tracer_t *tracer) |
| Add terms to the algebraic system related to a tracer equation according to the settings. Case of the default tracer modelling Rely on the generic function: cs_gwf_tracer_add_terms_t. | |
| void | cs_gwf_tracer_sat_finalize_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_adv_field_t *adv, cs_gwf_tracer_t *tracer) |
| Set the parameters related to a standard tracer equation. | |
| void | cs_gwf_tracer_unsat_finalize_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_adv_field_t *adv, cs_gwf_tracer_t *tracer) |
| Set the parameters related to a standard tracer equation in case of an unsaturated flow model. | |
| double | cs_gwf_tracer_integrate (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_gwf_tracer_t *tracer, const char *z_name) |
| Compute the integral of the tracer concentration over a given set of cells. This integral gives the number of moles of tracer inside the related volume. Moreover, it turns out to be exact for linear functions. A parallel operation (a sum reduction) is performed inside this function. | |
| void | cs_gwf_tracer_integrate_by_terms (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_gwf_tracer_t *tracer, const char *z_name, double results[]) |
| Compute the quantity of tracer using the integral of the tracer concentration over a given set of cells. Two terms are computed: one for the quantity of moles inside the liquid phase and another one for the quantity of tracer inside the precipitation state (in moles). A parallel operation (a sum reduction) is performed inside this function. | |
| cs_gwf_tracer_decay_chain_t * | cs_gwf_tracer_create_decay_chain (int n_tracers, const char *chain_name, cs_gwf_tracer_unit_t unit) |
| Create a decay chain structure to manage several linked tracers. | |
| cs_gwf_tracer_decay_chain_t * | cs_gwf_tracer_decay_chain_by_id (int id) |
| Retrieve the decay chain structure associated to the given id If not found, it returns the null pointer. | |
| cs_gwf_tracer_decay_chain_t * | cs_gwf_tracer_decay_chain_by_name (const char *chain_name) |
| Retrieve the decay chain structure associated to the name given as parameter. If not found, it returns the null pointer. | |
| cs_gwf_tracer_t * | cs_gwf_tracer_decay_chain_get_tracer (cs_gwf_tracer_decay_chain_t *tdc, int id) |
| Retrieve the tracer structure for the tracer at the position "id" in the decay chain structure. If "id" is not valid, then a nullptr pointer is returned. | |
| cs_equation_t * | cs_gwf_tracer_decay_chain_get_equation (cs_gwf_tracer_decay_chain_t *tdc, int id) |
| Retrieve the equation structure for the tracer at the position "id" in the decay chain structure. If "id" is not valid, then a nullptr pointer is returned. | |
| cs_equation_param_t * | cs_gwf_tracer_decay_chain_get_equation_param (cs_gwf_tracer_decay_chain_t *tdc, int id) |
| Retrieve the equation parameters for the tracer at the position "id" in the decay chain structure. If "id" is not valid, then a nullptr pointer is returned. | |
| static const char | _err_empty_tracer [] |
| static int | _n_tracers = 0 |
| static cs_gwf_tracer_t ** | _tracers = nullptr |
| static int | _n_decay_chains = 0 |
| static cs_gwf_tracer_decay_chain_t ** | _decay_chains = nullptr |
| static cs_real_t * | cs_shared_liquid_saturation = nullptr |
| #define CS_GWF_TRACER_DBG 0 |
static |
| [in,out] | tracer | pointer to a cs_gwf_tracer_t structure |
static |
| [in] | lambda | value of the first order decay coefficient |
static |
| [in] | tr_model | model related to this tracer |
| [in] | gwf_model | main model for the GWF module |
| [in] | eq_name | name of the tracer equation |
| [in] | var_name | name of the related variable |
| [in] | adv_field | pointer to a cs_adv_field_t structure |
static |
static |
| [in,out] | tracer | pointer to a structure cs_gwf_tracer_t |
inlinestatic |
| [in] | elt_ids | list of element ids |
| [in] | dense_output | indirection for output (true or false) |
| [in] | context | null or pointer to a structure cast on-the_fly |
| [in,out] | result | array storing the result (must be allocated) |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
| [in] | dense_output | perform an indirection for output (true/false) |
inlinestatic |
| [in] | context | pointer to an context structure cast on-the_fly |
inlinestatic |
inlinestatic |
static |
| [in] | eq | equation related to a tracer |
| [in] | z | pointer to a volume zone structure |
| [in] | context | pointer to a context structure for a tracer |
| [in,out] | results | resulting array of values |
static |
static |
static |
static |
static |
| [in,out] | tracer | pointer to the tracer to update |
| [in] | chain_id | -1 or id of the associated decay chain |
| [in] | chain_position | -1 or id in the chain (position) |
static |
| [in,out] | tracer | pointer to a cs_gwf_tracer_structure |
| [in,out] | context | null or pointer to a structure cast on-the-fly |
static |
static |
static |
static |
static |
static |
| cs_gwf_tracer_t * cs_gwf_tracer_add | ( | cs_gwf_tracer_model_t | tr_model, |
| cs_gwf_model_type_t | gwf_model, | ||
| const char * | eq_name, | ||
| cs_adv_field_t * | adv_field, | ||
| double | lambda, | ||
| int | chain_position, | ||
| int | chain_id, | ||
| cs_gwf_tracer_init_setup_t * | init_setup, | ||
| cs_gwf_tracer_finalize_setup_t * | finalize_setup ) |
Add a new equation related to the groundwater flow module. This equation is a specific transport equation. The tracer is advected thanks to the darcian velocity (in the liquid phase) which is given by the resolution of the Richards equation. Diffusion and reaction coefficients result from a physical modelling.
| [in] | chain_position | -1 if not used or the id in the chain position |
| [in] | init_setup | function pointer (predefined prototype) |
| [in] | finalize_setup | function pointer (predefined prototype) |
| cs_gwf_tracer_t * cs_gwf_tracer_by_name | ( | const char * | eq_name | ) |
| void cs_gwf_tracer_compute_all | ( | const cs_mesh_t * | mesh, |
| const cs_cdo_quantities_t * | cdoq ) |
| void cs_gwf_tracer_compute_steady_all | ( | const cs_mesh_t * | mesh, |
| cs_gwf_tracer_decay_chain_t * cs_gwf_tracer_create_decay_chain | ( | int | n_tracers, |
| const char * | chain_name, | ||
| cs_gwf_tracer_unit_t | unit ) |
| [in] | n_tracers | number of tracers equations |
| [in] | chain_name | name of the decay chain |
| [in] | unit | type of unit used in the tracer equations |
| cs_gwf_tracer_decay_chain_t * cs_gwf_tracer_decay_chain_by_id | ( | int | id | ) |
| [in] | id | id of the decay chain to retrieve |
| cs_gwf_tracer_decay_chain_t * cs_gwf_tracer_decay_chain_by_name | ( | const char * | chain_name | ) |
| cs_equation_t * cs_gwf_tracer_decay_chain_get_equation | ( | cs_gwf_tracer_decay_chain_t * | tdc, |
| int | id ) |
Retrieve the equation structure for the tracer at the position "id" in the decay chain structure. If "id" is not valid, then a null pointer is returned.
| [in] | tdc | pointer to a decay chain structure |
| [in] | id | position of the tracer in the decay chain |
| cs_equation_param_t * cs_gwf_tracer_decay_chain_get_equation_param | ( | cs_gwf_tracer_decay_chain_t * | tdc, |
| int | id ) |
Retrieve the equation parameters for the tracer at the position "id" in the decay chain structure. If "id" is not valid, then a null pointer is returned.
| cs_gwf_tracer_t * cs_gwf_tracer_decay_chain_get_tracer | ( | cs_gwf_tracer_decay_chain_t * | tdc, |
| int | id ) |
Retrieve the tracer structure for the tracer at the position "id" in the decay chain structure. If "id" is not valid, then a null pointer is returned.
| void cs_gwf_tracer_default_init_setup | ( | cs_gwf_tracer_t * | tracer | ) |
| void cs_gwf_tracer_finalize_setup | ( | const cs_cdo_connect_t * | connect, |
| const cs_cdo_quantities_t * | quant ) |
| void cs_gwf_tracer_free_all | ( | void | ) |
| cs_real_t cs_gwf_tracer_get_time_theta_max | ( | void | ) |
| void cs_gwf_tracer_init_setup | ( | void | ) |
| double cs_gwf_tracer_integrate | ( | const cs_cdo_connect_t * | connect, |
| const cs_gwf_tracer_t * | tracer, | ||
| const char * | z_name ) |
Compute the integral of the tracer concentration over a given set of cells. This integral gives the number of moles of tracer inside the related volume. Moreover, it turns out to be exact for linear functions. A parallel operation (a sum reduction) is performed.
| [in] | tracer | pointer to a cs_gwf_tracer_t structure |
| [in] | z_name | name of the volumic zone where the integral is done (if null or "" all cells are considered) |
| void cs_gwf_tracer_integrate_by_terms | ( | const cs_cdo_connect_t * | connect, |
| const char * | z_name, | ||
| double | results[] ) |
| [in] | z_name | name of the volume zone where the integral is done (if null or "" all cells are considered) |
| [in,out] | results | array of values. [0]= the quantity of moles in the liquid phase, [1]= the quantity of moles inside the precipitation state |
| void cs_gwf_tracer_log_all | ( | void | ) |
| void cs_gwf_tracer_sat_finalize_setup | ( | const cs_cdo_connect_t * | connect, |
| const cs_adv_field_t * | adv, | ||
| cs_gwf_tracer_t * | tracer ) |
Set the parameters related to a standard tracer equation case of a fully saturated flow model.
| [in] | adv | pointer to an advection field structure |
| void cs_gwf_tracer_set_precip_param | ( | cs_gwf_tracer_t * | tracer, |
| const char * | soil_name, | ||
| double | conc_l_star ) |
| [in] | soil_name | name of the related soil (or null if all soils are selected) |
| [in] | conc_l_star | value of the saturated concentration in the liquid phase |
| void cs_gwf_tracer_set_soil_param | ( | cs_gwf_tracer_t * | tracer, |
| double | wmd, | ||
| double | alpha_l, | ||
| double | alpha_t, | ||
| double | distrib_coef ) |
| [in] | wmd | value of the water molecular diffusivity |
| [in] | alpha_l | value of the longitudinal dispersivity |
| [in] | alpha_t | value of the transversal dispersivity |
| [in] | distrib_coef | value of the distribution coefficient |
| void cs_gwf_tracer_unsat_finalize_setup | ( | const cs_cdo_connect_t * | connect, |
| void cs_gwf_tracer_update_diff_pty | ( | const cs_time_step_t * | ts, |
static |
static |
static |
static |
static |
static |
