8.0
cs_field_pointer.h File Reference
+ Include dependency graph for cs_field_pointer.h:
Data Structures
struct  cs_field_pointer_array_t
Macros
#define CS_ENUMF_(e)   CS_FIELD_POINTER_ ## e
 Macro used for scoping of field pointer enums. More...
#define CS_F_(e)   cs_glob_field_pointers[CS_FIELD_POINTER_ ## e].f
 Macro used to return a field pointer by its enumerated value. More...
#define CS_FI_(e, i)   cs_glob_field_pointers[CS_FIELD_POINTER_ ## e].p[i]
Enumerations
enum  cs_field_pointer_id_t {
  dt , p , vel , k ,
  eps , rij , phi , f_bar ,
  alp_bl , omg , nusa , hybrid_blend ,
  mesh_u , void_f , vol_f , h ,
  t , t_b , e_tot , h_tot ,
  rho , rho_b , cp , cv ,
  mu , mu_t , lambda , th_diff ,
  poro , if_poro , t_poro , t_kelvin ,
  vism , volume_f , mass_f , energy_f ,
  pot_t , totwt , ntdrp , chemistry ,
  fm , fp2m , fsm , npm ,
  ygfm , yfm , yfp2m , coyfp ,
  np , xch , xck , xwt ,
  h2 , f1m , f2m , f4m ,
  f5m , f6m , f7m , f8m ,
  f9m , fvp2m , yco2 , yhcn ,
  yno , ynh3 , hox , potr ,
  poti , potva , ycoel , joulp ,
  radsc , elech , curre , curim ,
  laplf , magfl , elefl , rad_lumin ,
  rad_q , rad_est , rad_ist , rad_abs ,
  rad_emi , rad_cak , qinci , qinsp ,
  xlam , epa , emissivity , fnet ,
  fconv , hconv , fup , fdown ,
  rad_ck_up , rad_ck_down , mol_mass , head ,
  humid , ym_w , t_l , h_l ,
  y_l_pack , thermal_diff_h , thermal_diff_l , pack_zone_id ,
  yf_ncond , qp , qfp , qfpxx ,
  qfpxy , qfpxz , qfpyx , qfpyy ,
  qfpyz , qfpzx , qfpzy , qfpzz ,
  gamma , ia , x2 , d32 ,
  drag , ad_mass , wlubr , th_diff_t ,
  drho_dp , drho_dh , tau12_t , lift ,
  disp_t , surf_tens , drift_vel , yplus ,
  vel_mean , vel_rel , dt_dp , kindiff ,
  coldiff , elast , c_alpha , add_var ,
  user , CS_FIELD_N_POINTERS
void cs_field_pointer_ensure_init (void)
 Ensure field pointer array is initialized. More...
void cs_field_pointer_destroy_all (void)
 Free all field pointer data. More...
void cs_field_pointer_map (cs_field_pointer_id_t e, cs_field_t *f)
 Map a simple field to an enumerated pointer. More...
void cs_field_pointer_map_indexed (cs_field_pointer_id_t e, int index, cs_field_t *f)
 Map a field to an (enumerated pointer, index) couple. More...
void cs_field_pointer_map_base (void)
 Map base fields to enumerated pointers. More...
void cs_field_pointer_map_boundary (void)
 Map some boundary fields to enumerated pointers. More...
void cs_field_pointer_map_atmospheric (int n_chem_species, const int species_f_id[])
 Map base fields to enumerated pointers for atmospheric models. More...
void cs_field_pointer_map_coal_combustion (int n_coals, int n_classes)
 Map base fields to enumerated pointers for coal combustion. More...
void cs_field_pointer_map_compressible (void)
 Map base fields to enumerated pointers for compressible model. More...
void cs_field_pointer_map_gas_mix (void)
 Map base fields to enumerated pointers for gas mix model. More...
void cs_field_pointer_map_gas_combustion (void)
 Map base fields to enumerated pointers for gas combustion. More...
void cs_field_pointer_map_groundwater (void)
 Map base fields to enumerated pointers for groundwater flows. More...
struct cs_field_pointer_array_tcs_glob_field_pointers
◆ CS_ENUMF_
CS_ENUMF_ (   e)    CS_FIELD_POINTER_ ## e
This macro replaces CS_ENUMF_ by CS_FIELD_POINTER_ and allows to rebuild a full enumerated field pointer id.
[in]esuffix of enumerated field pointer id.
◆ CS_F_
CS_F_ (   e)    cs_glob_field_pointers[CS_FIELD_POINTER_ ## e].f
This macro replaces CS_F_ by an access to the global array of field pointers cs_glob_field_pointers using a rebuilt enumerated field pointer id.
◆ CS_FI_
CS_FI_ (   e,
This macro replaces CS_FI_ by an access to the global array of field pointers cs_glob_field_pointers using a rebuilt enumerated field pointer id and its field sublist index.
[in]ifield enumerator value.
◆ cs_field_pointer_id_t
Suffixes of enumerated field pointer ids, arguments of the macro CS_F_().
Enumerator
dt
local time step
pressure
vel
velocity
turbulent kinetic energy $ k $
eps
turbulent dissipation $ \varepsilon $
rij
Reynolds stress tensor $ R_{ij} $
phi
$ \phi $ for $ \phi-f_b $ model
f_bar
$ f_b $ for $ \phi-f_b $ model
alp_bl
$ \alpha $ for $ Bl-v^2-k $ or EBRSM model
omg
$ \omega $ for $ k-\omega $ SST model
nusa
$ \widetilde{\nu}_T $ for Spalart- Allmaras
hybrid_blend
Blending factor for DDES
mesh_u
mesh velocity
void_f
void fraction
vol_f
volume fraction
enthalpy
temperature
t_b
temperature (at boundary faces)
e_tot
total energy
h_tot
total enthalpy
rho
density (at cells)
rho_b
density (at boundary faces)
cp
isobaric specific heat
cv
isochoric specific heat
mu
molecular viscosity
mu_t
turbulent dynamic viscosity
lambda
Thermal conductivity
th_diff
Thermal diffusivity
poro
porosity
if_poro
internal faces porosity
t_poro
tensorial porosity
t_kelvin
temperature, in Kelvin
vism
mesh viscosity
volume_f
homogeneous model volume fraction
mass_f
homogeneous model mass fraction
energy_f
homogeneous model energy fraction
pot_t
potential temperature
totwt
total water content
ntdrp
total number of droplets
chemistry
chemistry species (indexed)
fm
mixture fraction
fp2m
mixture fraction variance
fsm
soot mass fraction
npm
soot precursor number
ygfm
fresh gas fraction
yfm
mass fraction
yfp2m
mass fraction variance
coyfp
mass fraction covariance
np
particles per kg for coal class
xch
reactive coal mass fraction for coal class
xck
coke mass fraction for coal class
xwt
water mass fraction for coal class
h2
mass enthalpy for coal class (permeatic case)
f1m
mean value light volatiles for coal class
f2m
mean value heavy volatiles for coal class
f4m
oxydant 2 mass fraction
f5m
oxydant 3 mass fraction
f6m
water from coal drying mass fraction
f7m
carbon from coal oxidyzed by O2 mass fraction
f8m
carbon from coal gasified by CO2 mass fraction
f9m
carbon from coal gasified by H2O mass fraction
fvp2m
f1f2 variance
yco2
CO2 fraction
yhcn
HCN fraction
yno
NO fraction
ynh3
NH3 enthalpy
hox
Ox enthalpy
potr
Electric potential, real part
poti
Electric potential, imaginary part
potva
Vector potential
ycoel
Constituent mass fraction
joulp
Joule power
radsc
radiation source
elech
electric charge
curre
current real
curim
current imaginary
laplf
laplace forces
magfl
magnetic field
elefl
electric field
rad_lumin
Radiative luminance
rad_q
Radiative flux
rad_est
Radiative flux explicit source term
rad_ist
Radiative flux implicit source term
rad_abs
Radiative absorption
rad_emi
Radiative emission
rad_cak
Radiative absorption coefficient
qinci
Radiative incident radiative flux density
qinsp
Spectral radiative incident flux
xlam
Wall thermal conductivity
epa
Wall thickness
emissivity
Wall emissivity
fnet
Boundary radiative flux
fconv
Boundary radiative convective flux
hconv
radiative exchange coefficient
fup
Spectral upward radiative flux
fdown
Spectral downward radiative flux
rad_ck_up
Spectral upward Radiative absorption coefficient
rad_ck_down
Spectral downward Radiative absorption coefficient
mol_mass
gas mix molar max
head
hydraulic head
humid
Humidity
ym_w
Mass fraction of dry air in humid air
t_l
Injected liquid water temperature
h_l
Injected liquid water enthalpy
y_l_pack
Mass of liquid per unit volume of cell
thermal_diff_h
Humid air thermal diffusivity
thermal_diff_l
Injected liquid water thermal diffusivity
pack_zone_id
Id of the packing zone
yf_ncond
non-condensable mass fraction
qp
Turbulent Kinetic Energy q2
qfp
Covariance q12
qfpxx
XX component of qfp
qfpxy
XY component of qfp
qfpxz
XZ component of qfp
qfpyx
YX component of qfp
qfpyy
YY component of qfp
qfpyz
YZ component of qfp
qfpzx
ZX component of qfp
qfpzy
ZY component of qfp
qfpzz
ZZ component of qfp
gamma
Interfacial mass transfer
ia
Interfacial area
x2
x2 for droplets
d32
Sauter diameter
drag
Phases drag
ad_mass
Added mass
wlubr
Wall lubrication
th_diff_t
Turbulent thermal diffusivity
drho_dp
drho over dp
drho_dh
drho over dh
tau12_t
turbulent tau12
lift
Lift coefficient
disp_t
Turbulent dispersion
surf_tens
Surface tension
drift_vel
Particles drift velocity
yplus
Wall distance: y+
vel_mean
Mean velocity (for dispersed phases)
vel_rel
Relative velocity (for dispersed phases)
dt_dp
dtemp/dpress derivative
kindiff
Particles kinetic diffusivity
coldiff
Particles collisional diffusivity
elast
Particles restitution coefficient
c_alpha
Ponderation coefficient for GEMMA model
add_var
User added variables
user
CS_FIELD_N_POINTERS
◆ cs_field_pointer_destroy_all()
void cs_field_pointer_destroy_all ( void  )
◆ cs_field_pointer_ensure_init()
void cs_field_pointer_ensure_init ( void  )
◆ cs_field_pointer_map()
void cs_field_pointer_map ( cs_field_pointer_id_t  e,
cs_field_t f
The associated field pointer may then be retreived using CS_F_(e).
[in]efield enumerator value
[in]fpointer to field structure
◆ cs_field_pointer_map_atmospheric()
void cs_field_pointer_map_atmospheric ( int  n_chem_species,
[in]n_chem_speciesnumber of chemical species
[in]species_f_idfield id for each chemical species
◆ cs_field_pointer_map_base()
void cs_field_pointer_map_base ( void  )
◆ cs_field_pointer_map_boundary()
void cs_field_pointer_map_boundary ( void  )
◆ cs_field_pointer_map_coal_combustion()
void cs_field_pointer_map_coal_combustion ( int  n_coals,
int  n_classes
[in]n_coalsnumber of coals
[in]n_classesnumber of coal classes
◆ cs_field_pointer_map_compressible()
void cs_field_pointer_map_compressible ( void  )
◆ cs_field_pointer_map_gas_combustion()
void cs_field_pointer_map_gas_combustion ( void  )
◆ cs_field_pointer_map_gas_mix()
void cs_field_pointer_map_gas_mix ( void  )
◆ cs_field_pointer_map_groundwater()
void cs_field_pointer_map_groundwater ( void  )
◆ cs_field_pointer_map_indexed()
void cs_field_pointer_map_indexed ( cs_field_pointer_id_t  e,
int  index,
cs_field_t f
This sort of mapping may be used for sets of fields whose size is not known in advance.
The associated field pointer may then be retreived using CS_FI_(e, i).
[in]indexfield enumerator index
◆ cs_glob_field_pointers
struct cs_field_pointer_array_t* cs_glob_field_pointers
extern
