7.1
cs_array.h
1 #ifndef __CS_ARRAY_H__
2 #define __CS_ARRAY_H__
5  * Array handling utilities.
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
45  * Type definitions
49  * Global variables
51
52 /*=============================================================================
53  * Public function prototypes
55
56 /*----------------------------------------------------------------------------*/
65 /*----------------------------------------------------------------------------*/
66
67 void
69  cs_lnum_t dim,
70  const cs_real_t src[],
71  cs_real_t dest[restrict]);
72
73 /*----------------------------------------------------------------------------
74  * Assign a constant value to an array.
75  *
76  * parameters:
77  * n_elts <-- number of associated elements
78  * dim <-- associated dimension
79  * v <-- value to assign
80  * a --> array values (size: n_elts*dim]
81  *----------------------------------------------------------------------------*/
82
83 void
85  cs_lnum_t dim,
86  cs_real_t v,
87  cs_real_t a[]);
88
89 /*----------------------------------------------------------------------------*/
90
92
93 #endif /* __CS_ARRAY_H__ */
#define restrict
Definition: cs_defs.h:142
Definition: cs_defs.h:322
double precision, dimension(:,:,:), allocatable v
Definition: atimbr.f90:114
void cs_array_set_value_real(cs_lnum_t n_elts, cs_lnum_t dim, cs_real_t v, cs_real_t a[])
Definition: cs_array.c:130
double precision, save a
Definition: cs_defs.h:316
void cs_array_copy_real(cs_lnum_t n_elts, cs_lnum_t dim, const cs_real_t src[], cs_real_t dest[restrict])
Copy real values from an array to another of the same dimensions.
Definition: cs_array.c:106
