1 #ifndef __CS_BOUNDARY_CONDITIONS_H__
2 #define __CS_BOUNDARY_CONDITIONS_H__
63 #define CS_MAX_BC_PM_ZONE_NUM 2000
66 #define CS_MAX_BC_TYPE 200
197 const char *type_name);
266 ple_locator_t *locator,
302 int source_location_id,
void cs_boundary_conditions_create(void)
Create the legacy boundary conditions face type and face zone arrays.
Definition: cs_boundary_conditions.c:2393
void cs_boundary_conditions_open_set_volume_flow_rate_by_value(const cs_zone_t *z, cs_real_t q)
Assign a constant volume flow rate to an inlet or outlet.
Definition: cs_boundary_conditions.c:3465
void cs_boundary_conditions_open_set_mass_flow_rate_by_value(const cs_zone_t *z, cs_real_t q)
Assign a constant mass flow rate to an inlet or outlet.
Definition: cs_boundary_conditions.c:3282
void cs_boundary_conditions_open_set_velocity_by_normal_value(const cs_zone_t *z, cs_real_t u_norm)
Assign a constant velocity normal to an inlet.
Definition: cs_boundary_conditions.c:3134
cs_boundary_condition_pm_info_t * cs_glob_bc_pm_info
const int * cs_glob_bc_type
cs_real_t cs_boundary_conditions_open_get_mass_flow_rate(const cs_zone_t *z)
Return the volume flow rate to an inlet or outlet.
Definition: cs_boundary_conditions.c:3243
void cs_boundary_conditions_open_set_mass_flow_rate_by_func(const cs_zone_t *z, cs_eval_at_location_t *func, void *input)
Assign a mass flow rate to an inlet or outlet based on provided function.
Definition: cs_boundary_conditions.c:3387
Definition: cs_boundary_conditions.h:63
void cs_boundary_conditions_mapped_set(const cs_field_t *f, ple_locator_t *locator, cs_mesh_location_type_t location_type, int normalize, int interpolate, cs_lnum_t n_faces, const cs_lnum_t *faces, cs_real_t *balance_w)
Set mapped boundary conditions for a given field and mapping locator.
Definition: cs_boundary_conditions.c:2119
void cs_boundary_conditions_legacy_turbulence(int bc_type[])
Define automatic turbulence values for specific physical modules.
Definition: cs_boundary_conditions.c:2752
void cs_boundary_conditions_complete(int bc_type[])
Automatic adjustments for boundary condition codes.
Definition: cs_boundary_conditions.c:2859
cs_time_control_t * cs_boundary_conditions_open_get_time_control(const cs_zone_t *zone)
Acess the time control structure of an open (inlet/outlet) boundary.
Definition: cs_boundary_conditions.c:3074
ple_locator_t * cs_boundary_conditions_map(cs_mesh_location_type_t location_type, cs_lnum_t n_location_elts, cs_lnum_t n_faces, const cs_lnum_t *location_elts, const cs_lnum_t *faces, cs_real_3_t *coord_shift, int coord_stride, double tolerance)
Locate shifted boundary face coordinates on possibly filtered cells or boundary faces for later inter...
Definition: cs_boundary_conditions.c:1967
int cs_boundary_conditions_add_map(int bc_location_id, int source_location_id, cs_real_t coord_shift[3], double tolerance)
Add location of locate shifted boundary face coordinates on cells or boundary faces for automatic int...
Definition: cs_boundary_conditions.c:2314
cs_real_t * cs_boundary_conditions_get_b_head_loss(bool alloc_if_null)
Return pointer to boundary head losses array.
Definition: cs_boundary_conditions.c:3016
void cs_boundary_conditions_create_legacy_zone_data(void)
Create the legacy boundary conditions zone data arrays.
Definition: cs_boundary_conditions.c:2347
void cs_boundary_conditions_open_set_velocity_by_func(const cs_zone_t *z, cs_eval_at_location_t *func, void *input)
Assign a normal velocity to an inlet using a provided function.
Definition: cs_boundary_conditions.c:3189
void cs_boundary_conditions_free(void)
Free the boundary conditions face type and face zone arrays.
Definition: cs_boundary_conditions.c:2447
void cs_boundary_conditions_compute(int bc_type[])
Update per variable boundary condition codes.
Definition: cs_boundary_conditions.c:2542
void cs_boundary_conditions_error(const int *bc_type, const char *type_name)
Handling of boundary condition definition errors and associated output.
Definition: cs_boundary_conditions.c:1913
int cs_boundary_conditions_get_legacy_zone_num(const cs_zone_t *z)
Definition: cs_boundary_conditions.c:2991
void cs_boundary_conditions_inlet_set_turbulence_intensity(const cs_zone_t *zone, cs_real_t ti)
Base the inlet turbulence values on a a circular duct with smooth wall (see ref cs_turbulence_bc_ke_h...
Definition: cs_boundary_conditions.c:3654
void cs_boundary_conditions_assign_model_inlet(const cs_zone_t *zone, void *s_ptr, void *s_del)
Assign pointer to model inlet structure associated with a given open (inlet/outlet) boundary.
Definition: cs_boundary_conditions.c:3041
void cs_boundary_conditions_reset(void)
Prepare (reset) condition coefficients for all variable fields.
Definition: cs_boundary_conditions.c:2490
void cs_boundary_conditions_inlet_set_turbulence_hyd_diam(const cs_zone_t *zone, cs_real_t hd)
Definition: cs_boundary_conditions.c:3624
void cs_boundary_conditions_open_set_volume_flow_rate_by_func(const cs_zone_t *z, cs_eval_at_location_t *func, void *input)
Assign a volume flow rate to an inlet or outlet based on provided function.
Definition: cs_boundary_conditions.c:3557
void cs_boundary_conditions_open_set_velocity_by_value(const cs_zone_t *z, const cs_real_t u[3])
Assign a constant velocity to an open (inlet/outlet) boundary.
Definition: cs_boundary_conditions.c:3095
void * cs_boundary_conditions_get_model_inlet(const cs_zone_t *zone)
Return pointer to model inlet structure associated with a given open (inlet/outlet) boundary.
Definition: cs_boundary_conditions.c:2970
Definition: cs_defs.h:528
Definition: cs_defs.h:332
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:347
Definition: cs_defs.h:529
Definition: cs_defs.h:325
void() cs_eval_at_location_t(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Function pointer for evaluation of local function values.
Definition: cs_function.h:112
Definition: cs_mesh_location.h:60
double precision, dimension(:,:,:), allocatable u
Definition: atimbr.f90:112
real(c_double), dimension(:), pointer, save xintur
turbulent intensity (k=1.5(uref*xintur)**2)
Definition: ppincl.f90:351
integer(c_int), dimension(:), pointer, save iqimp
imposed flow zone indicator in a way which is similar to the process described in the framework of th...
Definition: ppincl.f90:342
real(c_double), dimension(:), pointer, save dh
hydraulic diameter
Definition: ppincl.f90:354
integer(c_int), dimension(:), pointer, save icalke
condition type turbulence indicator
Definition: ppincl.f90:348
integer(c_int), dimension(:), pointer, save ientgf
Definition: coincl.f90:157
real(c_double), dimension(:), pointer, save fment
Definition: coincl.f90:158
real(c_double), dimension(:), pointer, save qimp
integer(c_int), dimension(:), pointer, save ientfu
Definition: coincl.f90:83
integer(c_int), dimension(:), pointer, save ientox
real(c_double), dimension(:), pointer, save tkent
integer(c_int), dimension(:), pointer, save ientgb
Definition: cs_boundary_conditions.h:100
int * itrifb
Definition: cs_boundary_conditions.h:108
int * iautom
Definition: cs_boundary_conditions.h:161
double frmel
Definition: cs_boundary_conditions.h:157
int * izfppp
Definition: cs_boundary_conditions.h:104
double tgf
Definition: cs_boundary_conditions.h:155
Definition: cs_field.h:131
Definition: cs_time_control.h:96
