8.0
cs_field_pointer.h
1 #ifndef __CS_FIELD_POINTER_H__
2 #define __CS_FIELD_POINTER_H__
5  * Field pointers and ids for standard and model fields
31  * Local headers
34 #include "cs_defs.h"
35 #include "cs_field.h"
36
38
41 /*=============================================================================
42  * Macro definitions
45 /* Macro used for scoping of field pointer enums */
46
47 #define CS_ENUMF_(e) CS_FIELD_POINTER_ ## e
48
49 /* Macro used to return a field pointer by its enumerated value */
50
51 #define CS_F_(e) cs_glob_field_pointers[CS_FIELD_POINTER_ ## e].f
52
53 #define CS_FI_(e, i) cs_glob_field_pointers[CS_FIELD_POINTER_ ## e].p[i]
54
55 /*============================================================================
56  * Type definitions
58
61 typedef enum {
62
63  /* Base variables and properties */
64
77  CS_ENUMF_(alp_bl),
81  CS_ENUMF_(nusa),
113  /* Specific physics variables and properties */
114
198  /* Cooling tower fields */
208  /* NCFD fields */
245  /* Added variables (scalars) */
248  /* User-defined arrays */
250
251  /* End of attributes */
252
254
256
262 };
263
264 /*============================================================================
265  * Global variables
266  *============================================================================*/
267
268 /* Pointers */
269
271
272 /*=============================================================================
273  * Public function prototypes
274  *============================================================================*/
275
276 /*----------------------------------------------------------------------------
277  * Ensure field pointer array is initialized.
278  *----------------------------------------------------------------------------*/
279
280 void
282
283 /*----------------------------------------------------------------------------
284  * Free all field pointer data.
285  *----------------------------------------------------------------------------*/
286
287 void
289
290 /*----------------------------------------------------------------------------
291  * Map a simple field to an enumerated pointer.
292  *
293  * The associated field pointer may then be retreived using \ref CS_F_(e).
294  *
295  * parameters:
296  * e <-- field enumerator value
297  * f <-- pointer to field structure
298  *----------------------------------------------------------------------------*/
299
300 void
302  cs_field_t *f);
303
304 /*----------------------------------------------------------------------------
305  * Map a field to an (enumerated pointer, index) couple.
306  *
307  * This sort of mapping may be used for sets of fields whose size
308  * is not known in advance.
309  *
310  * The associated field pointer may then be retreived using \ref CS_F_(e, i).
311  *
312  * parameters:
313  * e <-- field enumerator value
314  * index <-- field enumerator index
315  * f <-- pointer to field structure
316  *----------------------------------------------------------------------------*/
317
318 void
320  int index,
321  cs_field_t *f);
322
323 /*----------------------------------------------------------------------------
324  * Map base fields to enumerated pointers.
325  *----------------------------------------------------------------------------*/
326
327 void
329
330 /*----------------------------------------------------------------------------
331  * Map some boundary fields to enumerated pointers.
332  *----------------------------------------------------------------------------*/
333
334 void
336
337 /*----------------------------------------------------------------------------
338  * Map base fields to enumerated pointers for atmospheric models
339  *
340  * parameters:
341  * n_chem_species <-- number of chemical species
342  * species_f_if <-- field id for each chemical species
343  *----------------------------------------------------------------------------*/
344
345 void
346 cs_field_pointer_map_atmospheric(int n_chem_species,
347  const int species_f_id[]);
348
349 /*----------------------------------------------------------------------------
350  * Map base fields to enumerated pointers for atmospheric models
351  *
352  * parameters:
353  * n_coals <-- number of coals
354  * n_classes <-- number of coal classes
355  *----------------------------------------------------------------------------*/
356
357 void
359  int n_classes);
360
361 /*----------------------------------------------------------------------------*
362  * Map base fields to enumerated pointers for compressible model
363  *----------------------------------------------------------------------------*/
364
365 void
367
368 /*----------------------------------------------------------------------------*
369  * Map base fields to enumerated pointers for gas mix model
370  *----------------------------------------------------------------------------*/
371
372 void
374
375 /*----------------------------------------------------------------------------
376  * Map base fields to enumerated pointers for gas combustion.
377  *----------------------------------------------------------------------------*/
378
379 void
381
382 /*----------------------------------------------------------------------------*/
383 /*
384  * Map base fields to enumerated pointers for groundwater flows
385  *----------------------------------------------------------------------------*/
386
387 void
389
390 /*----------------------------------------------------------------------------*/
391
393
394 #endif /* __CS_FIELD_POINTER_H__ */
Definition: cs_defs.h:509
void cs_field_pointer_map_indexed(cs_field_pointer_id_t e, int index, cs_field_t *f)
Definition: cs_field_pointer.c:232
void cs_field_pointer_map_boundary(void)
Definition: cs_field_pointer.c:347
void cs_field_pointer_map_atmospheric(int n_chem_species, const int species_f_id[])
Map base fields to enumerated pointers for atmospheric models.
Definition: cs_field_pointer.c:366
void cs_field_pointer_map_gas_combustion(void)
Definition: cs_field_pointer.c:510
void cs_field_pointer_ensure_init(void)
Definition: cs_field_pointer.c:173
Macro used for scoping of field pointer enums.
Definition: cs_field_pointer.h:47
void cs_field_pointer_map_coal_combustion(int n_coals, int n_classes)
Map base fields to enumerated pointers for coal combustion.
Definition: cs_field_pointer.c:393
Definition: cs_field_pointer.h:61
@ t
@ mass_f
Definition: cs_field_pointer.h:120
@ vel_mean
Definition: cs_field_pointer.h:237
@ user
Definition: cs_field_pointer.h:249
@ head
Definition: cs_field_pointer.h:196
@ volume_f
Definition: cs_field_pointer.h:119
@ alp_bl
Definition: cs_field_pointer.h:77
@ drift_vel
Definition: cs_field_pointer.h:235
@ npm
Definition: cs_field_pointer.h:132
@ qfpzx
Definition: cs_field_pointer.h:218
@ ynh3
Definition: cs_field_pointer.h:156
@ f1m
Definition: cs_field_pointer.h:144
@ h_l
Definition: cs_field_pointer.h:202
@ p
Definition: cs_field_pointer.h:67
@ ym_w
Definition: cs_field_pointer.h:200
@ f4m
Definition: cs_field_pointer.h:146
@ d32
Definition: cs_field_pointer.h:224
@ xlam
Definition: cs_field_pointer.h:183
@ coyfp
Definition: cs_field_pointer.h:137
@ energy_f
Definition: cs_field_pointer.h:121
@ mol_mass
Definition: cs_field_pointer.h:194
@ elefl
Definition: cs_field_pointer.h:170
@ gamma
Definition: cs_field_pointer.h:221
@ yfm
Definition: cs_field_pointer.h:135
@ qfpxx
Definition: cs_field_pointer.h:212
@ f2m
Definition: cs_field_pointer.h:145
@ qfp
Definition: cs_field_pointer.h:211
@ elast
Definition: cs_field_pointer.h:242
@ nusa
Definition: cs_field_pointer.h:81
@ thermal_diff_l
Definition: cs_field_pointer.h:205
@ k
@ tau12_t
Definition: cs_field_pointer.h:231
@ pot_t
Definition: cs_field_pointer.h:123
@ h_tot
Definition: cs_field_pointer.h:95
@ vel_rel
Definition: cs_field_pointer.h:238
@ emissivity
Definition: cs_field_pointer.h:185
@ mu
Definition: cs_field_pointer.h:103
@ rad_ck_up
Definition: cs_field_pointer.h:191
@ yno
Definition: cs_field_pointer.h:155
@ qfpzy
Definition: cs_field_pointer.h:219
@ eps
Definition: cs_field_pointer.h:71
@ radsc
Definition: cs_field_pointer.h:164
@ xch
Definition: cs_field_pointer.h:140
@ xwt
Definition: cs_field_pointer.h:142
@ ntdrp
Definition: cs_field_pointer.h:125
@ rad_est
Definition: cs_field_pointer.h:175
@ add_var
Definition: cs_field_pointer.h:246
@ c_alpha
Definition: cs_field_pointer.h:243
@ cv
Definition: cs_field_pointer.h:101
@ magfl
Definition: cs_field_pointer.h:169
@ fp2m
Definition: cs_field_pointer.h:129
@ lift
Definition: cs_field_pointer.h:232
@ hybrid_blend
Definition: cs_field_pointer.h:84
@ f8m
Definition: cs_field_pointer.h:150
@ t_poro
Definition: cs_field_pointer.h:111
@ curre
Definition: cs_field_pointer.h:166
@ joulp
Definition: cs_field_pointer.h:163
@ qfpyz
Definition: cs_field_pointer.h:217
@ qinci
Definition: cs_field_pointer.h:181
@ t_kelvin
Definition: cs_field_pointer.h:115
@ ygfm
Definition: cs_field_pointer.h:133
@ dt_dp
Definition: cs_field_pointer.h:239
@ disp_t
Definition: cs_field_pointer.h:233
@ curim
Definition: cs_field_pointer.h:167
@ surf_tens
Definition: cs_field_pointer.h:234
@ potva
Definition: cs_field_pointer.h:161
@ drho_dp
Definition: cs_field_pointer.h:229
@ ycoel
Definition: cs_field_pointer.h:162
@ vel
@ wlubr
Definition: cs_field_pointer.h:227
@ cp
Definition: cs_field_pointer.h:100
@ poti
Definition: cs_field_pointer.h:160
@ xck
Definition: cs_field_pointer.h:141
@ humid
Definition: cs_field_pointer.h:199
@ qinsp
Definition: cs_field_pointer.h:182
@ rad_lumin
Definition: cs_field_pointer.h:172
@ qfpxy
Definition: cs_field_pointer.h:213
@ h
Definition: cs_field_pointer.h:91
@ drho_dh
Definition: cs_field_pointer.h:230
@ f9m
Definition: cs_field_pointer.h:151
@ qp
Definition: cs_field_pointer.h:210
@ e_tot
Definition: cs_field_pointer.h:94
@ th_diff_t
Definition: cs_field_pointer.h:228
@ rad_ck_down
Definition: cs_field_pointer.h:192
@ pack_zone_id
Definition: cs_field_pointer.h:206
@ poro
Definition: cs_field_pointer.h:109
@ rad_cak
Definition: cs_field_pointer.h:179
@ np
Definition: cs_field_pointer.h:139
@ yco2
Definition: cs_field_pointer.h:153
@ f7m
Definition: cs_field_pointer.h:149
@ vism
Definition: cs_field_pointer.h:117
@ rad_abs
Definition: cs_field_pointer.h:177
@ rad_emi
Definition: cs_field_pointer.h:178
@ rad_ist
Definition: cs_field_pointer.h:176
@ fdown
Definition: cs_field_pointer.h:190
@ omg
Definition: cs_field_pointer.h:80
@ f5m
Definition: cs_field_pointer.h:147
@ fsm
Definition: cs_field_pointer.h:131
@ fnet
Definition: cs_field_pointer.h:186
@ rho
@ f6m
Definition: cs_field_pointer.h:148
@ drag
Definition: cs_field_pointer.h:225
@ yplus
Definition: cs_field_pointer.h:236
@ epa
Definition: cs_field_pointer.h:184
@ coldiff
Definition: cs_field_pointer.h:241
@ rij
Definition: cs_field_pointer.h:73
@ yf_ncond
Definition: cs_field_pointer.h:209
@ yfp2m
Definition: cs_field_pointer.h:136
@ potr
Definition: cs_field_pointer.h:159
@ h2
Definition: cs_field_pointer.h:143
@ laplf
Definition: cs_field_pointer.h:168
@ yhcn
Definition: cs_field_pointer.h:154
@ rho_b
@ hconv
Definition: cs_field_pointer.h:188
@ elech
Definition: cs_field_pointer.h:165
@ kindiff
Definition: cs_field_pointer.h:240
@ thermal_diff_h
Definition: cs_field_pointer.h:204
@ x2
Definition: cs_field_pointer.h:223
@ phi
Definition: cs_field_pointer.h:75
@ fup
Definition: cs_field_pointer.h:189
@ dt
@ if_poro
Definition: cs_field_pointer.h:110
@ t_l
Definition: cs_field_pointer.h:201
@ totwt
Definition: cs_field_pointer.h:124
@ CS_FIELD_N_POINTERS
Definition: cs_field_pointer.h:253
@ f_bar
Definition: cs_field_pointer.h:76
@ y_l_pack
Definition: cs_field_pointer.h:203
@ t_b
Definition: cs_field_pointer.h:93
@ chemistry
Definition: cs_field_pointer.h:126
@ mu_t
Definition: cs_field_pointer.h:104
@ rad_q
Definition: cs_field_pointer.h:173
@ void_f
Definition: cs_field_pointer.h:88
@ ad_mass
Definition: cs_field_pointer.h:226
@ fvp2m
Definition: cs_field_pointer.h:152
@ vol_f
Definition: cs_field_pointer.h:89
@ lambda
Definition: cs_field_pointer.h:106
@ qfpxz
Definition: cs_field_pointer.h:214
@ fm
Definition: cs_field_pointer.h:128
@ th_diff
Definition: cs_field_pointer.h:107
@ qfpyy
Definition: cs_field_pointer.h:216
@ qfpzz
Definition: cs_field_pointer.h:220
@ ia
Definition: cs_field_pointer.h:222
@ fconv
Definition: cs_field_pointer.h:187
@ mesh_u
Definition: cs_field_pointer.h:86
@ qfpyx
Definition: cs_field_pointer.h:215
@ hox
Definition: cs_field_pointer.h:157
void cs_field_pointer_destroy_all(void)
Definition: cs_field_pointer.c:186
void cs_field_pointer_map_base(void)
Definition: cs_field_pointer.c:277
struct cs_field_pointer_array_t * cs_glob_field_pointers
Definition: cs_field_pointer.c:130
void cs_field_pointer_map_compressible(void)
Map base fields to enumerated pointers for compressible model.
Definition: cs_field_pointer.c:460
void cs_field_pointer_map_gas_mix(void)
Map base fields to enumerated pointers for gas mix model.
Definition: cs_field_pointer.c:497
void cs_field_pointer_map(cs_field_pointer_id_t e, cs_field_t *f)
Definition: cs_field_pointer.c:210
void cs_field_pointer_map_groundwater(void)
Map base fields to enumerated pointers for groundwater flows.
Definition: cs_field_pointer.c:544
Definition: cs_field_pointer.h:259
cs_field_t * f
Definition: cs_field_pointer.h:260
cs_field_t ** p
Definition: cs_field_pointer.h:261
Definition: cs_field.h:130
