#include "cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <math.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_array.h"#include "cs_assert.h"#include "cs_field.h"#include "cs_field_pointer.h"#include "cs_gradient.h"#include "cs_log.h"#include "cs_math.h"#include "cs_mesh.h"#include "cs_parall.h"#include "cs_mesh_location.h"#include "cs_turbulence_ke.h"#include "cs_turbulence_model.h"#include "cs_turbulence_rij.h"#include "cs_turbulence_init.h"#include "cs_log_iteration.h"
Include dependency graph for cs_turbulence_init.c:Functions | |
| void | cs_turbulence_init_by_ref_quantities (void) |
| First pass at initialization of turbulence variables. More... | |
| int | cs_turbulence_init_clip_and_verify (void) |
| Clipping of turbulence variables initialization. More... | |
Turbulence variables initialization for various models.
| void cs_turbulence_init_by_ref_quantities | ( | void | ) |
If the reference velocity is negative (incorrect or not initialized), values of k, Rij, epsilon, and omega are set to -10*cs_math_big_r. We will later test if those values were modified by user initialization or reading a restart file.
| int cs_turbulence_init_clip_and_verify | ( | void | ) |
If the user has prescribed "correct" values (in the sense that k, eps, Rii, ... > 0), we clip these values if needed for consistency.
If the prescribed values are manifestly incorrect (negative values), we assume this is an error, print warnings, and return a positive error count.
The same logic is applied to computation restarts.
