7.1
cs_restart_default.c File Reference
#include <ctype.h>
#include "cs_array.h"
#include "cs_field_pointer.h"
#include "cs_gradient.h"
#include "cs_halo.h"
#include "cs_halo_perio.h"
#include "cs_les_inflow.h"
#include "cs_map.h"
#include "cs_math.h"
#include "cs_mesh_location.h"
#include "cs_random.h"
#include "cs_time_step.h"
#include "cs_volume_zone.h"
#include "cs_restart_default.h"
+ Include dependency graph for cs_restart_default.c:
void cs_restart_read_field_info (cs_restart_t *r, cs_map_name_to_id_t **old_field_map)
 Read field metadata from checkpoint. More...
void cs_restart_write_field_info (cs_restart_t *r)
 Write field metadata to main checkpoint. More...
void cs_restart_read_variables (cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, int t_id_flag, int read_flag[])
 Read variables from checkpoint. More...
void cs_restart_write_variables (cs_restart_t *r, int t_id_flag, int write_flag[])
 Write variables to checkpoint. More...
void cs_restart_read_linked_fields (cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, const char *key, int read_flag[])
 Read fields depending on others from checkpoint. More...
int cs_restart_write_linked_fields (cs_restart_t *r, const char *key, int write_flag[])
 Write fields depending on others to checkpoint. More...
void cs_restart_read_bc_coeffs (cs_restart_t *r)
 Read boundary condition coefficients for all fields from checkpoint. More...
void cs_restart_write_bc_coeffs (cs_restart_t *r)
 Write boundary condition coefficients for all fields to checkpoint. More...
int cs_restart_read_field_vals (cs_restart_t *r, int f_id, int t_id)
 Read field values from checkpoint. More...
void cs_restart_write_field_vals (cs_restart_t *r, int f_id, int t_id)
 Write field values to checkpoint. More...
void cs_restart_read_time_step_info (cs_restart_t *r)
 Read restart time step info. More...
void cs_restart_write_fields (cs_restart_t *r, cs_restart_file_t r_id)
 Loop over all fields and save them in the restart file which id is passed in argument if it matches their "restart_file" key value. More...
void cs_restart_read_fields (cs_restart_t *r, cs_restart_file_t r_id)
 Loop over all fields and read them in the restart file which id is passed in argument if it matches their "restart_file" key value. More...
Checkpoint/restart handling for default application.
◆ cs_restart_read_bc_coeffs()
void cs_restart_read_bc_coeffs ( cs_restart_t r)
[in,out]rassociated restart file pointer
◆ cs_restart_read_field_info()
void cs_restart_read_field_info ( cs_restart_t r,
cs_map_name_to_id_t **  old_field_map
Old ids associated to each field are determined for future use. Note that when reading legacy files (Code_Saturne version 3.3 and below), the old id will actually be the old scalar id (-1 for others).
[out]old_field_mapname to id map of fields in restart file
◆ cs_restart_read_field_vals()
int cs_restart_read_field_vals ( cs_restart_t r,
int  f_id,
int  t_id
If the values are not found using the default rules based on the field's name, its name itself, or a "restart_rename" keyed string value, an old name may be used for compatibility with older files. For cell-based fields, the old name base is appended automatically with "_ce_phase01", except for scalars, where the name uses a different scheme, based on "scalaire_ce_%04" % s_num;
[in]f_idfield id
[in]t_idtime id (0 for current, 1 for previous, ...)
CS_RESTART_SUCCESS in case of success, CS_RESTART_ERR_... otherwise
◆ cs_restart_read_fields()
void cs_restart_read_fields ( cs_restart_t r,
[in]r_idvalue of the key "restart_file"
◆ cs_restart_read_linked_fields()
void cs_restart_read_linked_fields ( cs_restart_t r,
const cs_map_name_to_id_t old_field_map,
const char *  key,
int  read_flag[]
Old ids associate to each field are determined for future use. Note that when reading legacy files (Code_Saturne version 3.3 and below), the old id will actually be the old scalar id (-1 for others).
[in]old_field_mapname to id map of fields in restart file
[in]keykey for field association
[in,out]read_flagoptional flag to track fields read, or NULL; set to sum of 2^time_id for fields read, -1 for fields failed to read (size: n_fields)
◆ cs_restart_read_time_step_info()
void cs_restart_read_time_step_info ( cs_restart_t r)
◆ cs_restart_read_variables()
void cs_restart_read_variables ( cs_restart_t r,
int  t_id_flag,
int  read_flag[]
[in]t_id_flag-1: all time values; 0: current values; > 0: previous values
[in,out]read_flagoptional flag to track fields read, or NULL; set to sum of 2^time_id for fields read (size: n_fields)
◆ cs_restart_write_bc_coeffs()
void cs_restart_write_bc_coeffs ( cs_restart_t r)
◆ cs_restart_write_field_info()
void cs_restart_write_field_info ( cs_restart_t r)
◆ cs_restart_write_field_vals()
void cs_restart_write_field_vals ( cs_restart_t r,
int  f_id,
int  t_id
[in]f_idfield id
◆ cs_restart_write_fields()
void cs_restart_write_fields ( cs_restart_t r,
◆ cs_restart_write_linked_fields()
int cs_restart_write_linked_fields ( cs_restart_t r,
const char *  key,
int  write_flag[]
[in,out]write_flagoptional flag to track fields written, or NULL; set to sum of 2^time_id for fields written (size: n_fields)
number of fields written
◆ cs_restart_write_variables()
void cs_restart_write_variables ( cs_restart_t r,
int  t_id_flag,
int  write_flag[]
