8.0
cs_atmo.c File Reference
#include <errno.h>
#include <ctype.h>
#include <stdarg.h>
#include <float.h>
#include "cs_atmo_profile_std.h"
#include "cs_boundary_conditions.h"
#include "cs_boundary_zone.h"
#include "cs_domain.h"
#include "cs_field_default.h"
#include "cs_field_pointer.h"
#include "cs_halo.h"
#include "cs_math.h"
#include "cs_mesh_location.h"
#include "cs_equation_iterative_solve.h"
#include "cs_post.h"
#include "cs_prototypes.h"
#include "cs_thermal_model.h"
#include "cs_volume_zone.h"
#include "cs_balance.h"
#include "cs_blas.h"
#include "cs_parameters.h"
#include "cs_porous_model.h"
#include "cs_timer.h"
#include "cs_matrix_building.h"
#include "cs_sles.h"
#include "cs_sles_default.h"
#include "cs_face_viscosity.h"
#include "cs_divergence.h"
#include "cs_restart.h"
#include "cs_restart_default.h"
#include "cs_velocity_pressure.h"
#include "cs_atmo.h"
#include "cs_atmo_aerosol.h"
void cs_atmo_add_property_fields (void)
void cs_atmo_init_meteo_profiles (void)
 Initialize meteo profiles if no meteo file is given. More...
void cs_atmo_compute_meteo_profiles (void)
 Compute meteo profiles if no meteo file is given. More...
void cs_atmo_z_ground_compute (void)
 Compute the ground elevation. More...
void cs_atmo_hydrostatic_profiles_compute (void)
 Compute hydrostatic profiles of density and pressure. More...
void cs_atmo_set_meteo_file_name (const char *file_name)
 This function set the file name of the meteo file. More...
void cs_atmo_set_chem_conc_file_name (const char *file_name)
 This function set the file name of the chemistry file. More...
void cs_atmo_set_aero_conc_file_name (const char *file_name)
 This function set the file name of the aerosol file. More...
void cs_atmo_chemistry_set_spack_file_name (const char *file_name)
 This function set the file name of the SPACK file. More...
void cs_atmo_chemistry_set_aerosol_file_name (const char *file_name)
 This function sets the file name to initialize the aerosol library. More...
void cs_atmo_declare_chem_from_spack (void)
 This function declares additional transported variables for atmospheric module for the chemistry defined from SPACK. More...
void cs_atmo_compute_solar_angles (cs_real_t latitude, cs_real_t longitude, cs_real_t squant, cs_real_t utc, int sea_id, cs_real_t *albedo, cs_real_t *muzero, cs_real_t *omega, cs_real_t *fo)
 1D Radiative scheme - Solar data + zenithal angle) More...
void cs_atmo_log_setup (void)
 Print the atmospheric module options to setup.log. More...
void cs_atmo_chemistry_log_setup (void)
 Print the atmospheric chemistry options to setup.log. More...
void cs_atmo_aerosol_log_setup (void)
 Print the atmospheric aerosols options to setup.log. More...
void cs_atmo_finalize (void)
 Deallocate arrays for atmo module. More...
◆ cs_atmo_add_property_fields()
void cs_atmo_add_property_fields ( void  )
add properties fields
◆ cs_atmo_aerosol_log_setup()
void cs_atmo_aerosol_log_setup ( void  )
◆ cs_atmo_chemistry_log_setup()
void cs_atmo_chemistry_log_setup ( void  )
◆ cs_atmo_chemistry_set_aerosol_file_name()
void cs_atmo_chemistry_set_aerosol_file_name ( const char *  file_name)
[in]file_namename of the file.
◆ cs_atmo_chemistry_set_spack_file_name()
void cs_atmo_chemistry_set_spack_file_name ( const char *  file_name)
◆ cs_atmo_compute_meteo_profiles()
void cs_atmo_compute_meteo_profiles ( void  )
◆ cs_atmo_compute_solar_angles()
void cs_atmo_compute_solar_angles ( cs_real_t  latitude,
cs_real_t  squant,
cs_real_t  utc,
int  sea_id,
cs_real_t albedo,
cs_real_t muzero,
cs_real_t omega,
cs_real_t fo
Compute:
  • zenithal angle
  • solar contant (with correction for earth - solar length)
  • albedo if above the sea (Use analytical formulae of Paltrige and Platt dev.in atm. science no 5)
    [in]latitudelatitude
    [in]longitudelongitude
    [in]squantstart day in the year
    [in]utcUniversal time (hour)
    [in]sea_idsea index
    [out]albedoalbedo
    [out]muzerocosin of zenithal angle
    [out]omegasolar azimut angle
    [out]fosolar constant
◆ cs_atmo_declare_chem_from_spack()
void cs_atmo_declare_chem_from_spack ( void  )
This function declare additional transported variables for atmospheric module for the chemistry defined from SPACK.
◆ cs_atmo_finalize()
void cs_atmo_finalize ( void  )
◆ cs_atmo_hydrostatic_profiles_compute()
void cs_atmo_hydrostatic_profiles_compute ( void  )
This function solves the following transport equation on $ \varia $:
\[ \divs \left( \grad \varia \right) = \divs \left( \dfrac{\vect{g}}{c_p \theta} \right) \]
where $ \vect{g} $ is the gravity field and $ \theta $ is the potential temperature.
The boundary conditions on $ \varia $ read:
\[ \varia = \left(\dfrac{P_{sea}}{p_s}\right)^{R/C_p} \textrm{on the ground} \]
and Neumann elsewhere.
◆ cs_atmo_init_meteo_profiles()
void cs_atmo_init_meteo_profiles ( void  )
◆ cs_atmo_log_setup()
void cs_atmo_log_setup ( void  )
◆ cs_atmo_set_aero_conc_file_name()
void cs_atmo_set_aero_conc_file_name ( const char *  file_name)
This function set the file name of the aerosol concentration file.
◆ cs_atmo_set_chem_conc_file_name()
void cs_atmo_set_chem_conc_file_name ( const char *  file_name)
This function set the file name of the chemistry concentration file.
◆ cs_atmo_set_meteo_file_name()
void cs_atmo_set_meteo_file_name ( const char *  file_name)
◆ cs_atmo_z_ground_compute()
void cs_atmo_z_ground_compute ( void  )
\[ \dfrac{\partial \varia}{\partial t} + \divs \left( \varia \vect{g} \right) - \divs \left( \vect{V} \right) \varia = 0 \]
\[ \varia = z \textrm{ on walls} \]
\[ \dfrac{\partial \varia}{\partial n} = 0 \textrm{ elsewhere} \]
Remarks:
  • a steady state is looked for.
