7.1
cs_ext_neighborhood.h
1 #ifndef __CS_EXT_NEIGHBOR_H__
2 #define __CS_EXT_NEIGHBOR_H__
5  * Fortran interfaces of functions needing a synchronization of the extended
6  * neighborhood.
8
9 /*
10  This file is part of Code_Saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2021 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
30
31 /*----------------------------------------------------------------------------
32  * Local headers
33  *----------------------------------------------------------------------------*/
34
35 #include "cs_base.h"
36 #include "cs_mesh.h"
37 #include "cs_mesh_quantities.h"
38
44  * Local Macro definitions
46
48  * Type definition
50
51 /*----------------------------------------------------------------------------
52  * Extended neighborhood type
53  *----------------------------------------------------------------------------*/
54
55 typedef enum {
56
57  CS_EXT_NEIGHBORHOOD_NONE, /* No extended neighborhood */
58  CS_EXT_NEIGHBORHOOD_COMPLETE, /* Full extended neighborhood */
59  CS_EXT_NEIGHBORHOOD_CELL_CENTER_OPPOSITE, /* Cell centers best aligned
60  opposite to adjacent
61  cell centers */
62  CS_EXT_NEIGHBORHOOD_NON_ORTHO_MAX /* Cells adjacent to faces
63  whose non-orthogonality exceeds
64  a given threshold */
65
67
68 /*============================================================================
69  * Global variables
70  *============================================================================*/
71
72 /* Short names for extended neighborhood types */
73
74 extern const char *cs_ext_neighborhood_type_name[];
75
76 /*============================================================================
77  * Public function prototypes
78  *============================================================================*/
79
86 /*----------------------------------------------------------------------------*/
87
90
91 /*----------------------------------------------------------------------------*/
98
99 void
101
109 /*----------------------------------------------------------------------------*/
110
111 cs_real_t
113
114 /*----------------------------------------------------------------------------*/
121 /*----------------------------------------------------------------------------*/
122
123 void
125
126 /*----------------------------------------------------------------------------*/
137 /*----------------------------------------------------------------------------*/
138
139 void
141  cs_mesh_quantities_t *mesh_quantities);
142
143 /*----------------------------------------------------------------------------*/
149 /*----------------------------------------------------------------------------*/
150
151 void
153
154 /*----------------------------------------------------------------------------*/
155
157
158 #endif /* __CS_EXT_NEIGHBOR_H__ */
Definition: cs_ext_neighborhood.h:59
void cs_ext_neighborhood_reduce(cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
Reduce the "cell -> cells" connectivity for the extended neighborhood using a non-orthogonality crite...
Definition: cs_ext_neighborhood.c:1605
const char * cs_ext_neighborhood_type_name[]
void cs_ext_neighborhood_define(cs_mesh_t *mesh)
Create the "cell -> cells" connectivity.
Definition: cs_ext_neighborhood.c:1747
Definition: cs_ext_neighborhood.h:62
Definition: cs_defs.h:322
Definition: cs_mesh.h:84
Definition: cs_ext_neighborhood.h:57
Definition: cs_ext_neighborhood.h:58
void cs_ext_neighborhood_set_non_ortho_max(cs_real_t non_ortho_max)
Set the non_orthogonality threshold (in degrees) associated with the CS_EXT_NEIGHBORHOOD_NON_ORTHO_MA...
Definition: cs_ext_neighborhood.c:1586
void cs_ext_neighborhood_set_type(cs_ext_neighborhood_type_t enh_type)
Set the extended neighborhood type.
Definition: cs_ext_neighborhood.c:1552
cs_ext_neighborhood_type_t cs_ext_neighborhood_get_type(void)
Get the extended neighborhood type.
Definition: cs_ext_neighborhood.c:1538
cs_real_t cs_ext_neighborhood_get_non_ortho_max(void)
Get the non_orthogonality threshold (in degrees) associated with the CS_EXT_NEIGHBORHOOD_NON_ORTHO_MA...
Definition: cs_ext_neighborhood.c:1571
Definition: mesh.f90:26
Type of extended neighborhood associated with the mesh.
Definition: cs_ext_neighborhood.h:55
