7.1
cs_gui_mesh.h
1 #ifndef __CS_GUI_MESH_H__
2 #define __CS_GUI_MESH_H__
5  * Management of the GUI parameters file: mesh related options
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_mesh.h"
36
38
42  * Public function prototypes for Fortran API
46  * Public function prototypes
48
49 /*-----------------------------------------------------------------------------
50  * Determine whether warped faces should be cut.
51  *----------------------------------------------------------------------------*/
52
53 void
55
56 /*-----------------------------------------------------------------------------
57  * Define joinings using a GUI-produced XML file.
58  *----------------------------------------------------------------------------*/
59
60 void
62
63 /*-----------------------------------------------------------------------------
64  * Define periodicities using a GUI-produced XML file.
65  *----------------------------------------------------------------------------*/
66
67 void
69
70 /*----------------------------------------------------------------------------
71  * Mesh smoothing.
72  *
73  * parameters:
74  * mesh <-> pointer to mesh structure to smoothe
75  *----------------------------------------------------------------------------*/
76
77 void
79
80 /*----------------------------------------------------------------------------
81  * Define user thin wall through the GUI.
82  *----------------------------------------------------------------------------*/
83
84 void
86
87 /*----------------------------------------------------------------------------
88  * Define user mesh extrude through the GUI.
89  *----------------------------------------------------------------------------*/
90
91 void
93
94 /*----------------------------------------------------------------------------
95  * Define mesh save behavior trough the GUI.
96  *----------------------------------------------------------------------------*/
97
98 void
100
101 /*----------------------------------------------------------------------------
102  * Define if cartesian mesh is to be built through GUI.
103  *----------------------------------------------------------------------------*/
104
105 int
107
108 /*----------------------------------------------------------------------------
109  * Read cartesian mesh parameters defined with GUI.
110  *----------------------------------------------------------------------------*/
111
112 void
114
115 /*----------------------------------------------------------------------------*/
116
118
119 #endif /* __CS_GUI_MESH_H__ */
void cs_gui_mesh_warping(void)
Definition: cs_gui_mesh.c:293
void cs_gui_mesh_smoothe(cs_mesh_t *mesh)
Definition: cs_gui_mesh.c:481
Definition: cs_mesh.h:84
void cs_gui_mesh_extrude(cs_mesh_t *mesh)
Definition: cs_gui_mesh.c:572
void cs_gui_mesh_boundary(cs_mesh_t *mesh)
Definition: cs_gui_mesh.c:532
void cs_gui_mesh_define_joinings(void)
Definition: cs_gui_mesh.c:331
void cs_gui_mesh_define_periodicities(void)
Definition: cs_gui_mesh.c:383
void cs_gui_mesh_cartesian_define(void)
Definition: cs_gui_mesh.c:679
void cs_gui_mesh_save_if_modified(cs_mesh_t *mesh)
Definition: cs_gui_mesh.c:630
Definition: mesh.f90:26
int cs_gui_mesh_build_cartesian(void)
Definition: cs_gui_mesh.c:659
