1 #ifndef __CS_VELOCITY_PRESSURE_H__
2 #define __CS_VELOCITY_PRESSURE_H__
Definition: cs_defs.h:509
cs_velocity_pressure_model_t cs_stokes_model_t
Definition: cs_velocity_pressure.h:177
cs_velocity_pressure_model_t * cs_get_glob_velocity_pressure_model(void)
Definition: cs_velocity_pressure.c:463
void cs_velocity_pressure_set_n_buoyant_scalars(void)
Definition: cs_velocity_pressure.c:491
void cs_velocity_pressure_param_log_setup(void)
Print Velocity-pressure parameters to setup.log.
Definition: cs_velocity_pressure.c:615
cs_velocity_pressure_param_t cs_piso_t
Definition: cs_velocity_pressure.h:178
cs_velocity_pressure_param_t * cs_get_glob_velocity_pressure_param(void)
Provide access to cs_glob_velocity_pressure_param.
Definition: cs_velocity_pressure.c:479
void cs_velocity_pressure_set_solid(void)
Definition: cs_velocity_pressure.c:515
const cs_velocity_pressure_param_t * cs_glob_velocity_pressure_param
const cs_velocity_pressure_model_t * cs_glob_velocity_pressure_model
void cs_velocity_pressure_model_log_setup(void)
Print the stokes model parameters to setup.log.
Definition: cs_velocity_pressure.c:536
Stokes equation model descriptor.
Definition: cs_velocity_pressure.h:51
int ivisse
Definition: cs_velocity_pressure.h:53
int idilat
Definition: cs_velocity_pressure.h:58
int n_buoyant_scal
Definition: cs_velocity_pressure.h:71
bool fluid_solid
Definition: cs_velocity_pressure.h:67
int iprcdo
Definition: cs_velocity_pressure.h:74
Inner velocity/pressure iteration options descriptor.
Definition: cs_velocity_pressure.h:84
int icalhy
Definition: cs_velocity_pressure.h:94
int irevmc
Definition: cs_velocity_pressure.h:110
double arak
Definition: cs_velocity_pressure.h:144
double epsdp
Definition: cs_velocity_pressure.h:171
double xnrmu
Definition: cs_velocity_pressure.h:164
int iifren
Definition: cs_velocity_pressure.h:114
int ipredfl
Definition: cs_velocity_pressure.h:105
int nterup
Definition: cs_velocity_pressure.h:157
double xnrmu0
Definition: cs_velocity_pressure.h:169
int ipucou
Definition: cs_velocity_pressure.h:136
int rcfact
Definition: cs_velocity_pressure.h:147
int igpust
Definition: cs_velocity_pressure.h:130
int iprco
Definition: cs_velocity_pressure.h:100
double epsup
Definition: cs_velocity_pressure.h:160
int igprij
Definition: cs_velocity_pressure.h:125
int iphydr
Definition: cs_velocity_pressure.h:86
int staggered
Definition: cs_velocity_pressure.h:152
int irecmf
Definition: cs_velocity_pressure.h:118
int itpcol
Definition: cs_velocity_pressure.h:140
