#include "cs_defs.h"#include <assert.h>#include <errno.h>#include <stdio.h>#include <stdlib.h>#include <stdarg.h>#include <string.h>#include <math.h>#include <float.h>#include "bft_mem.h"#include "cs_array.h"#include "cs_balance.h"#include "cs_blas.h"#include "cs_halo.h"#include "cs_base.h"#include "cs_convection_diffusion.h"#include "cs_equation.h"#include "cs_equation_iterative_solve.h"#include "cs_face_viscosity.h"#include "cs_field.h"#include "cs_field_default.h"#include "cs_field_pointer.h"#include "cs_field_operator.h"#include "cs_gradient.h"#include "cs_lagr.h"#include "cs_log.h"#include "cs_log_iteration.h"#include "cs_mass_source_terms.h"#include "cs_math.h"#include "cs_mesh.h"#include "cs_mesh_quantities.h"#include "cs_physical_constants.h"#include "cs_prototypes.h"#include "cs_rotation.h"#include "cs_thermal_model.h"#include "cs_time_step.h"#include "cs_turbulence_model.h"#include "cs_turbulence_rotation.h"#include "cs_velocity_pressure.h"#include "cs_turbulence_kw.h"
Include dependency graph for cs_turbulence_kw.c:Functions | |
| void | cs_turbulence_kw (cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], const cs_real_t dt[], cs_real_t smacel[]) |
| Solve the k-omega equations. More... | |
| void | cs_turbulence_kw_mu_t (void) |
Calculation of turbulent viscosity for the SST model. More... | |
Solve the
SST for incompressible flows or slightly compressible flows for one time step.
| void cs_turbulence_kw | ( | cs_lnum_t | ncesmp, |
| cs_lnum_t | icetsm[], | ||
| int | itypsm[], | ||
| const cs_real_t | dt[], | ||
| cs_real_t | smacel[] | ||
Solve the
| [in] | itypsm | mass source type for the variables size: [nvar][ncesmp] |
| [in] | smacel | values of the variables associated to the mass source (for the pressure variable, smacel is the mass flux) size: [nvar][ncesmp] |
| void cs_turbulence_kw_mu_t | ( | void | ) |
SST model.
with
and
where
is the distance to the wall.
is calculated at the same time than
for use in cs_turbulence_kw. !
