8.0
cs_restart.h
1 #ifndef __CS_RESTART_H__
2 #define __CS_RESTART_H__
5  * Manage checkpoint / restart files
35  * Local headers
38 #include "cs_defs.h"
40 #include "cs_time_step.h"
45
47  * Macro definitions
49
50 /* Predefined checkpoint interval */
51
52 #define CS_RESTART_INTERVAL_NONE -2
53 #define CS_RESTART_INTERVAL_ONLY_AT_END -1
54 #define CS_RESTART_INTERVAL_DEFAULT 0
55
56 /* Error codes */
57
58 #define CS_RESTART_SUCCESS 0
59 #define CS_RESTART_ERR_FILE_NUM -1
60 #define CS_RESTART_ERR_LOCATION -2
61 #define CS_RESTART_ERR_VAL_TYPE -3
62 #define CS_RESTART_ERR_N_VALS -4
63 #define CS_RESTART_ERR_MODE -5
64 #define CS_RESTART_ERR_EXISTS -6
65 #define CS_RESTART_ERR_NO_MAP -7
68 /*============================================================================
69  * Local type definitions
70  *============================================================================*/
71
74 typedef enum {
75
80
81 /* Datatype enumeration to transmit a data's type to a function */
82
83 typedef enum {
89
90 /*
91  Pointer associated with a restart file structure. The structure itself
92  is defined in "cs_restart.c", and is opaque outside that unit.
93 */
94
95 typedef struct _cs_restart_t cs_restart_t;
96
117 /*----------------------------------------------------------------------------*/
118
119 typedef int
121  void *context,
122  const char *sec_name,
123  int location_id,
124  int n_location_vals,
125  cs_restart_val_type_t val_type);
126
147 /*----------------------------------------------------------------------------*/
148
149 typedef int
151  void *context,
152  const char *sec_name,
153  int location_id,
154  int n_location_vals,
155  cs_restart_val_type_t val_type,
156  void *val);
157
158 /*----------------------------------------------------------------------------*/
175 /*----------------------------------------------------------------------------*/
176
177 typedef void
179  void *context,
180  const char *sec_name,
181  int location_id,
182  int n_location_vals,
183  cs_restart_val_type_t val_type,
184  const void *val);
185
186 /*=============================================================================
187  * Global variables
188  *============================================================================*/
189
190 /*============================================================================
191  * Public Fortran function prototypes
192  *============================================================================*/
193
194 /*----------------------------------------------------------------------------
195  * Check if checkpointing is recommended at a given time.
196  *
197  * Fortran interface
198  *
199  * subroutine reqsui (iisuit)
200  * *****************
201  *
202  * integer iisuit : --> : 0 if no restart required, 1 otherwise
203  *----------------------------------------------------------------------------*/
204
205 void CS_PROCF (reqsui, REQSUI)
206 (
207  int *iisuit
208 );
209
210 /*----------------------------------------------------------------------------
211  * Indicate checkpointing has been done at a given time.
212  *
213  * This updates the status for future checks to determine
214  * if checkpointing is recommended at a given time.
215  *
216  * Fortran interface
217  *
218  * subroutine stusui
219  * *****************
220  *----------------------------------------------------------------------------*/
221
222 void CS_PROCF (stusui, STUSUI)
223 (
224  void
225 );
226
227 /*----------------------------------------------------------------------------
228  * Save output mesh for turbomachinery if needed
229  *
230  * Fortran interface
231  *
232  * subroutine trbsui
233  * *****************
234  *----------------------------------------------------------------------------*/
235
236 void CS_PROCF (trbsui, TRBSUI)
237 (
238  void
239 );
240
241 /*----------------------------------------------------------------------------
242  * Indicate if a restart directory is present.
243  *
244  * Fortran interface
245  *
246  * subroutine indsui (isuite)
247  * *****************
248  *
249  * integer isuite : --> : 1 for restart, 0 otherwise
250  *----------------------------------------------------------------------------*/
251
252 void CS_PROCF (indsui, INDSUI)
253 (
254  int *isuite
255 );
256
257 /*============================================================================
258  * Public function prototypes
259  *============================================================================*/
260
261 /*----------------------------------------------------------------------------*/
275 /*----------------------------------------------------------------------------*/
276
277 void
278 cs_restart_checkpoint_get_intervals(int *nt_interval,
279  double *t_interval,
280  double *wt_interval);
281
282 /*----------------------------------------------------------------------------*/
293 /*----------------------------------------------------------------------------*/
294
295 void
296 cs_restart_checkpoint_set_interval(int nt_interval,
297  double t_interval,
298  double wt_interval);
299
300 /*----------------------------------------------------------------------------*/
318 /*----------------------------------------------------------------------------*/
319
320 void
322
323 /*----------------------------------------------------------------------------*/
329 /*----------------------------------------------------------------------------*/
330
331 void
333
334 /*----------------------------------------------------------------------------*/
340 /*----------------------------------------------------------------------------*/
341
342 void
344
345 /*----------------------------------------------------------------------------*/
351 /*----------------------------------------------------------------------------*/
352
353 void
354 cs_restart_checkpoint_set_next_tv(double t_next);
355
356 /*----------------------------------------------------------------------------*/
362 /*----------------------------------------------------------------------------*/
363
364 void
365 cs_restart_checkpoint_set_next_wt(double wt_next);
366
367 /*----------------------------------------------------------------------------*/
375 /*----------------------------------------------------------------------------*/
376
377 bool
379
380 /*----------------------------------------------------------------------------*/
389 /*----------------------------------------------------------------------------*/
390
391 void
393
394 /*----------------------------------------------------------------------------*/
400 /*----------------------------------------------------------------------------*/
401
402 int
403 cs_restart_present(void);
404
405 /*----------------------------------------------------------------------------*/
416 /*----------------------------------------------------------------------------*/
417
418 cs_restart_t *
419 cs_restart_create(const char *name,
420  const char *path,
421  cs_restart_mode_t mode);
422
423 /*----------------------------------------------------------------------------*/
429 /*----------------------------------------------------------------------------*/
430
431 void
433
434 /*----------------------------------------------------------------------------*/
448 /*----------------------------------------------------------------------------*/
449
450 void
452  bool *match_cell,
453  bool *match_i_face,
454  bool *match_b_face,
455  bool *match_vertex);
456
457 /*----------------------------------------------------------------------------*/
469 /*----------------------------------------------------------------------------*/
470
471 int
473  const char *location_name,
474  cs_gnum_t n_glob_ents,
475  cs_lnum_t n_ents,
476  const cs_gnum_t *ent_global_num);
477
478 /*----------------------------------------------------------------------------*/
489 /*----------------------------------------------------------------------------*/
490
491 void
492 cs_restart_add_location_ref(const char *location_name,
493  cs_gnum_t n_glob_ents,
494  cs_lnum_t n_ents,
495  const cs_gnum_t *ent_global_num);
496
497 /*----------------------------------------------------------------------------*/
501 /*----------------------------------------------------------------------------*/
502
503 void
505
506 /*----------------------------------------------------------------------------*/
520 /*----------------------------------------------------------------------------*/
521
522 void
523 cs_restart_set_context(void *context);
524
525 /*----------------------------------------------------------------------------*/
535 /*----------------------------------------------------------------------------*/
536
539
540 /*----------------------------------------------------------------------------*/
551 /*----------------------------------------------------------------------------*/
552
555
556 /*----------------------------------------------------------------------------*/
567 /*----------------------------------------------------------------------------*/
568
571
572 /*----------------------------------------------------------------------------*/
580 /*----------------------------------------------------------------------------*/
581
582 const char *
583 cs_restart_get_name(const cs_restart_t *restart);
584
585 /*----------------------------------------------------------------------------*/
595 /*----------------------------------------------------------------------------*/
596
597 cs_lnum_t
599  int location_id);
600
601 /*----------------------------------------------------------------------------*/
607 /*----------------------------------------------------------------------------*/
608
609 void
610 cs_restart_dump_index(const cs_restart_t *restart);
611
612 /*----------------------------------------------------------------------------*/
625 /*----------------------------------------------------------------------------*/
626
627 int
629  const char *sec_name,
630  int location_id,
631  int n_location_vals,
632  cs_restart_val_type_t val_type);
633
634 /*----------------------------------------------------------------------------*/
648 /*----------------------------------------------------------------------------*/
649
650 int
652  const char *sec_name,
653  int location_id,
654  int n_location_vals,
655  cs_restart_val_type_t val_type,
656  void *val);
657
658 /*----------------------------------------------------------------------------*/
669 /*----------------------------------------------------------------------------*/
670
671 void
673  const char *sec_name,
674  int location_id,
675  int n_location_vals,
676  cs_restart_val_type_t val_type,
677  const void *val);
678
679 /*----------------------------------------------------------------------------*/
691 /*----------------------------------------------------------------------------*/
692
693 int
695  const char *name,
696  cs_lnum_t *n_particles);
697
698 /*----------------------------------------------------------------------------*/
710 /*----------------------------------------------------------------------------*/
711
712 int
714  int particles_location_id,
715  cs_lnum_t *particle_cell_id,
716  cs_real_t *particle_coords);
717
718 /*----------------------------------------------------------------------------*/
738 /*----------------------------------------------------------------------------*/
739
740 int
742  const char *name,
743  bool number_by_coords,
744  cs_lnum_t n_particles,
745  const cs_lnum_t *particle_cell_id,
746  const cs_real_t *particle_coords);
747
748 /*----------------------------------------------------------------------------*/
770 /*----------------------------------------------------------------------------*/
771
772 int
774  const char *sec_name,
775  int location_id,
776  int ref_location_id,
777  cs_lnum_t ref_id_base,
778  cs_lnum_t *ref_id);
779
780 /*----------------------------------------------------------------------------*/
795 /*----------------------------------------------------------------------------*/
796
797 void
799  const char *sec_name,
800  int location_id,
801  int ref_location_id,
802  cs_lnum_t ref_id_base,
803  const cs_lnum_t *ref_id);
804
805 /*----------------------------------------------------------------------------*/
821 /*----------------------------------------------------------------------------*/
822
823 int
825  const char *sec_name,
826  const char *old_name,
827  int location_id,
828  int n_location_vals,
829  cs_restart_val_type_t val_type,
830  void *val);
831
832 /*----------------------------------------------------------------------------*/
851 /*----------------------------------------------------------------------------*/
852
853 int
855  const char *sec_name,
856  const char *old_name_x,
857  const char *old_name_y,
858  const char *old_name_z,
859  int location_id,
860  cs_real_3_t *val);
861
862 /*----------------------------------------------------------------------------*/
884 /*----------------------------------------------------------------------------*/
885
886 int
888  const char *sec_name,
889  const char *old_name_xx,
890  const char *old_name_yy,
891  const char *old_name_zz,
892  const char *old_name_xy,
893  const char *old_name_yz,
894  const char *old_name_xz,
895  int location_id,
896  cs_real_6_t *val);
897
898 /*----------------------------------------------------------------------------*/
920 /*----------------------------------------------------------------------------*/
921
922 int
924  const char *sec_name,
925  const char *old_name_xx,
926  const char *old_name_yy,
927  const char *old_name_zz,
928  const char *old_name_xy,
929  const char *old_name_yz,
930  const char *old_name_xz,
931  int location_id,
932  cs_real_66_t *val);
933
934 /*----------------------------------------------------------------------------*/
938 /*----------------------------------------------------------------------------*/
939
940 void
942
943 /*----------------------------------------------------------------------------*/
947 /*----------------------------------------------------------------------------*/
948
949 void
951
952 /*----------------------------------------------------------------------------*/
958 /*----------------------------------------------------------------------------*/
959
960 int
962
963 /*----------------------------------------------------------------------------*/
969 /*----------------------------------------------------------------------------*/
970
971 int
973
974 /*----------------------------------------------------------------------------*/
987 /*----------------------------------------------------------------------------*/
988
989 void
990 cs_restart_set_n_max_checkpoints(int n_checkpoints);
991
992 /*----------------------------------------------------------------------------*/
996 /*----------------------------------------------------------------------------*/
997
998 void
1000
1001 /*----------------------------------------------------------------------------*/
1005 /*----------------------------------------------------------------------------*/
1006
1007 void
1009
1010 /*----------------------------------------------------------------------------*/
1011
1013
1014 #endif /* __CS_RESTART_H__ */
Definition: cs_defs.h:509
Definition: cs_defs.h:319
#define CS_PROCF(x, y)
Definition: cs_defs.h:523
cs_real_t cs_real_66_t[6][6]
6x6 matrix of floating-point values
Definition: cs_defs.h:342
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:332
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:298
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:334
Definition: cs_defs.h:313
int cs_restart_is_from_ncfd(void)
Returns if restart is done from a NCFD checkpoint file.
Definition: cs_restart.c:4069
cs_restart_mode_t
Definition: cs_restart.h:74
@ CS_RESTART_MODE_WRITE
Definition: cs_restart.h:77
@ CS_RESTART_MODE_READ
Definition: cs_restart.h:76
const char * cs_restart_get_name(const cs_restart_t *restart)
Return name of restart file.
Definition: cs_restart.c:2680
Definition: cs_restart.h:83
@ CS_TYPE_int
Definition: cs_restart.h:85
@ CS_TYPE_cs_gnum_t
Definition: cs_restart.h:86
@ CS_TYPE_cs_real_t
Definition: cs_restart.h:87
@ CS_TYPE_char
Definition: cs_restart.h:84
cs_restart_write_section_t * cs_restart_set_write_section_func(cs_restart_write_section_t *func)
Associate a function and its input to all restart section write operations.
Definition: cs_restart.c:2661
void indsui(int *isuite)
Definition: cs_restart.c:1830
void stusui(void)
Definition: cs_restart.c:1794
int cs_restart_read_real_6_t_compat(cs_restart_t *restart, const char *sec_name, const char *old_name_xx, const char *old_name_yy, const char *old_name_zz, const char *old_name_xy, const char *old_name_yz, const char *old_name_xz, int location_id, cs_real_6_t *val)
Read a cs_real_6_t tensor section from a restart file, when that section may have used a different na...
Definition: cs_restart.c:3713
bool cs_restart_checkpoint_required(const cs_time_step_t *ts)
Definition: cs_restart.c:1986
cs_lnum_t cs_restart_get_n_location_elts(const cs_restart_t *restart, int location_id)
Return local number of elements associated with a given restart location.
Definition: cs_restart.c:2700
void cs_restart_checkpoint_get_intervals(int *nt_interval, double *t_interval, double *wt_interval)
Query checkpoint intervals.
Definition: cs_restart.c:1858
void trbsui(void)
Definition: cs_restart.c:1811
void cs_restart_set_context(void *context)
Associate a context to restart section check operations.
Definition: cs_restart.c:2599
int cs_restart_present(void)
Check if we have a restart directory.
Definition: cs_restart.c:2097
void cs_restart_check_base_location(const cs_restart_t *restart, bool *match_cell, bool *match_i_face, bool *match_b_face, bool *match_vertex)
Check the locations associated with a restart file.
Definition: cs_restart.c:2377
void cs_restart_clear_locations_ref(void)
Clear reference location definitions with a private copy.
Definition: cs_restart.c:2572
Definition: cs_restart.h:95
int cs_restart_check_if_restart_from_ncfd(cs_restart_t *r)
Checks if restart is done from a NCFD checkpoint file.
Definition: cs_restart.c:4040
int() cs_restart_read_section_t(cs_restart_t *restart, void *context, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type, void *val)
Function pointer for modifying behavior when reading a section.
Definition: cs_restart.h:150
void reqsui(int *iisuit)
Definition: cs_restart.c:1771
int cs_restart_check_section(cs_restart_t *restart, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type)
Check the presence of a given section in a restart file.
Definition: cs_restart.c:2761
void cs_restart_checkpoint_set_last_ts(int nt_last)
Define last forced checkpoint time step.
Definition: cs_restart.c:1928
void cs_restart_checkpoint_set_next_wt(double wt_next)
Define next forced checkpoint wall-clock time value.
Definition: cs_restart.c:1970
void cs_restart_log_setup(void)
Log checkpoint/restart setup.
Definition: cs_restart.c:3978
cs_restart_check_section_t * cs_restart_set_check_section_func(cs_restart_check_section_t *func)
Associate a function to restart section check operations.
Definition: cs_restart.c:2617
cs_restart_read_section_t * cs_restart_set_read_section_func(cs_restart_read_section_t *func)
Associate a function and its input to all restart section read operations.
Definition: cs_restart.c:2639
void cs_restart_set_n_max_checkpoints(int n_checkpoints)
Set the number of checkpoint files to keep.
Definition: cs_restart.c:4093
int() cs_restart_check_section_t(cs_restart_t *restart, void *context, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type)
Function pointer for modifying behavior when checking a section's presence.
Definition: cs_restart.h:120
int cs_restart_read_real_3_t_compat(cs_restart_t *restart, const char *sec_name, const char *old_name_x, const char *old_name_y, const char *old_name_z, int location_id, cs_real_3_t *val)
Read a cs_real_3_t vector section from a restart file, when that section may have used a different na...
Definition: cs_restart.c:3599
void() cs_restart_write_section_t(cs_restart_t *restart, void *context, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type, const void *val)
Function pointer for modifying behavior when writing a section.
Definition: cs_restart.h:178
void cs_restart_checkpoint_set_next_tv(double t_next)
Define next forced checkpoint time value.
Definition: cs_restart.c:1956
void cs_restart_write_section(cs_restart_t *restart, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type, const void *val)
Write a section to a restart file.
Definition: cs_restart.c:2837
int cs_restart_read_particles_info(cs_restart_t *restart, const char *name, cs_lnum_t *n_particles)
Read basic particles information from a restart file.
Definition: cs_restart.c:2877
void cs_restart_destroy(cs_restart_t **restart)
Destroy structure associated with a restart file (and close the file).
Definition: cs_restart.c:2321
void cs_restart_write_ids(cs_restart_t *restart, const char *sec_name, int location_id, int ref_location_id, cs_lnum_t ref_id_base, const cs_lnum_t *ref_id)
Write a referenced location id section to a restart file.
Definition: cs_restart.c:3419
int cs_restart_read_real_66_t_compat(cs_restart_t *restart, const char *sec_name, const char *old_name_xx, const char *old_name_yy, const char *old_name_zz, const char *old_name_xy, const char *old_name_yz, const char *old_name_xz, int location_id, cs_real_66_t *val)
Read a cs_real_66_t tensor section from a restart file, when that section may have used a different n...
Definition: cs_restart.c:3855
int cs_restart_read_section_compat(cs_restart_t *restart, const char *sec_name, const char *old_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type, void *val)
Read a section from a restart file, when that section may have used a different name in a previous ve...
Definition: cs_restart.c:3522
int cs_restart_add_location(cs_restart_t *restart, const char *location_name, cs_gnum_t n_glob_ents, cs_lnum_t n_ents, const cs_gnum_t *ent_global_num)
Add a location definition.
Definition: cs_restart.c:2435
int cs_restart_read_particles(cs_restart_t *restart, int particles_location_id, cs_lnum_t *particle_cell_id, cs_real_t *particle_coords)
Definition: cs_restart.c:3064
void cs_restart_multiwriters_destroy_all(void)
Destroy the multiwriter structure at the end of the computation.
Definition: cs_restart.c:4174
void cs_restart_dump_index(const cs_restart_t *restart)
Print the index associated with a restart file in read mode.
Definition: cs_restart.c:2722
int cs_restart_read_section(cs_restart_t *restart, const char *sec_name, int location_id, int n_location_vals, cs_restart_val_type_t val_type, void *val)
Read a section from a restart file.
Definition: cs_restart.c:2794
void cs_restart_clean_multiwriters_history(void)
Remove all previous checkpoints which are not to be retained.
Definition: cs_restart.c:4115
void cs_restart_add_location_ref(const char *location_name, cs_gnum_t n_glob_ents, cs_lnum_t n_ents, const cs_gnum_t *ent_global_num)
Add a reference location definition with a private copy.
Definition: cs_restart.c:2530
int cs_restart_write_particles(cs_restart_t *restart, const char *name, bool number_by_coords, cs_lnum_t n_particles, const cs_lnum_t *particle_cell_id, const cs_real_t *particle_coords)
Write basic particles information to a restart file.
Definition: cs_restart.c:3181
void cs_restart_checkpoint_set_interval(int nt_interval, double t_interval, double wt_interval)
Define default checkpoint interval.
Definition: cs_restart.c:1884
cs_restart_t * cs_restart_create(const char *name, const char *path, cs_restart_mode_t mode)
Initialize a restart file.
Definition: cs_restart.c:2126
void cs_restart_checkpoint_set_mesh_mode(int mode)
Define checkpoint behavior for mesh.
Definition: cs_restart.c:1914
int cs_restart_read_ids(cs_restart_t *restart, const char *sec_name, int location_id, int ref_location_id, cs_lnum_t ref_id_base, cs_lnum_t *ref_id)
Read a referenced location id section from a restart file.
Definition: cs_restart.c:3316
void cs_restart_checkpoint_done(const cs_time_step_t *ts)
Definition: cs_restart.c:2058
void cs_restart_print_stats(void)
Print statistics associated with restart files.
Definition: cs_restart.c:4017
void cs_restart_checkpoint_set_next_ts(int nt_next)
Define next forced checkpoint time step.
Definition: cs_restart.c:1942
integer, save isuite
Indicator of a calculation restart (=1) or not (=0). This value is set automatically by the code; dep...
Definition: optcal.f90:158
time step descriptor
Definition: cs_time_step.h:64
