file | atchem.f90 |
| Module for chemistry in the atmospheric module.
file | atimbr.f90 |
| Atmospheric Imbrication module. This module contains the data structure and subroutines to perform atmospheric imbrication or nesting of a CFD domain within a large scale meteorological field. Starting from a set of large scale meteological profiles (in the format of meteo files) an interpolation is performed for each boundary face both spatially and temporally (using Cressman method)
file | atincl.f90 |
| Module for atmospheric models - main variables.
file | atini1.f90 |
| Initialisation of variable options for the atmospheric module in addition to what is done in usipsu function.
file | atiniv.f90 |
| Initialisation of calculation variables for the atmospheric module, it is the counterpart of usiniv.f90.
file | atleca.f90 |
| Reads initial aerosol concentration and number.
file | atlecc.f90 |
| Reads the chemistry profile data for the atmospheric chemistry.
file | atlecm.f90 |
| Reads the meteo profile data for the atmospheric module.
file | atmcls.f90 |
| Compute friction velocity u* and surface sensible heat flux q0 for a non neutral atmospheric surface layer using the explicit formula developed for the ECMWF by Louis (1982)
file | atmsol.f90 |
| build constants and variables to describe ground model
file | atphyv.f90 |
| Functions that compute physical variables for each cell for the atmospheric module.
file | atprop.f90 |
| Add if needed the variables fields for temperature and liquid water.
file | atr1vf.f90 |
| Compute radiative fluxes for the atmospheric model. Computes the source term for scalar equations from radiative forcing (UV and IR radiative fluxes) with a 1D scheme.
file | atsoil.f90 |
| Module for the atmospheric soil model adapted to the IGN "land use" file format.
file | attssc.f90 |
| Additional right-hand side source terms for scalar equations taking into account dry and humid atmospheric variables. If 1D atmospheric radiative module is used (iatra1 = 1) additional source terms for the thermal scalar equation to take into account the radiative forcing.
file | attycl.f90 |
| Automatic boundary conditions for atmospheric module (based on meteo file)
file | atvarp.f90 |
| Declare additional transported variables for atmospheric module.
file | chem_luscheme1.f90 |
| Routines for atmospheric chemical scheme 1.
file | chem_luscheme2.f90 |
| Routines for atmospheric chemical scheme 2.
file | chem_luscheme3.f90 |
| Routines for atmospheric chemical scheme 3.
file | chem_roschem.f90 |
| Rosenbrock solver for atmospheric chemistry.
file | chem_solvelu.f90 |
| Solver of AX=B with LU decomposition of A for atmospheric chemical systems.
file | chem_source_terms.f90 |
| Computes the explicit chemical source term for atmospheric chemistry in case of a semi-coupled resolution.
file | compute_gaseous_chemistry.f90 |
| Calls the rosenbrock resolution for atmospheric chemistry.
file | cs_air_props.c |
file | cs_air_props.h [code] |
file | cs_at_data_assim.c |
file | cs_at_data_assim.h [code] |
file | cs_at_opt_interp.c |
file | cs_at_opt_interp.h [code] |
file | cs_at_source_terms.f90 |
file | cs_atmo.c |
file | cs_atmo.h [code] |
file | cs_atmo_aerosol.c |
file | cs_atmo_aerosol.h [code] |
file | cs_atmo_aerosol_ssh.c |
file | cs_atmo_aerosol_ssh.h [code] |
file | cs_atmo_profile_std.c |
file | cs_atmo_profile_std.h [code] |
file | cs_atprke.c |
file | cs_atprke.h [code] |
file | cs_intprf.c |
file | cs_intprf.h [code] |
file | kinrates.f90 |
| Calls the computation of reaction rates for atmospheric chemistry.
file | rayigc.f90 |
| Compute carbonic dioxide (CO2) and ozone (O3) absorption in infrared (1D radiative scheme).
file | rayir.f90 |
| Compute infrared flux divergence profile and downward flux at ground level relying on a 1D radiative scheme.
file | rayive.f90 |
| 1D Radiative scheme - IR H20 and dimere absorption
file | rayso.f90 |
file | solcat.f90 |
| Soil - atmosphere parameters computed from a "Land use" file.
file | soliva.f90 |
| Atmospheric soil module - soil variables initialisation.
file | solmoy.f90 |
| Atmospheric soil module - Initialize ground level parameters from land use.
file | solvar.f90 |
| Atmospheric soil module - Compute ground level variables.
file | spefun.f90 |
| Atmospheric module - Module for specific math functions.
file | sshaerosol.f90 |
| Module for aerosol chemistry in the atmospheric module.
