#include "cs_defs.h"#include <stdio.h>#include <stdlib.h>#include <math.h>#include <float.h>#include <assert.h>#include "cs_lagr_agglo.h"#include <limits.h>#include <stddef.h>#include <ctype.h>#include "bft_mem.h"#include "bft_printf.h"#include "cs_base.h"#include "cs_field.h"#include "cs_field_pointer.h"#include "cs_math.h"#include "cs_prototypes.h"#include "cs_parameters.h"#include "cs_time_step.h"#include "cs_physical_constants.h"#include "cs_thermal_model.h"#include "cs_turbulence_model.h"#include "cs_lagr.h"#include "cs_lagr_particle.h"#include "cs_random.h"
Include dependency graph for cs_lagr_agglo.c:Functions | |
| void | cs_lagr_agglo_merge_arrays (cs_lnum_2_t arr1[], cs_lnum_2_t arr2[], cs_lnum_t n1, cs_lnum_t n2, cs_lnum_2_t arr3[]) |
| Merge two sorted arrays in a third sorted array. More... | |
| cs_lnum_t | cs_lagr_agglomeration (cs_lnum_t cell_id, cs_real_t dt, cs_real_t minimum_particle_diam, cs_lnum_t start_particle, cs_lnum_t end_particle) |
| Agglomeration algorithm based on algorithms used in rare gas modelling. More... | |
| void cs_lagr_agglo_merge_arrays | ( | cs_lnum_2_t | arr1[], |
| cs_lnum_2_t | arr2[], | ||
| cs_lnum_t | n1, | ||
| cs_lnum_t | n2, | ||
| cs_lnum_2_t | arr3[] | ||
| [in] | arr1 | first sorted array |
| [in] | arr2 | second sorted array |
| [in] | n1 | size of first sorted array |
| [in] | n2 | size of second sorted array |
| [in,out] | arr3 | preallocated array that will contain the sorted merge of the two previous arrays |
| cs_lnum_t cs_lagr_agglomeration | ( | cs_lnum_t | cell_id, |
| cs_real_t | dt, | ||
| cs_real_t | minimum_particle_diam, | ||
| cs_lnum_t | start_particle, | ||
| cs_lnum_t | end_particle | ||
Parcels represent physical particles with similar properties (size). The number of physical particles in a parcel is represented by the statistical weight.
Working hypotheses:
1) Discrete diameters
| [in] | cell_id | current cell id |
| [in] | dt | time step |
| [in] | minimum_particle_diam | minumum diameter (monomere diameter) |
| [in] | start_particle | index of the first particle |
| [in] | end_particle | index after the last particle |
