1 #ifndef __CS_MESH_QUANTITIES_H__ 2 #define __CS_MESH_QUANTITIES_H__ 56 #define CS_BAD_CELLS_WARPED_CORRECTION (1 << 0) 59 #define CS_BAD_CELLS_REGULARISATION (1 << 1) 62 #define CS_CELL_FACE_CENTER_CORRECTION (1 << 2) 65 #define CS_CELL_CENTER_CORRECTION (1 << 3) 68 #define CS_FACE_DISTANCE_CLIP (1 << 4) 71 #define CS_FACE_RECONSTRUCTION_CLIP (1 << 5) 74 #define CS_CELL_VOLUME_RATIO_CORRECTION (1 << 6) 79 #define CS_FACE_CENTER_REFINE (1 << 7) void cs_mesh_quantities_check_vol(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, int allow_error)
Definition: cs_mesh_quantities.c:4248
void cs_mesh_quantities_dump(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities)
Definition: cs_mesh_quantities.c:4589
int has_disable_flag
Definition: cs_mesh_quantities.h:157
cs_real_t cs_real_2_t[2]
Definition: cs_defs.h:334
cs_real_t * b_dist
Definition: cs_mesh_quantities.h:136
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:337
void cs_mesh_quantities_compute(const cs_mesh_t *m, cs_mesh_quantities_t *mq)
Compute mesh quantities.
Definition: cs_mesh_quantities.c:3661
void cs_mesh_quantities_b_thickness_v(const cs_mesh_t *m, const cs_mesh_quantities_t *mq, int n_passes, cs_real_t b_thickness[])
Determine local boundary thickness around each vertex.
Definition: cs_mesh_quantities.c:4412
cs_real_t * corr_grad_lin_det
Definition: cs_mesh_quantities.h:151
int * c_disable_flag
Definition: cs_mesh_quantities.h:160
cs_real_t * cell_f_vol
Definition: cs_mesh_quantities.h:94
cs_real_t * b_face_surf
Definition: cs_mesh_quantities.h:119
cs_real_t * cs_mesh_quantities_cell_volume(const cs_mesh_t *mesh)
Definition: cs_mesh_quantities.c:4207
cs_real_t * djjpf
Definition: cs_mesh_quantities.h:132
cs_real_t * b_f_face_cog
Definition: cs_mesh_quantities.h:114
cs_real_t min_f_vol
Definition: cs_mesh_quantities.h:147
cs_real_t max_f_vol
Definition: cs_mesh_quantities.h:148
Definition: cs_defs.h:512
void cs_mesh_quantities_solid_compute(const cs_mesh_t *m, const cs_real_3_t *cen_points, cs_mesh_quantities_t *mq)
Compute cell and faces quantities needed at the immersed boundaries.
Definition: cs_mesh_quantities.c:2954
cs_real_33_t * corr_grad_lin
Definition: cs_mesh_quantities.h:153
cs_real_6_t * cs_mesh_quantities_cell_extents(const cs_mesh_t *m, cs_real_t tolerance)
Compute the bounding box for cells.
Definition: cs_mesh_quantities.c:4306
int cs_mesh_quantities_face_cog_choice(int algo_choice)
Query or modification of the option for computing face centers.
Definition: cs_mesh_quantities.c:2572
cs_real_t * diipf
Definition: cs_mesh_quantities.h:131
cs_real_t * dofij
Definition: cs_mesh_quantities.h:130
cs_real_t * b_face_cog
Definition: cs_mesh_quantities.h:107
Definition: cs_defs.h:322
void cs_mesh_quantities_face_normal(const cs_mesh_t *mesh, cs_real_t *p_i_face_normal[], cs_real_t *p_b_face_normal[])
Definition: cs_mesh_quantities.c:3956
cs_real_t max_vol
Definition: cs_mesh_quantities.h:144
unsigned * bad_cell_flag
Definition: cs_mesh_quantities.h:162
void cs_mesh_quantities_free_all(cs_mesh_quantities_t *mq)
Reset a mesh quantities structure to its empty initial state.
Definition: cs_mesh_quantities.c:2665
cs_real_t * i_f_face_normal
Definition: cs_mesh_quantities.h:100
void cs_mesh_init_fluid_sections(const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
Definition: cs_mesh_quantities.c:3875
void cs_mesh_quantities_fluid_vol_reductions(const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
Definition: cs_mesh_quantities.c:3835
int cs_mesh_quantities_cell_cen_choice(int algo_choice)
Query or modification of the option for computing cell centers.
Definition: cs_mesh_quantities.c:2550
cs_real_t tot_vol
Definition: cs_mesh_quantities.h:145
cs_real_t * c_w_face_normal
Definition: cs_mesh_quantities.h:104
cs_real_t * c_w_face_surf
Definition: cs_mesh_quantities.h:123
cs_real_t tot_f_vol
Definition: cs_mesh_quantities.h:149
cs_real_t * dijpf
Definition: cs_mesh_quantities.h:128
void cs_mesh_quantities_b_faces(const cs_mesh_t *mesh, cs_real_t *p_b_face_cog[], cs_real_t *p_b_face_normal[])
Definition: cs_mesh_quantities.c:4036
cs_real_t * cell_cen
Definition: cs_mesh_quantities.h:91
cs_real_t * i_dist
Definition: cs_mesh_quantities.h:134
cs_real_t * i_face_normal
Definition: cs_mesh_quantities.h:96
cs_real_2_t * i_f_face_factor
Definition: cs_mesh_quantities.h:125
cs_mesh_quantities_t * cs_mesh_quantities_destroy(cs_mesh_quantities_t *mq)
Destroy a mesh quantities structure.
Definition: cs_mesh_quantities.c:2647
cs_mesh_quantities_t * cs_mesh_quantities_create(void)
Create a mesh quantities structure.
Definition: cs_mesh_quantities.c:2589
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
cs_real_t * i_f_face_cog_0
Definition: cs_mesh_quantities.h:108
cs_real_t * cell_f_cen
unsigned cs_glob_mesh_quantities_flag
void cs_mesh_quantities_log_setup(void)
Log mesh quantities options to setup file.
Definition: cs_mesh_quantities.c:4544
cs_real_t * b_f_face_surf
Definition: cs_mesh_quantities.h:122
cs_real_t * weight
Definition: cs_mesh_quantities.h:141
cs_real_t * b_f_face_factor
Definition: cs_mesh_quantities.h:126
cs_real_t min_vol
Definition: cs_mesh_quantities.h:143
Definition: cs_defs.h:513
void cs_mesh_quantities_cell_faces_cog(const cs_mesh_t *mesh, const cs_real_t i_face_norm[], const cs_real_t i_face_cog[], const cs_real_t b_face_norm[], const cs_real_t b_face_cog[], cs_real_t cell_cen[])
Compute approximate cells centers as the mean of the given face centers weighted by the associated su...
Definition: cs_mesh_quantities.c:4079
cs_real_t * i_f_face_surf
Definition: cs_mesh_quantities.h:121
void cs_mesh_quantities_compute_preprocess(const cs_mesh_t *m, cs_mesh_quantities_t *mq)
Compute mesh quantities needed for preprocessing.
Definition: cs_mesh_quantities.c:2720
void cs_mesh_quantities_fluid_compute(const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
Definition: cs_mesh_quantities.c:3819
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:344
cs_real_t * b_face_normal
Definition: cs_mesh_quantities.h:98
int * b_sym_flag
Definition: cs_mesh_quantities.h:156
cs_real_t * diipb
Definition: cs_mesh_quantities.h:129
cs_real_t * cell_vol
Definition: cs_mesh_quantities.h:93
cs_real_t * c_w_dist_inv
Definition: cs_mesh_quantities.h:138
void cs_mesh_quantities_b_thickness_f(const cs_mesh_t *m, const cs_mesh_quantities_t *mq, int n_passes, cs_real_t b_thickness[])
Determine local boundary thickness around each boundary face.
Definition: cs_mesh_quantities.c:4502
void cs_mesh_quantities_sup_vectors(const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
Definition: cs_mesh_quantities.c:3921
cs_real_t * c_w_face_cog
Definition: cs_mesh_quantities.h:115
cs_real_t * i_face_surf
Definition: cs_mesh_quantities.h:118
int cs_mesh_quantities_compute_count(void)
Definition: cs_mesh_quantities.c:4394
cs_real_t * i_face_cog
Definition: cs_mesh_quantities.h:106
cs_real_t * i_f_face_cog_1
Definition: cs_mesh_quantities.h:111
cs_real_t * b_f_face_normal
Definition: cs_mesh_quantities.h:102
void cs_mesh_quantities_i_faces(const cs_mesh_t *mesh, cs_real_t *p_i_face_cog[], cs_real_t *p_i_face_normal[])
Definition: cs_mesh_quantities.c:4003
