8.0
cs_physical_constants.h
1 #ifndef __CS_PHYSICAL_CONSTANTS_H__
2 #define __CS_PHYSICAL_CONSTANTS_H__
5  * Base physical constants data.
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
45  * Type definitions
48 /* physical constants descriptor */
49 /*-------------------------------*/
50
51 typedef struct {
52
53  cs_real_t gravity[3]; /* gravity vector in m.s^-2 */
54  int icorio; /* Coriolis source terms indicator */
55
57
58 /* fluid properties descriptor */
59 /*-----------------------------*/
60
61 typedef struct {
62
63  int ixyzp0; /* indicator for filling of reference point for
64  total pressure */
65  int icp; /* property index of the isobaric specific heat */
66  int icv; /* property index of the isochoric specific
67  heat */
68  int irovar; /* variable density field */
69  int ivivar; /* variable viscosity field */
70  int ivsuth; /* Sutherland law for laminar viscosity and
71  thermal conductivity in gas mix spec. phys. */
72  double ro0; /* reference density */
73  double viscl0; /* reference molecular dynamic viscosity */
74  double viscv0; /* reference volume viscosity
75  (for compressible model) */
76  double p0; /* reference pressure for the total pressure */
77  double pred0; /* reference value for the reduced pressure */
78  double xyzp0[3]; /* reference point coordinates for the total
79  pressure */
80  double t0; /* reference temperature */
81  double cp0; /* reference specific heat at constant pressure */
82  double cv0; /* reference specific heat at constant volume */
83  double lambda0; /* reference heat conductivity */
84
85  double r_pg_cnst; /* perfect gas specific constant in J/kg/K */
86  double rvsra; /* ratio gas constant h2o / dry air */
87  double clatev; /* latent heat of evaporation */
88  double xmasmr; /* molar mass of the perfect gas in kg/mol
89  (if ieos=1) */
90  int ipthrm; /* uniform variable thermodynamic pressure for the
91  low-Mach algorithm */
92  double pther; /* uniform thermodynamic pressure for the low-Mach
93  algorithm */
94  double pthera; /* thermodynamic pressure for the previous time
95  step */
96  double pthermax; /* thermodynamic maximum pressure for user
97  clipping, used to model a venting effect */
98  double sleak; /* leak surface */
99  double kleak; /* leak head loss (2.9 by default, from Idelcick) */
100  double roref; /* Initial reference density */
101
103
104 /*============================================================================
105  * Static global variables
106  *============================================================================*/
107
108 /* Physical constants */
109
110 extern const double cs_physical_constants_r; /* Ideal gas constant (J/mol/K) */
111 extern const double cs_physical_constants_kb; /* Boltzmann constant (J/K) */
112 extern const double cs_physical_constants_celsius_to_kelvin; /* Celsius to
113  Kelvin*/
114 extern const double cs_physical_constants_stephan; /* Stephan constant
115  (W/m2/K4)*/
116 extern const double cs_physical_constants_avogadro; /* Avogadro constant
117  (1/mol) */
118
119 /* Pointer to main physical constants structure */
120
122
123 /* Pointer to main fluid properties structure */
124
126
127 /*=============================================================================
128  * Public function prototypes
129  *============================================================================*/
130
131 /*----------------------------------------------------------------------------
132  * Provide access to cs_glob_physical_constants
133  *
134  * needed to initialize structure with GUI
135  *----------------------------------------------------------------------------*/
136
139
140 /*----------------------------------------------------------------------------
141  * Provide access to cs_glob_fluid_properties
142  *
143  * needed to initialize structure with GUI
144  *----------------------------------------------------------------------------*/
145
148
149 /*----------------------------------------------------------------------------
150  * Print the physical constants structure to setup.log.
151  *----------------------------------------------------------------------------*/
152
153 void
155
156 /*----------------------------------------------------------------------------
157  * Print the fluid properties structure to setup.log.
158  *----------------------------------------------------------------------------*/
159
160 void
162
163 /*----------------------------------------------------------------------------*/
164
166
167 #endif /* __CS_PHYSICAL_CONSTANTS_H__ */
Definition: cs_defs.h:509
Definition: cs_defs.h:319
Definition: cs_physical_constants.c:393
void cs_physical_constants_log_setup(void)
Definition: cs_physical_constants.c:629
Definition: cs_physical_constants.c:380
cs_physical_constants_t * cs_get_glob_physical_constants(void)
Definition: cs_physical_constants.c:604
Definition: cs_physical_constants.c:384
Definition: cs_physical_constants.c:388
Definition: cs_physical_constants.c:397
Definition: cs_physical_constants.c:404
cs_fluid_properties_t * cs_get_glob_fluid_properties(void)
Definition: cs_physical_constants.c:617
const cs_physical_constants_t * cs_glob_physical_constants
Definition: cs_physical_constants.c:401
void cs_fluid_properties_log_setup(void)
Definition: cs_physical_constants.c:661
real(c_double), dimension(:), pointer, save xyzp0
coordinates of the reference point for the total pressure.
Definition: cstphy.f90:206
Fluid properties descriptor.
int ivivar
Definition: cs_physical_constants.h:69
double kleak
Definition: cs_physical_constants.h:99
double viscl0
Definition: cs_physical_constants.h:73
int icp
Definition: cs_physical_constants.h:65
double pthermax
Definition: cs_physical_constants.h:96
double sleak
Definition: cs_physical_constants.h:98
double ro0
Definition: cs_physical_constants.h:72
double cv0
Definition: cs_physical_constants.h:82
double pthera
Definition: cs_physical_constants.h:94
double viscv0
Definition: cs_physical_constants.h:74
double r_pg_cnst
Definition: cs_physical_constants.h:85
double xmasmr
Definition: cs_physical_constants.h:88
double rvsra
Definition: cs_physical_constants.h:86
int irovar
Definition: cs_physical_constants.h:68
double pred0
Definition: cs_physical_constants.h:77
int ipthrm
Definition: cs_physical_constants.h:90
int ixyzp0
Definition: cs_physical_constants.h:63
int icv
Definition: cs_physical_constants.h:66
double pther
Definition: cs_physical_constants.h:92
double clatev
Definition: cs_physical_constants.h:87
double t0
Definition: cs_physical_constants.h:80
double cp0
Definition: cs_physical_constants.h:81
double lambda0
Definition: cs_physical_constants.h:83
double roref
Definition: cs_physical_constants.h:100
double p0
Definition: cs_physical_constants.h:76
int ivsuth
Definition: cs_physical_constants.h:70
Physical constants descriptor.
Definition: cs_physical_constants.h:51
int icorio
Definition: cs_physical_constants.h:54
