1#ifndef __CS_SOURCE_TERM_H__
2#define __CS_SOURCE_TERM_H__
49#define CS_N_MAX_SOURCE_TERMS 8
156 const int n_source_terms,
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
unsigned short int cs_flag_t
Definition cs_defs.h:344
unsigned char cs_mask_t
Definition cs_flag.h:159
unsigned int cs_eflag_t
Definition cs_flag.h:192
cs_param_space_scheme_t
Definition cs_param_types.h:215
void cs_source_term_set_default_flag(cs_param_space_scheme_t scheme, cs_flag_t *state_flag, cs_flag_t *meta_flag)
Set the default flag related to a source term according to the numerical scheme chosen for discretizi...
Definition cs_source_term.cpp:511
void cs_source_term_pvsp_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution for a cell related to a source term and add it to the given array of values....
Definition cs_source_term.cpp:1066
void cs_source_term_hhosd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution of a source term for a cell and add it to the given array of values....
Definition cs_source_term.cpp:3018
void cs_source_term_fcb_pcsd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:2527
void cs_source_term_init_sharing(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect)
Definition cs_source_term.cpp:492
void cs_source_term_fb_pcvd_bary_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:2695
void cs_source_term_dcsd_q1o1_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:1755
void cs_source_term_set_reduction(cs_xdef_t *st, cs_flag_t flag)
Set advanced parameters which are defined by default in a source term structure.
Definition cs_source_term.cpp:559
void cs_source_term_dcsd_none_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:1606
void cs_source_term_compute_cellwise(const int n_source_terms, cs_xdef_t *const *source_terms, const cs_cell_mesh_t *cm, const cs_mask_t *source_mask, cs_source_term_cellwise_t *compute_source[], cs_real_t time_eval, void *input, cs_cell_builder_t *cb, cs_real_t *result)
Compute the local contributions of source terms in a cell.
Definition cs_source_term.cpp:1002
void cs_source_term_pvsp_by_c2v_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:1236
void cs_source_term_dcsd_by_dof_func(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:1554
void cs_source_term_dfsf_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:3379
cs_flag_t cs_source_term_get_flag(const cs_xdef_t *st)
Get metadata related to the given source term structure.
Definition cs_source_term.cpp:616
void cs_source_term_fcb_pcsd_by_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:2652
void cs_source_term_hhosd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:3145
void cs_source_term_fb_pcvd_by_dof_func(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:2385
void cs_source_term_dcsd_by_c2v_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution of a source term in a cell and add it to the given array of values....
Definition cs_source_term.cpp:1463
void cs_source_term_hhovd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:3264
void cs_source_term_fb_pcvd_by_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:2972
void cs_source_term_fb_pcvd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Compute the contribution for a cell related to a source term and add it the given array of values....
Definition cs_source_term.cpp:2436
void cs_source_term_vcsp_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:2230
void cs_source_term_fcb_pcsd_bary_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:2477
void cs_source_term_vcsp_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:2174
void cs_source_term_dcsd_q5o3_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:2067
void cs_source_term_fb_pcvd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:2839
void cs_source_term_dcsd_bary_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:1658
void cs_source_term_dcsd_by_pc_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:1512
void cs_source_term_dcvd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:1330
cs_eflag_t cs_source_term_init(cs_param_space_scheme_t space_scheme, const int n_source_terms, cs_xdef_t *const *source_terms, cs_source_term_cellwise_t *compute_source[], cs_flag_t *sys_flag, cs_mask_t *source_mask[])
Initialize data to build the source terms.
Definition cs_source_term.cpp:641
void cs_source_term_fcb_pcsd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:2297
void cs_source_term_dcsd_q10o2_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:1834
void cs_source_term_macfb_pcvd_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:2750
void cs_source_term_pvsp_by_analytic(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:1122
void cs_source_term_dcvd_by_pv_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:1415
void cs_source_term_cellwise_t(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.h:70
void cs_source_term_pvsp_by_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:1177
void cs_source_term_dcsd_by_pv_array(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:1371
void cs_source_term_dcsd_by_value(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:1290
void cs_source_term_fcb_pcsd_by_dof_func(const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values)
Definition cs_source_term.cpp:2336
Definition cs_cdo_connect.h:61
Definition cs_cdo_quantities.h:145
Definition cs_cdo_local.h:60
Definition cs_cdo_local.h:202
Definition cs_xdef.h:160
