8.0
cs_velocity_pressure.h File Reference
+ Include dependency graph for cs_velocity_pressure.h:
Data Structures
struct  cs_velocity_pressure_model_t
 Stokes equation model descriptor. More...
struct  cs_velocity_pressure_param_t
 Inner velocity/pressure iteration options descriptor. More...
Typedefs
typedef cs_velocity_pressure_model_t cs_stokes_model_t
typedef cs_velocity_pressure_param_t cs_piso_t
cs_velocity_pressure_model_tcs_get_glob_velocity_pressure_model (void)
cs_velocity_pressure_param_tcs_get_glob_velocity_pressure_param (void)
 Provide access to cs_glob_velocity_pressure_param. More...
void cs_velocity_pressure_set_n_buoyant_scalars (void)
void cs_velocity_pressure_set_solid (void)
void cs_velocity_pressure_model_log_setup (void)
 Print the stokes model parameters to setup.log. More...
void cs_velocity_pressure_param_log_setup (void)
 Print Velocity-pressure parameters to setup.log. More...
const cs_velocity_pressure_model_tcs_glob_velocity_pressure_model
const cs_velocity_pressure_param_tcs_glob_velocity_pressure_param
Typedef Documentation
◆ cs_piso_t
◆ cs_stokes_model_t
◆ cs_get_glob_velocity_pressure_model()
cs_velocity_pressure_model_t* cs_get_glob_velocity_pressure_model ( void  )
◆ cs_get_glob_velocity_pressure_param()
cs_velocity_pressure_param_t* cs_get_glob_velocity_pressure_param ( void  )
velocity_pressure_param information structure
◆ cs_velocity_pressure_model_log_setup()
void cs_velocity_pressure_model_log_setup ( void  )
◆ cs_velocity_pressure_param_log_setup()
void cs_velocity_pressure_param_log_setup ( void  )
◆ cs_velocity_pressure_set_n_buoyant_scalars()
void cs_velocity_pressure_set_n_buoyant_scalars ( void  )
◆ cs_velocity_pressure_set_solid()
void cs_velocity_pressure_set_solid ( void  )
◆ cs_glob_velocity_pressure_model
const cs_velocity_pressure_model_t* cs_glob_velocity_pressure_model
extern
◆ cs_glob_velocity_pressure_param
const cs_velocity_pressure_param_t* cs_glob_velocity_pressure_param
extern
