#include "base/cs_defs.h"#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft/bft_error.h"#include "bft/bft_mem.h"#include "base/cs_array.h"#include "base/cs_field.h"#include "base/cs_field_default.h"#include "base/cs_field_pointer.h"#include "mesh/cs_mesh.h"#include "mesh/cs_mesh_location.h"#include "base/cs_parameters_check.h"#include "base/cs_physical_constants.h"#include "pprt/cs_physical_model.h"#include "base/cs_physical_properties.h"#include "base/cs_prototypes.h"#include "base/cs_restart_default.h"#include "base/cs_velocity_pressure.h"#include "cfbl/cs_cf_model.h"#include "cfbl/cs_cf_thermo.h"Functions | |
| cs_cf_model_t * | cs_get_glob_cf_model (void) |
| Provide access to compressible model global structure cs_glob_cf_model. | |
| void | cs_cf_add_variable_fields (void) |
| Variable field definitions for the compressible module, according to calculation type selected by the user. | |
| void | cs_cf_add_property_fields (void) |
| Property field definitions for the compressible module, according to calculation type selected by the user. | |
| void | cs_cf_setup (void) |
| Setup options specific to the compressible model. | |
| void | cs_cf_model_log_setup (void) |
| Print the compressible module options to setup.log. | |
| void | cs_cf_initialize (void) |
| Initialize variables of the compressible flow model. | |
| void | cs_cf_physical_properties (void) |
| Compute variable physical properties for the compressible module. | |
Compressible models data.
| void cs_cf_add_property_fields | ( | void | ) |
| void cs_cf_add_variable_fields | ( | void | ) |
| void cs_cf_initialize | ( | void | ) |
| void cs_cf_model_log_setup | ( | void | ) |
| void cs_cf_physical_properties | ( | void | ) |
| void cs_cf_setup | ( | void | ) |
| cs_cf_model_t * cs_get_glob_cf_model | ( | void | ) |
