Translation of the boundary conditions given by the user in a form that fits to the solver. More...
#include "cs_defs.h"#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <assert.h>#include <math.h>#include <mpi.h>#include "bft_printf.h"#include "cs_1d_wall_thermal.h"#include "cs_ale.h"#include "cs_array.h"#include "cs_assert.h"#include "cs_base.h"#include "cs_boundary.h"#include "cs_boundary_conditions.h"#include "cs_boundary_conditions_check.h"#include "cs_boundary_conditions_set_coeffs_symmetry.h"#include "cs_boundary_conditions_set_coeffs_turb.h"#include "cs_boundary_conditions_type.h"#include "cs_cf_boundary_conditions.h"#include "cs_coupling.h"#include "cs_field.h"#include "cs_field_default.h"#include "cs_field_operator.h"#include "cs_field_pointer.h"#include "cs_gradient_boundary.h"#include "cs_gui_boundary_conditions.h"#include "cs_gui_mobile_mesh.h"#include "cs_gui_util.h"#include "cs_ht_convert.h"#include "cs_internal_coupling.h"#include "cs_les_inflow.h"#include "cs_log.h"#include "cs_mesh.h"#include "cs_mesh_quantities.h"#include "cs_mobile_structures.h"#include "cs_parall.h"#include "cs_parameters.h"#include "cs_physical_constants.h"#include "cs_physical_model.h"#include "cs_prototypes.h"#include "cs_rad_transfer.h"#include "cs_rad_transfer_bcs.h"#include "cs_sat_coupling.h"#include "cs_syr_coupling.h"#include "cs_thermal_model.h"#include "cs_time_step.h"#include "cs_turbulence_model.h"#include "cs_turbomachinery.h"#include "cs_velocity_pressure.h"#include "cs_vof.h"#include "cs_boundary_conditions_set_coeffs.h"Macros | |
| #define | NOZPPM 2000 /* max number of boundary conditions zone */ |
| int * | cs_f_boundary_conditions_get_bc_type (void) |
| void | cs_f_ppprcl (int itypfb[], cs_real_t dt[]) |
| void | cs_f_tagmri (void) |
| void | cs_f_cou1di (void) |
| void | cs_f_mmtycl (const int *itypfb) |
| void | cs_f_pptycl (bool init, int *itypfb, const int *izfppp, cs_real_t dt[]) |
| void | cs_f_cscloc (void) |
| void | cs_f_cscfbr (int *itypfb, cs_real_t *dt) |
| void | cs_f_cscfbr_init (int *itypfb) |
| void | cs_f_user_boundary_conditions_wrapper (const cs_lnum_t itrifb[], int itypfb[], const int izfppp[], cs_real_t dt[]) |
| void | cs_boundary_conditions_set_coeffs (int nvar, int iterns, int isvhb, int itrale, int italim, int itrfin, int ineefl, int itrfup, int isostd[], cs_real_t visvdr[], cs_real_t hbord[], cs_real_t theipb[], int nftcdt) |
| Translation of the boundary conditions given by the user in a form that fits to the solver. More... | |
| void | cs_boundary_conditions_set_coeffs_init (void) |
| Initialization of boundary condition arrays. More... | |
| void | cs_boundary_conditions_set_convective_outlet_scalar (cs_lnum_t f_id, cs_field_bc_coeffs_t *bc_coeffs, cs_real_t pimp, cs_real_t cfl, cs_real_t hint) |
| Set convective oulet boundary condition for a scalar. More... | |
| void | cs_boundary_conditions_set_generalized_sym_vector_aniso (cs_lnum_t f_id, cs_field_bc_coeffs_t *bc_coeffs, const cs_real_t pimpv[3], const cs_real_t qimpv[3], const cs_real_t hint[6], const cs_real_t normal[3]) |
| Set generalized BC for an anisotropic symmetric vector for a given face. More... | |
| void | cs_boundary_conditions_set_generalized_dirichlet_vector_aniso (cs_lnum_t f_id, cs_field_bc_coeffs_t *bc_coeffs, const cs_real_t pimpv[3], const cs_real_t qimpv[3], const cs_real_t hint[6], const cs_real_t normal[3]) |
| Set generalized Dirichlet BC for an anisotropic vector for a given face. More... | |
Boundary condition management.
| #define NOZPPM 2000 /* max number of boundary conditions zone */ |
| void cs_boundary_conditions_set_coeffs | ( | int | nvar, |
| int | iterns, | ||
| int | isvhb, | ||
| int | itrale, | ||
| int | italim, | ||
| int | itrfin, | ||
| int | ineefl, | ||
| int | itrfup, | ||
| int | isostd[], | ||
| cs_real_t | visvdr[], | ||
| cs_real_t | hbord[], | ||
| cs_real_t | theipb[], | ||
| int | nftcdt | ||
The values at a boundary face
stored in the face center
of the variable
and its diffusive flux
are written as:
and
where
is the value of the variable
at the neighboring cell.
Please refer to the boundary conditions section of the theory guide for more informations, as well as the condli section.
| [in] | iterns | iteration number on Navier-Stokes equations |
| [in] | isvhb | indicator to save exchange coeffient at the walls |
| [in] | itrale | ALE iteration number |
| [in] | italim | for ALE |
| [in] | itrfin | for ALE |
| [in] | ineefl | for ALE |
| [in] | itrfup | for ALE |
| [in,out] | isostd | indicator for standard outlet and reference face index |
| [out] | visvdr | dynamic viscosity after V. Driest damping in boundary cells |
| [out] | hbord | exchange coefficient at boundary |
| [out] | theipb | value of thermal scalar at |
| [in] | nftcdt | Global indicator of condensation source terms (ie. sum on the processors of nfbpcd) cells associated to the face with condensation phenomenon |
| void cs_boundary_conditions_set_coeffs_init | ( | void | ) |
| void cs_boundary_conditions_set_convective_outlet_scalar | ( | cs_lnum_t | f_id, |
| cs_field_bc_coeffs_t * | bc_coeffs, | ||
| cs_real_t | pimp, | ||
| cs_real_t | cfl, | ||
| cs_real_t | hint | ||
| [in] | f_id | face id |
| [out] | bc_coeffs | boundary conditions structure |
| [in] | pimp | flux value to impose |
| [in] | cfl | local Courant number used to convect |
| [in] | hint | internal exchange coefficient |
| void cs_boundary_conditions_set_generalized_dirichlet_vector_aniso | ( | cs_lnum_t | f_id, |
| const cs_real_t | pimpv[3], | ||
| const cs_real_t | qimpv[3], | ||
| const cs_real_t | hint[6], | ||
| const cs_real_t | normal[3] | ||
| [in] | pimpv | Dirichlet value to impose on the tangential components |
| [in] | qimpv | flux value to impose on the normal component |
| [in] | normal | unit normal |
| void cs_boundary_conditions_set_generalized_sym_vector_aniso | ( | cs_lnum_t | f_id, |
| [in] | pimpv | Dirichlet value to impose on the normal component |
| [in] | qimpv | flux value to impose on the tangential components |
| int* cs_f_boundary_conditions_get_bc_type | ( | void | ) |
| void cs_f_cou1di | ( | void | ) |
| void cs_f_cscfbr | ( | int * | itypfb, |
| cs_real_t * | dt | ||
| void cs_f_cscfbr_init | ( | int * | itypfb | ) |
| void cs_f_cscloc | ( | void | ) |
| void cs_f_mmtycl | ( | const int * | itypfb | ) |
| void cs_f_ppprcl | ( | int | itypfb[], |
| cs_real_t | dt[] | ||
| void cs_f_pptycl | ( | bool | init, |
| int * | itypfb, | ||
| const int * | izfppp, | ||
| void cs_f_tagmri | ( | void | ) |
