7.1
cs_turbomachinery.c File Reference
#include "fvm_selector.h"
#include "cs_interface.h"
#include "cs_boundary_zone.h"
#include "cs_coupling.h"
#include "cs_cell_to_vertex.h"
#include "cs_gradient.h"
#include "cs_gui.h"
#include "cs_gui_mesh.h"
#include "cs_gui_output.h"
#include "cs_join.h"
#include "cs_halo.h"
#include "cs_halo_perio.h"
#include "cs_mesh_coherency.h"
#include "cs_mesh_location.h"
#include "cs_mesh_to_builder.h"
#include "cs_multigrid.h"
#include "cs_post.h"
#include "cs_preprocess.h"
#include "cs_prototypes.h"
#include "cs_renumber.h"
#include "cs_rotation.h"
#include "cs_time_step.h"
#include "cs_timer.h"
#include "cs_timer_stats.h"
#include "cs_restart.h"
#include "cs_sat_coupling.h"
#include "cs_preprocessor_data.h"
#include "cs_volume_zone.h"
+ Include dependency graph for cs_turbomachinery.c:
void cs_turbomachinery_set_model (cs_turbomachinery_model_t model)
 Define rotor/stator model. More...
cs_turbomachinery_model_t cs_turbomachinery_get_model (void)
 Return rotor/stator model. More...
void cs_turbomachinery_add_rotor (const char *cell_criteria, double rotation_velocity, const double rotation_axis[3], const double rotation_invariant[3])
 Define a rotor by its axis and cell selection criteria. More...
int cs_turbomachinery_join_add (const char *sel_criteria, float fraction, float plane, int verbosity, int visualization)
 Add a cs_join_t structure to the list of rotor/stator joinings. More...
int cs_turbomachinery_coupling_add (const char *sel_criteria, float tolerance, int verbosity)
 Add a boundary coupling to the list of rotor/stator couplings. More...
void cs_turbomachinery_update_mesh (double t_cur_mob, double *t_elapsed)
 Update mesh for unsteady rotor/stator computation. More...
void cs_turbomachinery_restart_mesh (void)
 Update mesh for unsteady rotor/stator computation in case of restart. More...
void cs_turbomachinery_define (void)
 Definitions for turbomachinery computation. More...
void cs_turbomachinery_initialize (void)
 Initializations for turbomachinery computation. More...
void cs_turbomachinery_finalize (void)
 Free turbomachinery structure. More...
void cs_turbomachinery_reinit_i_face_fields (void)
 Reinitialize interior face-based fields. More...
void cs_turbomachinery_resize_cell_fields (void)
 Resize cell-based fields. More...
void cs_turbomachinery_rotation_matrix (int rotor_num, double theta, cs_real_t matrix[3][4])
 Compute rotation matrix. More...
int cs_turbomachinery_n_rotors (void)
 Return number of rotors. More...
const int * cs_turbomachinery_get_cell_rotor_num (void)
 Return cell rotor number. More...
double cs_turbomachinery_get_rotation_velocity (int rotor_num)
 Return rotation velocity. More...
void cs_turbomachinery_set_rotation_velocity (int rotor_num, double omega)
 Set rotation velocity. More...
void cs_turbomachinery_set_rotation_retry (int n_max_join_retries, double dt_retry_multiplier)
 Set turbomachinery joining retry parameters. More...
cs_real_34_tcs_turbomachinery_get_rotation_matrices (double dt)
 Build rotation matrices for a given time interval. More...
void cs_turbomachinery_rotate_fields (const cs_real_t dt[])
 Rotation of vector and tensor fields. More...
void cs_turbomachinery_relative_velocity (int rotor_num, const cs_real_t coords[3], cs_real_t velocity[3])
 Compute velocity relative to fixed coordinates at a given point. More...
void cs_turbomachinery_restart_read (cs_restart_t *r)
 Read turbomachinery metadata from restart file. More...
void cs_turbomachinery_restart_write (cs_restart_t *r)
 Write turbomachinery metadata to checkpoint file. More...
◆ cs_turbomachinery_add_rotor()
void cs_turbomachinery_add_rotor ( const char *  cell_criteria,
[in]cell_criteriacell selection criteria string
[in]rotation_velocityrotation velocity, in radians/second
[in]rotation_axisrotation axis vector
[in]rotation_invariantrotation invariant point
◆ cs_turbomachinery_coupling_add()
int cs_turbomachinery_coupling_add ( const char *  sel_criteria,
float  tolerance,
int  verbosity
[in]sel_criteriaboundary face selection criteria
[in]tolerancevalue of the search tolerance
[in]verbositylevel of verbosity required
number (1 to n) associated with new coupling
◆ cs_turbomachinery_define()
void cs_turbomachinery_define ( void  )
◆ cs_turbomachinery_finalize()
void cs_turbomachinery_finalize ( void  )
◆ cs_turbomachinery_get_cell_rotor_num()
const int* cs_turbomachinery_get_cell_rotor_num ( void  )
Each cell may be associated with a given rotor, or rotation, with 0 indicating that that cell does not rotate.
array defining rotor number associated with each cell (0 for none, 1 to n otherwise)
◆ cs_turbomachinery_get_model()
cs_turbomachinery_model_t cs_turbomachinery_get_model ( void  )
◆ cs_turbomachinery_get_rotation_matrices()
cs_real_34_t* cs_turbomachinery_get_rotation_matrices ( double  dt)
The caller is responsible for freeing the array when not needed.
[in]dtassociated time delta (0 for current, unmodified time)
array of rotation matrices.
◆ cs_turbomachinery_get_rotation_velocity()
double cs_turbomachinery_get_rotation_velocity ( int  rotor_num)
[in]rotor_numrotor number (1 to n numbering)
◆ cs_turbomachinery_initialize()
void cs_turbomachinery_initialize ( void  )
Note
This function should be called after the mesh is built, but before cs_post_init_meshes() so that postprocessing meshes are updated correctly in the transient case.
◆ cs_turbomachinery_join_add()
int cs_turbomachinery_join_add ( const char *  sel_criteria,
float  fraction,
float  plane,
int  verbosity,
int  visualization
[in]fractionvalue of the fraction parameter
[in]planevalue of the plane parameter
[in]visualizationlevel of visualization required
number (1 to n) associated with new joining
◆ cs_turbomachinery_n_rotors()
int cs_turbomachinery_n_rotors ( void  )
Note that the number of associated rotations is n_rotors + 1, as the first rotation id is reserved for the fixed portion of the domain.
number of rotors
◆ cs_turbomachinery_reinit_i_face_fields()
void cs_turbomachinery_reinit_i_face_fields ( void  )
◆ cs_turbomachinery_relative_velocity()
void cs_turbomachinery_relative_velocity ( int  rotor_num,
Deprecated:
Use cs_rotation_velocity for more consistent naming of this reference frame velocity.
[in]coordspoint coordinates
[out]velocityvelocity relative to fixed coordinates
◆ cs_turbomachinery_resize_cell_fields()
void cs_turbomachinery_resize_cell_fields ( void  )
This function only handles fields owning their values.
◆ cs_turbomachinery_restart_mesh()
void cs_turbomachinery_restart_mesh ( void  )
Reads mesh from checkpoint when available.
◆ cs_turbomachinery_restart_read()
void cs_turbomachinery_restart_read ( cs_restart_t r)
The mesh is handled separately.
[in,out]rassociated restart file pointer
◆ cs_turbomachinery_restart_write()
void cs_turbomachinery_restart_write ( cs_restart_t r)
◆ cs_turbomachinery_rotate_fields()
void cs_turbomachinery_rotate_fields ( const cs_real_t  dt[])
◆ cs_turbomachinery_rotation_matrix()
void cs_turbomachinery_rotation_matrix ( int  rotor_num,
double  theta,
[in]thetarotation angle, in radians
[out]matrixresulting rotation matrix
◆ cs_turbomachinery_set_model()
void cs_turbomachinery_set_model ( cs_turbomachinery_model_t  model)
◆ cs_turbomachinery_set_rotation_retry()
void cs_turbomachinery_set_rotation_retry ( int  n_max_join_retries,
When a joing leads to a different number of boundary faces from the previous position, the rotor positions may be perturbed by a small quantity to try to obtain a better joining.
param[in] n_max_join_retries maximum number of retries before considering the joining has failed param[in] dt_retry_multiplier time step multiplier for new position retry
◆ cs_turbomachinery_set_rotation_velocity()
void cs_turbomachinery_set_rotation_velocity ( int  rotor_num,
double  omega
param[in] rotor_num rotor number (1 to n numbering) param[in] omega rotation velocity
◆ cs_turbomachinery_update_mesh()
void cs_turbomachinery_update_mesh ( double  t_cur_mob,
double *  t_elapsed
[in]t_cur_mobcurrent rotor time
[out]t_elapsedelapsed computation time
