1 #ifndef __CS_LOG_ITERATION_H__
    2 #define __CS_LOG_ITERATION_H__
  130                            const char                     *category,
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
Definition: cs_defs.h:325
void cs_log_iteration_set_active(void)
Activate or deactivate default log for current iteration.
Definition: cs_log_iteration.c:1761
void cs_log_iteration_set_interval(int n)
Set interval for "per time step" logging information.
Definition: cs_log_iteration.c:1743
void cs_log_iteration(void)
Log field and other array statistics for the current time step.
Definition: cs_log_iteration.c:1683
void cs_log_iteration_destroy_all(void)
Free arrays possible used by logging of array statistics.
Definition: cs_log_iteration.c:1643
void cs_log_iteration_prepare(void)
Initialize structures used for logging for new iteration.
Definition: cs_log_iteration.c:1995
void cs_log_iteration_set_automatic(int n)
Set adaptive interval for "per time step" logging information.
Definition: cs_log_iteration.c:1721
void cs_log_iteration_clipping_field(int f_id, cs_lnum_t n_clip_min, cs_lnum_t n_clip_max, const cs_real_t min_pre_clip[], const cs_real_t max_pre_clip[], cs_lnum_t n_clip_min_comp[], cs_lnum_t n_clip_max_comp[])
Add or update clipping info for a field.
Definition: cs_log_iteration.c:1973
void cs_log_iteration_clipping(const char *name, int dim, cs_lnum_t n_clip_min, cs_lnum_t n_clip_max, const cs_real_t min_pre_clip[], const cs_real_t max_pre_clip[])
Add or update clipping info for a given array.
Definition: cs_log_iteration.c:1939
void cs_log_iteration_add_array(const char *name, const char *category, const cs_mesh_location_type_t loc_id, bool is_intensive, int dim, const cs_real_t val[])
Add or update array not saved as permanent field to iteration log.
Definition: cs_log_iteration.c:1784
void cs_log_iteration_l2residual(void)
Log L2 time residual for variable fields.
Definition: cs_log_iteration.c:2018
void cs_log_iteration_log_setup(void)
Print default log per iteration options to setup.log.
Definition: cs_log_iteration.c:2095
Definition: cs_mesh_location.h:60
