1 #ifndef __CS_TURBULENCE_RIJ_H__
2 #define __CS_TURBULENCE_RIJ_H__
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
Definition: cs_defs.h:325
void cs_turbulence_rij_clip(int phase_id, cs_lnum_t n_cells)
Clip the turbulent Reynods stress tensor and the turbulent dissipation (coupled components version).
Definition: cs_turbulence_rij.c:3699
void cs_turbulence_rij(int phase_id, cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], cs_real_t smacel[])
Solve the for incompressible flows or slightly compressible flows for one time step.
Definition: cs_turbulence_rij.c:2752
void cs_turbulence_rij_mu_t(int phase_id)
Compute the turbulent viscosity for the Reynolds Stress model.
Definition: cs_turbulence_rij.c:3940
void cs_turbulence_rij_init_by_ref_quantities(cs_real_t uref, cs_real_t almax)
Initialize Rij-epsilon variables based on reference quantities.
Definition: cs_turbulence_rij.c:3636
void cs_turbulence_rij_compute_rusanov(void)
Compute Rusanov equivalent diffusivity of the model.
Definition: cs_turbulence_rij.c:4045
void cs_turbulence_rij_solve_alpha(int f_id, int phase_id, cs_real_t c_durbin_l)
Solve the equation on alpha in the framework of the Rij-EBRSM model.
Definition: cs_turbulence_rij.c:3381
integer, dimension(:), allocatable, target icetsm
number of the ncetsm cells in which a mass injection is imposed. See iicesm and the cs_equation_add_v...
Definition: pointe.f90:176
double precision, dimension(:,:), allocatable, target smacel
value of the mass source term for pressure. For the other variables, eventual imposed injection value...
Definition: pointe.f90:188
integer, dimension(:,:), allocatable, target itypsm
type of mass source term for each variable
Definition: pointe.f90:182
real(c_double), pointer, save almax
is a characteristic macroscopic length of the domain, used for the initialization of the turbulence a...
Definition: cstphy.f90:344
real(c_double), pointer, save uref
the characteristic flow velocity, used for the initialization of the turbulence. Negative value: not ...
Definition: cstphy.f90:353
