8.0
cs_atmo_aerosol_ssh.h
1 #ifndef __CS_ATMO_AEROSOL_SSH_H__
2 #define __CS_ATMO_AEROSOL_SSH_H__
5  * Main for atmospheric aerosols library SSH related functions
31  * PLE library headers
34 #include <ple_locator.h>
37  * Local headers
40 #include "fvm_nodal.h"
42 #include "cs_base.h"
43 #include "cs_halo.h"
44 #include "cs_mesh.h"
45 #include "cs_mesh_quantities.h"
46
47 /*----------------------------------------------------------------------------*/
48
50
52  * Local Macro definitions
54
55 /*============================================================================
56  * Type definitions
58
59 /*============================================================================
60  * Static global variables
62
63 /*============================================================================
64  * Public function definitions
65  *============================================================================*/
66
67 /*----------------------------------------------------------------------------*/
71 /*----------------------------------------------------------------------------*/
72
73 void
75
76 /*----------------------------------------------------------------------------*/
81
82 void
84
86 /*
87  * \brief This function computes the number of aerosols using the given array
88  */
89 /*----------------------------------------------------------------------------*/
90
91 void
93
94 /*----------------------------------------------------------------------------*/
105 /*----------------------------------------------------------------------------*/
106
107 void
109  cs_real_t *P,
110  cs_real_t *yw);
111
117 /*----------------------------------------------------------------------------*/
118
119 void
121
128
129 void
131
132 /*----------------------------------------------------------------------------*/
137 /*----------------------------------------------------------------------------*/
138
139 void
141
142 /*----------------------------------------------------------------------------*/
147 /*----------------------------------------------------------------------------*/
148
149 void
151
152 /*----------------------------------------------------------------------------*/
157 /*----------------------------------------------------------------------------*/
158
159 void
161
163
164 #endif /* __CS_ATMO_AEROSOL_SSH_H__ */
void cs_atmo_aerosol_ssh_initialize(void)
This function initializes SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.c:341
void cs_atmo_aerosol_ssh_get_aero(cs_real_t *)
This function fills the given array with aerosol concentrations and numbers from SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.c:670
void cs_atmo_aerosol_ssh_set_gas(cs_real_t *)
This function uses the given array to update the gas concentrations in SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.c:712
void cs_atmo_aerosol_ssh_time_advance(void)
This function computes a time step of gaseous chemistry and aerosols dynamic using SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.c:763
void cs_atmo_aerosol_ssh_compute_numbers(cs_real_t *)
This function computes the number of aerosols using the given array.
Definition: cs_atmo_aerosol_ssh.c:558
void cs_atmo_aerosol_ssh_finalize(void)
This function finalizes SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.c:533
void cs_atmo_aerosol_ssh_get_gas(cs_real_t *)
This function fills the given array with gas concentrations from SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.c:736
void cs_atmo_aerosol_ssh_set_t_p_h(cs_real_t *T, cs_real_t *P, cs_real_t *yw)
This function takes as input absolute temperature T total pressure P water mass fraction yw It comput...
Definition: cs_atmo_aerosol_ssh.c:601
void cs_atmo_aerosol_ssh_set_aero(cs_real_t *)
This function uses the given array to update the aerosol concentrations and numbers in SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.c:638
Definition: cs_defs.h:509
Definition: cs_defs.h:319
