Functions to handle the setup of a computational domain High level interface for handling the computation. More...
#include "base/cs_defs.h"#include <assert.h>#include "bft/bft_mem.h"#include "base/cs_ale.h"#include "base/cs_boundary_zone.h"#include "base/cs_log.h"#include "base/cs_log_iteration.h"#include "base/cs_parall.h"#include "base/cs_pressure_correction.h"#include "base/cs_prototypes.h"#include "base/cs_time_step.h"#include "cdo/cs_cdo_blas.h"#include "cdo/cs_cdo_system.h"#include "cdo/cs_equation.h"#include "cdo/cs_equation_param.h"#include "cdo/cs_evaluate.h"#include "cdo/cs_hodge.h"#include "cdo/cs_maxwell.h"#include "cdo/cs_mesh_deform.h"#include "cdo/cs_navsto_system.h"#include "cdo/cs_solidification.h"#include "cdo/cs_source_term.h"#include "cdo/cs_thermal_system.h"#include "cdo/cs_walldistance.h"#include "gui/cs_gui.h"#include "gwf/cs_gwf.h"#include "mesh/cs_mesh_location.h"#include "cdo/cs_domain_setup.h"Functions | |
| static void | _set_scheme_flags (cs_domain_t *domain) |
| Define the scheme flags for the current computational domain Requirement: domain->cdo_context is alloctated. | |
| void | cs_domain_set_time_param (cs_domain_t *domain, int nt_max, double t_max) |
| Set parameters for unsteady computations: the max number of time steps or the final physical time of the simulation. | |
| void | cs_domain_automatic_time_step_settings (cs_domain_t *domain) |
| Set time step parameters for unsteady computations when this is not already done. This situation should occur when the GUI is used to set a constant time step. | |
| cs_xdef_t * | cs_domain_def_time_step_by_function (cs_domain_t *domain, cs_time_func_t *func, void *func_input) |
| Define the value of the time step thanks to a predefined function. | |
| void | cs_domain_def_time_step_by_value (cs_domain_t *domain, double dt) |
| Define the value of the time step. | |
| void | cs_domain_setup_init_cdo_structures (cs_domain_t *domain) |
| After having read the mesh and the first setup stage build the connectivities and mesh quantities related to CDO/HHO schemes. | |
| void | cs_domain_setup_initialize (cs_domain_t *domain) |
| First setup stage of the cs_domain_t structure Define extra domain boundaries Setup predefined equations Create fields (already done in the FV part) Define cs_sles_t structures for variable fields. | |
| void | cs_domain_setup_finalize (cs_domain_t *domain) |
| Last GUI and then user setup stage of the cs_domain_t structure. | |
| void | cs_domain_setup_finalize_module (cs_domain_t *domain) |
| Last user setup stage of the cs_domain_t structure. | |
| void | cs_domain_setup_init_state (cs_domain_t *domain) |
| Initialize systems of equations and their related field/properties values according to the user settings. | |
| void | cs_domain_setup_log (const cs_domain_t *domain) |
| Summary of the main domain settings. | |
static |
| void cs_domain_automatic_time_step_settings | ( | cs_domain_t * | domain | ) |
| cs_xdef_t * cs_domain_def_time_step_by_function | ( | cs_domain_t * | domain, |
| cs_time_func_t * | func, | ||
| void * | func_input ) |
| [in] | func | pointer to a cs_time_func_t function |
| [in] | func_input | pointer to a structure cast on-the-fly |
| void cs_domain_def_time_step_by_value | ( | cs_domain_t * | domain, |
| double | dt ) |
| [in] | dt | value of the constant time step |
| void cs_domain_set_time_param | ( | cs_domain_t * | domain, |
| int | nt_max, | ||
| double | t_max ) |
| [in] | nt_max | max. number of time step iterations |
| [in] | t_max | final physical time of the simulation |
| void cs_domain_setup_finalize | ( | cs_domain_t * | domain | ) |
| [in,out] | domain | pointer to a cs_domain_t struct. |
| void cs_domain_setup_finalize_module | ( | cs_domain_t * | domain | ) |
| void cs_domain_setup_init_cdo_structures | ( | cs_domain_t * | domain | ) |
| void cs_domain_setup_init_state | ( | cs_domain_t * | domain | ) |
| void cs_domain_setup_initialize | ( | cs_domain_t * | domain | ) |
| void cs_domain_setup_log | ( | const cs_domain_t * | domain | ) |
| [in] | domain | pointer to the cs_domain_t structure to summarize |
