7.1
cs_mesh_t Struct Reference
#include <cs_mesh.h>
+ Collaboration diagram for cs_mesh_t:
Data Fields
cs_lnum_t dim
int domain_num
int n_domains
cs_mesh_time_dep_t time_dep
cs_lnum_t n_cells
cs_lnum_t n_i_faces
cs_lnum_t n_b_faces
cs_lnum_t n_vertices
cs_lnum_t i_face_vtx_connect_size
cs_lnum_t b_face_vtx_connect_size
cs_real_tvtx_coord
cs_lnum_2_ti_face_cells
cs_lnum_tb_face_cells
cs_lnum_ti_face_vtx_idx
cs_lnum_ti_face_vtx_lst
cs_lnum_tb_face_vtx_idx
cs_lnum_tb_face_vtx_lst
cs_gnum_t n_g_cells
cs_gnum_t n_g_i_faces
cs_gnum_t n_g_b_faces
cs_gnum_t n_g_vertices
cs_gnum_t n_g_i_c_faces
cs_gnum_tglobal_cell_num
cs_gnum_tglobal_i_face_num
cs_gnum_tglobal_b_face_num
cs_gnum_tglobal_vtx_num
int n_init_perio
int n_transforms
int have_rotation_perio
fvm_periodicity_tperiodicity
cs_halo_type_t halo_type
cs_lnum_t n_cells_with_ghosts
cs_lnum_t n_ghost_cells
cs_interface_set_tvtx_interfaces
cs_halo_thalo
cs_range_set_tvtx_range_set
cs_numbering_tcell_numbering
cs_numbering_tvtx_numbering
cs_numbering_ti_face_numbering
cs_numbering_tb_face_numbering
cs_lnum_t n_b_cells
cs_lnum_tb_cells
cs_lnum_tcell_cells_idx
cs_lnum_tcell_cells_lst
cs_lnum_tgcell_vtx_idx
cs_lnum_tgcell_vtx_lst
int n_groups
int * group_idx
char * group
int n_families
int n_max_family_items
int * family_item
int * cell_family
int * i_face_family
int * b_face_family
fvm_group_class_set_tclass_defs
fvm_selector_tselect_cells
fvm_selector_tselect_i_faces
fvm_selector_tselect_b_faces
char * i_face_r_gen
cs_gnum_t n_g_free_faces
cs_gnum_t n_g_b_faces_all
cs_lnum_t n_b_faces_all
int verbosity
int modified
int save_if_modified
Mesh structure definition
Field Documentation
◆ b_cells
cs_lnum_t* b_cells
boundary cell list
◆ b_face_cells
cs_lnum_t* b_face_cells
boundary faces -> cells connectivity
◆ b_face_family
int* b_face_family
boundary face family
◆ b_face_numbering
cs_numbering_t* b_face_numbering
boundary face numbering info
◆ b_face_vtx_connect_size
boundary faces -> vertices connectivity size
◆ b_face_vtx_idx
cs_lnum_t* b_face_vtx_idx
boundary faces -> vertices index
◆ b_face_vtx_lst
cs_lnum_t* b_face_vtx_lst
◆ cell_cells_idx
cs_lnum_t* cell_cells_idx
"cell -> cells" connectivity index for extended halo. Only defined if extended neighborhood is built.
◆ cell_cells_lst
cs_lnum_t* cell_cells_lst
"cell -> cells" connectivity list for extended halo. Only defined if extended neighborhood is built.
◆ cell_family
int* cell_family
cell family
◆ cell_numbering
cs_numbering_t* cell_numbering
cell numbering info
◆ class_defs
fvm_group_class_set_t* class_defs
definition of group classes for selection and postprocessing (built from element families and their descriptions)
◆ dim
cs_lnum_t dim
space dimension
◆ domain_num
int domain_num
local domain number
◆ family_item
int* family_item
family items
◆ gcell_vtx_idx
cs_lnum_t* gcell_vtx_idx
ghost cells -> vertices index
◆ gcell_vtx_lst
cs_lnum_t* gcell_vtx_lst
ghost cells -> vertices list
◆ global_b_face_num
cs_gnum_t* global_b_face_num
global boundary face numbering
◆ global_cell_num
cs_gnum_t* global_cell_num
global cell numbering
◆ global_i_face_num
cs_gnum_t* global_i_face_num
global interior face numbering
◆ global_vtx_num
cs_gnum_t* global_vtx_num
global vertex numbering
◆ group
char* group
list of group names
◆ group_idx
int* group_idx
starting index in group
◆ halo
cs_halo_t* halo
ghost cells structure
◆ halo_type
halo type
◆ have_rotation_perio
periodicity rotation indicator
◆ i_face_cells
cs_lnum_2_t* i_face_cells
interior faces -> cells connectivity
◆ i_face_family
int* i_face_family
interior face family
◆ i_face_numbering
cs_numbering_t* i_face_numbering
interior face numbering info
◆ i_face_r_gen
char* i_face_r_gen
interior face refinement generation
◆ i_face_vtx_connect_size
interior faces -> vertices connectivity size
◆ i_face_vtx_idx
cs_lnum_t* i_face_vtx_idx
interior faces -> vertices index
◆ i_face_vtx_lst
cs_lnum_t* i_face_vtx_lst
◆ modified
int modified
modification status
◆ n_b_cells
cs_lnum_t n_b_cells
number of boundary cells
◆ n_b_faces
cs_lnum_t n_b_faces
number of boundary faces
◆ n_b_faces_all
number of boundary faces including faces ignored in FV schemes
◆ n_cells
cs_lnum_t n_cells
number of cells
◆ n_cells_with_ghosts
total number of cells on the local rank (n_cells + n_ghost_cells)
◆ n_domains
int n_domains
number of domains
◆ n_families
int n_families
number of families
◆ n_g_b_faces
global number of boundary faces
◆ n_g_b_faces_all
global number of boundary faces inluding those ignored in FV schemes
◆ n_g_cells
cs_gnum_t n_g_cells
global number of cells
◆ n_g_free_faces
global number of boundary faces which are in fact isolated
◆ n_g_i_c_faces
global number of interior faces for counts (with periodic faces counted only once)
◆ n_g_i_faces
◆ n_g_vertices
global number of vertices
◆ n_ghost_cells
number of "ghost" cells
◆ n_groups
int n_groups
number of groups
◆ n_i_faces
cs_lnum_t n_i_faces
◆ n_init_perio
int n_init_perio
number of initial periodicities
◆ n_max_family_items
max. number of items for one family
◆ n_transforms
int n_transforms
number of transformations
◆ n_vertices
number of vertices
◆ periodicity
fvm_periodicity_t* periodicity
parameters of each periodicity
◆ save_if_modified
flag for mesh saving behavior: 0: never save 1: saved when modified (default) 2: always save
◆ select_b_faces
fvm_selector_t* select_b_faces
boundary faces selection object
◆ select_cells
fvm_selector_t* select_cells
cells selection object
◆ select_i_faces
fvm_selector_t* select_i_faces
interior faces selection object
◆ time_dep
time dependency
◆ verbosity
int verbosity
current verbosity level
◆ vtx_coord
cs_real_t* vtx_coord
vertex coordinates
◆ vtx_interfaces
cs_interface_set_t* vtx_interfaces
vertices interface set
◆ vtx_numbering
cs_numbering_t* vtx_numbering
vertex numbering info
◆ vtx_range_set
cs_range_set_t* vtx_range_set
handle local/distant ranges for vertices in parallel
