#include "cs_map.h"
#include "cs_restart.h"
| void | cs_restart_read_field_info (cs_restart_t *r, cs_map_name_to_id_t **old_field_map) |
| | Read field metadata from checkpoint. More...
| void | cs_restart_write_field_info (cs_restart_t *r) |
| | Write field metadata to main checkpoint. More...
| void | cs_restart_read_variables (cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, int t_id_flag, int read_flag[]) |
| | Read variables from checkpoint. More...
| void | cs_restart_write_variables (cs_restart_t *r, int t_id_flag, int write_flag[]) |
| | Write variables to checkpoint. More...
| void | cs_restart_read_linked_fields (cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, const char *key, int read_flag[]) |
| | Read fields depending on others from checkpoint. More...
| int | cs_restart_write_linked_fields (cs_restart_t *r, const char *key, int write_flag[]) |
| | Write fields depending on others to checkpoint. More...
| void | cs_restart_read_bc_coeffs (cs_restart_t *r) |
| | Read boundary condition coefficients for all fields from checkpoint. More...
| void | cs_restart_write_bc_coeffs (cs_restart_t *r) |
| | Write boundary condition coefficients for all fields to checkpoint. More...
| int | cs_restart_read_field_vals (cs_restart_t *r, int f_id, int t_id) |
| | Read field values from checkpoint. More...
| void | cs_restart_write_field_vals (cs_restart_t *r, int f_id, int t_id) |
| | Write field values to checkpoint. More...
| void | cs_restart_read_time_step_info (cs_restart_t *r) |
| | Read restart time step info. More...
| void | cs_restart_write_fields (cs_restart_t *r, cs_restart_file_t r_id) |
| | Loop over all fields and save them in the restart file which id is passed in argument if it matches their "restart_file" key value. More...
| void | cs_restart_read_fields (cs_restart_t *r, cs_restart_file_t r_id) |
| | Loop over all fields and read them in the restart file which id is passed in argument if it matches their "restart_file" key value. More...
◆ cs_restart_file_t
Restart file ids
| Enumerator |
| CS_RESTART_DISABLED | no values to save
| CS_RESTART_MAIN | save values in main restart file
| CS_RESTART_AUXILIARY | save values in auxiliary restart file
| CS_RESTART_RAD_TRANSFER | save values in radiative transfer restart file
| CS_RESTART_LAGR | save values in lagrangian restart file
| CS_RESTART_LAGR_STAT | save values in restart file for lagrangian statistics
| CS_RESTART_1D_WALL_THERMAL | save values in 1D wall thermal restart file
| CS_RESTART_LES_INFLOW | save values in LES inflow restart file
| CS_RESTART_N_RESTART_FILES | Number of types of restart file
◆ cs_restart_read_bc_coeffs()
- Parameters
| [in,out] | r | associated restart file pointer |
◆ cs_restart_read_field_info()
Old ids associated to each field are determined for future use. Note that when reading legacy files (Code_Saturne version 3.3 and below), the old id will actually be the old scalar id (-1 for others).
- Parameters
| [out] | old_field_map | name to id map of fields in restart file |
◆ cs_restart_read_field_vals()
| int cs_restart_read_field_vals |
cs_restart_t * |
r, |
int |
f_id, |
int |
t_id |
If the values are not found using the default rules based on the field's name, its name itself, or a "restart_rename" keyed string value, an old name may be used for compatibility with older files. For cell-based fields, the old name base is appended automatically with "_ce_phase01", except for scalars, where the name uses a different scheme, based on "scalaire_ce_%04" % s_num;
- Parameters
| [in] | f_id | field id |
| [in] | t_id | time id (0 for current, 1 for previous, ...) |
- Returns
- CS_RESTART_SUCCESS in case of success, CS_RESTART_ERR_... otherwise
◆ cs_restart_read_fields()
- Parameters
| [in] | r_id | value of the key "restart_file" |
◆ cs_restart_read_linked_fields()
Old ids associate to each field are determined for future use. Note that when reading legacy files (Code_Saturne version 3.3 and below), the old id will actually be the old scalar id (-1 for others).
- Parameters
| [in] | old_field_map | name to id map of fields in restart file |
| [in] | key | key for field association |
| [in,out] | read_flag | optional flag to track fields read, or NULL; set to sum of 2^time_id for fields read, -1 for fields failed to read (size: n_fields) |
◆ cs_restart_read_time_step_info()
- Parameters
◆ cs_restart_read_variables()
- Parameters
| [in] | t_id_flag | -1: all time values; 0: current values; > 0: previous values |
| [in,out] | read_flag | optional flag to track fields read, or NULL; set to sum of 2^time_id for fields read (size: n_fields) |
◆ cs_restart_write_bc_coeffs()
- Parameters
◆ cs_restart_write_field_info()
- Parameters
◆ cs_restart_write_field_vals()
| void cs_restart_write_field_vals |
cs_restart_t * |
r, |
int |
f_id, |
int |
t_id |
- Parameters
◆ cs_restart_write_fields()
- Parameters
◆ cs_restart_write_linked_fields()
| int cs_restart_write_linked_fields |
cs_restart_t * |
r, |
const char * |
key, |
int |
write_flag[] |
- Parameters
| [in,out] | write_flag | optional flag to track fields written, or NULL; set to sum of 2^time_id for fields written (size: n_fields) |
- Returns
- number of fields written
◆ cs_restart_write_variables()
| void cs_restart_write_variables |
cs_restart_t * |
r, |
int |
t_id_flag, |
int |
write_flag[] |
- Parameters
