cs_gwf_tracer.h
1#ifndef __CS_GWF_TRACER_H__
2#define __CS_GWF_TRACER_H__
5 * Set of main functions to handle soils in the groundwater flow module
6 * when using CDO schemes
7 *============================================================================*/
8
9/*
10 This file is part of code_saturne, a general-purpose CFD tool.
11
12 Copyright (C) 1998-2025 EDF S.A.
13
14 This program is free software; you can redistribute it and/or modify it under
15 the terms of the GNU General Public License as published by the Free Software
16 Foundation; either version 2 of the License, or (at your option) any later
17 version.
18
19 This program is distributed in the hope that it will be useful, but WITHOUT
20 ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
21 FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
22 details.
23
24 You should have received a copy of the GNU General Public License along with
25 this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
26 Street, Fifth Floor, Boston, MA 02110-1301, USA.
27*/
28
29/*----------------------------------------------------------------------------*/
30
31/*----------------------------------------------------------------------------
32 * Local headers
33 *----------------------------------------------------------------------------*/
34
36#include "base/cs_base.h"
37#include "cdo/cs_equation.h"
38#include "gwf/cs_gwf_param.h"
45 * Typedef definition
52
53typedef struct _gwf_tracer_t cs_gwf_tracer_t;
54
55/* \struct cs_gwf_tracer_default_context_t
56 *
57 * \brief Set of parameters related to a tracer equation attached to a standard
58 * modelling
59 */
60
61typedef struct _gwf_tracer_default_context_t cs_gwf_tracer_default_context_t;
62
63/*============================================================================
64 * Public function pointer prototypes
65 *============================================================================*/
66
67/*----------------------------------------------------------------------------*/
74/*----------------------------------------------------------------------------*/
75
76typedef void
78
79/*----------------------------------------------------------------------------*/
90/*----------------------------------------------------------------------------*/
91
92typedef void
94 const cs_cdo_quantities_t *quant,
95 const cs_adv_field_t *adv,
96 cs_gwf_tracer_t *tracer);
97
98/*----------------------------------------------------------------------------*/
110/*----------------------------------------------------------------------------*/
111
112typedef void
114 void *context,
115 const cs_time_step_t *ts,
116 const cs_mesh_t *mesh,
117 const cs_cdo_connect_t *connect,
118 const cs_cdo_quantities_t *quant);
119
120/*----------------------------------------------------------------------------*/
126/*----------------------------------------------------------------------------*/
127
128typedef void
130
131/*----------------------------------------------------------------------------*/
146/*----------------------------------------------------------------------------*/
147
148typedef void
150 const cs_cdo_quantities_t *cdoq,
151 const cs_equation_t *eq,
152 const cs_zone_t *zone,
153 void *context,
154 double results[]);
155
156/*============================================================================
157 * Structure definitions
158 *============================================================================*/
159
160/* Structure to handle of radioactive decay chain */
161
162typedef struct {
163
164 char *name; /* Name of the decay chain */
165 int id; /* Position in the array of chain decays */
166
167 int n_tracers; /* Number of tracers in the decay chain */
168 cs_gwf_tracer_unit_t unit; /* Type of unit measure:
169 * - mole (classical tracer)
170 * - Becquerel (activity)
171 */
172
173 cs_gwf_tracer_t **tracers; /* Array of tracers associated to the
174 decay chain. tracers[0] is the parent
175 without any ancestor. */
176
177 cs_xdef_t **st_defs; /* List of source term definitions */
178
180
181/* Set of parameters related to a tracer equation attached to a standard
182 modelling */
183
185
186 /* Common settings shared by all physical modelling */
187 /* ------------------------------------------------ */
188
189 double decay_coef; /* First order decay coefficient (related to the
190 reaction term). This value is intrinsic to the
191 component (a radioactive element for instance)
192 and not to the soil. */
193
194 /* The following parameters are defined for each soil (arrays of size equal
195 * to n_soils) */
196
197 double *rho_bulk; /* bulk density (kg.m^-3) */
198 double *kd0; /* reference value of the distribution coefficient
199 (m^".kg^-1) */
200 double *rho_kd; /* Derived quantity: rho_bulk*kd0 */
201
202 double *alpha_l; /* Longitudinal dispersivity */
203 double *alpha_t; /* Transversal dispersivity */
204
205 double *wmd; /* Water molecular diffusivity (m^2.s^-1) */
206
207 /* Precipitation members (set to null if not used) */
208 /* ----------------------------------------------- */
209
210 double *conc_l_star; /* maximal value of the concentration of
211 * tracer in the liquid phase in mol/m^3. There
212 * is one user-defined value for each soil. The
213 * exceeded quantities are stored in the solid
214 * phase (-> precip_mass). These values
215 * corresponds to the user settings
216 */
217
218 cs_real_t *precip_mass; /* array storing the mass of precipitate
219 * (solid) in the dedicated auxiliary
220 * storage. The size of this array may vary
221 * w.r.t. to the discretization scheme.
222 */
223
224 cs_field_t *precip_field; /* field structure storing the (interpolated)
225 * values of the concentration of precipitate
226 * in mol/kg in each cell.
227 */
228
229 /* Sorption members (set to null if not used) */
230 /* ------------------------------------------ */
231
232 double *k0_plus; /* kinetic coefficient towards site 2 locations
233 (m^3.kg^-1.s^-1) */
234 double *k0_minus; /* kinetic coefficient from site 2 locations
235 (s^-1) */
236
237 cs_real_t *conc_site2; /* array allocated to n_cells whatever the
238 space discretization is */
239
240 /* Variables used for the update of physical properties (shared pointers) */
241
243
244};
245
246/* Set of parameters describing a tracer structure */
247/* ----------------------------------------------- */
248
374
375/*============================================================================
376 * Public function prototypes
377 *============================================================================*/
378
379/*----------------------------------------------------------------------------*/
388/*----------------------------------------------------------------------------*/
389
391cs_gwf_tracer_by_name(const char *eq_name);
392
393/*----------------------------------------------------------------------------*/
419/*----------------------------------------------------------------------------*/
420
423 cs_gwf_model_type_t gwf_model,
424 const char *eq_name,
425 const char *var_name,
426 cs_adv_field_t *adv_field,
427 double lambda,
428 int chain_position,
429 int chain_id,
430 cs_gwf_tracer_init_setup_t *init_setup,
431 cs_gwf_tracer_finalize_setup_t *finalize_setup);
432
433/*----------------------------------------------------------------------------*/
437/*----------------------------------------------------------------------------*/
438
439void
441
442/*----------------------------------------------------------------------------*/
449/*----------------------------------------------------------------------------*/
450
453
454/*----------------------------------------------------------------------------*/
467/*----------------------------------------------------------------------------*/
468
469void
471 const char *soil_name,
472 double wmd,
473 double alpha_l,
474 double alpha_t,
475 double distrib_coef);
476
477/*----------------------------------------------------------------------------*/
488/*----------------------------------------------------------------------------*/
489
490void
492 const char *soil_name,
493 double conc_l_star);
494
495/*----------------------------------------------------------------------------*/
501/*----------------------------------------------------------------------------*/
502
503void
505
506/*----------------------------------------------------------------------------*/
513/*----------------------------------------------------------------------------*/
514
515void
517 const cs_cdo_quantities_t *quant);
518
519/*----------------------------------------------------------------------------*/
530/*----------------------------------------------------------------------------*/
531
532void
534 const cs_mesh_t *mesh,
535 const cs_cdo_connect_t *connect,
536 const cs_cdo_quantities_t *quant);
537
538/*----------------------------------------------------------------------------*/
542/*----------------------------------------------------------------------------*/
543
544void
546
547/*----------------------------------------------------------------------------*/
557/*----------------------------------------------------------------------------*/
558
559void
561 const cs_time_step_t *time_step,
562 const cs_cdo_connect_t *connect,
563 const cs_cdo_quantities_t *cdoq);
564
565/*----------------------------------------------------------------------------*/
575/*----------------------------------------------------------------------------*/
576
577void
579 const cs_time_step_t *time_step,
580 const cs_cdo_connect_t *connect,
581 const cs_cdo_quantities_t *cdoq);
582
583/*----------------------------------------------------------------------------*/
592/*----------------------------------------------------------------------------*/
593
594void
596
597/*----------------------------------------------------------------------------*/
607/*----------------------------------------------------------------------------*/
608
609void
611 const cs_cdo_quantities_t *quant,
612 const cs_adv_field_t *adv,
613 cs_gwf_tracer_t *tracer);
614
615/*----------------------------------------------------------------------------*/
625/*----------------------------------------------------------------------------*/
626
627void
629 const cs_cdo_quantities_t *quant,
630 const cs_adv_field_t *adv,
631 cs_gwf_tracer_t *tracer);
632
633/*----------------------------------------------------------------------------*/
649/*----------------------------------------------------------------------------*/
650
651double
653 const cs_cdo_quantities_t *cdoq,
654 const cs_gwf_tracer_t *tracer,
655 const char *z_name);
656
657/*----------------------------------------------------------------------------*/
675/*----------------------------------------------------------------------------*/
676
677void
679 const cs_cdo_quantities_t *cdoq,
680 const cs_gwf_tracer_t *tracer,
681 const char *z_name,
682 double results[]);
683
684/*----------------------------------------------------------------------------*/
694/*----------------------------------------------------------------------------*/
695
698 const char *chain_name,
700
701/*----------------------------------------------------------------------------*/
710/*----------------------------------------------------------------------------*/
711
714
715/*----------------------------------------------------------------------------*/
724/*----------------------------------------------------------------------------*/
725
727cs_gwf_tracer_decay_chain_by_name(const char *chain_name);
728
729/*----------------------------------------------------------------------------*/
740/*----------------------------------------------------------------------------*/
741
744 int id);
745
746/*----------------------------------------------------------------------------*/
757/*----------------------------------------------------------------------------*/
758
761 int id);
762
763/*----------------------------------------------------------------------------*/
774/*----------------------------------------------------------------------------*/
775
778 int id);
779
780/*----------------------------------------------------------------------------*/
781
783
784#endif /* __CS_GWF_TRACER_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
@ lambda
Definition cs_field_pointer.h:108
Flags specifying the general behavior of a tracer associated to the groundwater flow module.
Definition cs_gwf_param.h:297
cs_gwf_model_type_t
Definition cs_gwf_param.h:127
Type of unit for the expression of the radioactive inventory.
Definition cs_gwf_param.h:111
void cs_gwf_tracer_compute_all(const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Compute the new (unsteady) state for all tracer equations. Nothing is done if all equations are stead...
Definition cs_gwf_tracer.cpp:2658
void cs_gwf_tracer_free_context_t(cs_gwf_tracer_t *tracer)
Generic function to free the input of a tracer model.
Definition cs_gwf_tracer.h:129
void cs_gwf_tracer_compute_steady_all(const cs_mesh_t *mesh, const cs_time_step_t *time_step, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq)
Compute the steady-state for all tracer equations. Nothing is done if all equations are unsteady.
Definition cs_gwf_tracer.cpp:2610
cs_gwf_tracer_t * cs_gwf_tracer_add(cs_gwf_tracer_model_t tr_model, cs_gwf_model_type_t gwf_model, const char *eq_name, const char *var_name, cs_adv_field_t *adv_field, double lambda, int chain_position, int chain_id, cs_gwf_tracer_init_setup_t *init_setup, cs_gwf_tracer_finalize_setup_t *finalize_setup)
Create a new cs_gwf_tracer_t structure and initialize its members. This creation of a new tracer is f...
Definition cs_gwf_tracer.cpp:2107
void cs_gwf_tracer_unsat_finalize_setup(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_adv_field_t *adv, cs_gwf_tracer_t *tracer)
Set the parameters related to a standard tracer equation in case of an unsaturated flow model.
Definition cs_gwf_tracer.cpp:3017
void cs_gwf_tracer_free_all(void)
Free all tracer structures and all decay chains.
Definition cs_gwf_tracer.cpp:2163
void cs_gwf_tracer_finalize_setup(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Finalize the tracer setup.
Definition cs_gwf_tracer.cpp:2405
void cs_gwf_tracer_update_diff_pty(const cs_time_step_t *ts, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Update the diffusion property related to each tracer equation The update strategy depends on the soil...
Definition cs_gwf_tracer.cpp:2496
double cs_gwf_tracer_integrate(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_gwf_tracer_t *tracer, const char *z_name)
Compute the integral of the tracer concentration over a given set of cells. This integral gives the n...
Definition cs_gwf_tracer.cpp:3148
cs_gwf_tracer_t * cs_gwf_tracer_decay_chain_get_tracer(cs_gwf_tracer_decay_chain_t *tdc, int id)
Retrieve the tracer structure for the tracer at the position "id" in the decay chain structure....
Definition cs_gwf_tracer.cpp:3364
cs_gwf_tracer_decay_chain_t * cs_gwf_tracer_create_decay_chain(int n_tracers, const char *chain_name, cs_gwf_tracer_unit_t unit)
Create a decay chain structure to manage several linked tracers.
Definition cs_gwf_tracer.cpp:3250
cs_equation_t * cs_gwf_tracer_decay_chain_get_equation(cs_gwf_tracer_decay_chain_t *tdc, int id)
Retrieve the equation structure for the tracer at the position "id" in the decay chain structure....
Definition cs_gwf_tracer.cpp:3395
void cs_gwf_tracer_default_init_setup(cs_gwf_tracer_t *tracer)
Add terms to the algebraic system related to a tracer equation according to the settings....
Definition cs_gwf_tracer.cpp:2713
void cs_gwf_tracer_update_t(cs_gwf_tracer_t *tracer, void *context, const cs_time_step_t *ts, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Generic function to update the properties related to a tracer. This function depends on a numerical s...
Definition cs_gwf_tracer.h:113
void cs_gwf_tracer_init_setup_t(cs_gwf_tracer_t *tracer)
Generic function to update the first setup stage (the one done before building mesh and its related q...
Definition cs_gwf_tracer.h:77
cs_real_t cs_gwf_tracer_get_time_theta_max(void)
Retrieve the max. value of the theta parameter associated to a time scheme. Loop on all tracer equati...
Definition cs_gwf_tracer.cpp:2214
void cs_gwf_tracer_sat_finalize_setup(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_adv_field_t *adv, cs_gwf_tracer_t *tracer)
Set the parameters related to a standard tracer equation case of a fully saturated flow model.
Definition cs_gwf_tracer.cpp:2875
void cs_gwf_tracer_log_all(void)
Display the main features related to each tracer.
Definition cs_gwf_tracer.cpp:2528
cs_gwf_tracer_t * cs_gwf_tracer_by_name(const char *eq_name)
Retrieve the pointer to the cs_gwf_tracer_t structure associated to the name given as parameter.
Definition cs_gwf_tracer.cpp:2054
cs_gwf_tracer_decay_chain_t * cs_gwf_tracer_decay_chain_by_name(const char *chain_name)
Retrieve the decay chain structure associated to the name given as parameter. If not found,...
Definition cs_gwf_tracer.cpp:3325
cs_equation_param_t * cs_gwf_tracer_decay_chain_get_equation_param(cs_gwf_tracer_decay_chain_t *tdc, int id)
Retrieve the equation parameters for the tracer at the position "id" in the decay chain structure....
Definition cs_gwf_tracer.cpp:3425
void cs_gwf_tracer_init_setup(void)
Initial setup step for tracer equations. Soils and equation parameters are defined at this stage....
Definition cs_gwf_tracer.cpp:2368
void cs_gwf_tracer_finalize_setup_t(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_adv_field_t *adv, cs_gwf_tracer_t *tracer)
Generic function to finalize the setup of parameters related to a tracer equation....
Definition cs_gwf_tracer.h:93
void cs_gwf_tracer_integrate_by_terms(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_gwf_tracer_t *tracer, const char *z_name, double results[])
Compute the quantity of tracer using the integral of the tracer concentration over a given set of cel...
Definition cs_gwf_tracer.cpp:3202
void cs_gwf_tracer_set_precip_param(cs_gwf_tracer_t *tracer, const char *soil_name, double conc_l_star)
For a specified soil set the parameters corresponding to a precipitation modelling of a tracer transp...
Definition cs_gwf_tracer.cpp:2320
void cs_gwf_tracer_integrate_t(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_equation_t *eq, const cs_zone_t *zone, void *context, double results[])
Compute the quantity of tracer using an integral of the tracer concentration over a given set of cell...
Definition cs_gwf_tracer.h:149
cs_gwf_tracer_decay_chain_t * cs_gwf_tracer_decay_chain_by_id(int id)
Retrieve the decay chain structure associated to the given id If not found, it returns the null point...
Definition cs_gwf_tracer.cpp:3301
void cs_gwf_tracer_set_soil_param(cs_gwf_tracer_t *tracer, const char *soil_name, double wmd, double alpha_l, double alpha_t, double distrib_coef)
Set the main parameters corresponding to a default modelling of a tracer transport equation for a spe...
Definition cs_gwf_tracer.cpp:2253
Definition mesh.f90:26
Definition cs_gwf_tracer.h:184
cs_real_t * precip_mass
Definition cs_gwf_tracer.h:218
double * kd0
Definition cs_gwf_tracer.h:198
double decay_coef
Definition cs_gwf_tracer.h:189
double * rho_bulk
Definition cs_gwf_tracer.h:197
double * conc_l_star
Definition cs_gwf_tracer.h:210
cs_real_t * conc_site2
Definition cs_gwf_tracer.h:237
cs_field_t * precip_field
Definition cs_gwf_tracer.h:224
double * k0_plus
Definition cs_gwf_tracer.h:232
double * alpha_t
Definition cs_gwf_tracer.h:203
double * k0_minus
Definition cs_gwf_tracer.h:234
const cs_field_t * darcy_velocity_field
Definition cs_gwf_tracer.h:242
double * rho_kd
Definition cs_gwf_tracer.h:200
double * wmd
Definition cs_gwf_tracer.h:205
double * alpha_l
Definition cs_gwf_tracer.h:202
Definition cs_gwf_tracer.h:249
cs_gwf_tracer_update_t * update_diff_pty
Definition cs_gwf_tracer.h:360
cs_field_t * diffusivity
Definition cs_gwf_tracer.h:275
cs_gwf_tracer_update_t * update_decay_chain_st
Definition cs_gwf_tracer.h:362
cs_gwf_model_type_t hydraulic_model
Definition cs_gwf_tracer.h:261
cs_gwf_tracer_integrate_t * integrate
Definition cs_gwf_tracer.h:364
cs_gwf_tracer_update_t * update_precipitation
Definition cs_gwf_tracer.h:361
cs_gwf_tracer_init_setup_t * init_setup
Definition cs_gwf_tracer.h:366
cs_equation_t * equation
Definition cs_gwf_tracer.h:295
cs_gwf_tracer_model_t model
Definition cs_gwf_tracer.h:268
int reaction_id
Definition cs_gwf_tracer.h:283
int chain_id
Definition cs_gwf_tracer.h:317
int chain_position_id
Definition cs_gwf_tracer.h:310
cs_gwf_tracer_free_context_t * free_context
Definition cs_gwf_tracer.h:368
void * context
Definition cs_gwf_tracer.h:302
cs_gwf_tracer_finalize_setup_t * finalize_setup
Definition cs_gwf_tracer.h:367
Definition cs_advection_field.h:151
Definition cs_cdo_connect.h:61
Definition cs_cdo_quantities.h:145
Definition cs_equation_param.h:193
Definition cs_field.h:158
Definition cs_gwf_tracer.h:162
char * name
Definition cs_gwf_tracer.h:164
cs_xdef_t ** st_defs
Definition cs_gwf_tracer.h:177
int id
Definition cs_gwf_tracer.h:165
cs_gwf_tracer_t ** tracers
Definition cs_gwf_tracer.h:173
int n_tracers
Definition cs_gwf_tracer.h:167
Definition cs_gwf_tracer.h:168
Set of parameters describing a tracer structure.
Definition cs_mesh.h:85
time step descriptor
Definition cs_time_step.h:64
Definition cs_xdef.h:160
Definition cs_zone.h:55
