7.3
cs_field_operator.h
1 #ifndef __CS_FIELD_OPERATOR_H__
2 #define __CS_FIELD_OPERATOR_H__
5  * Field based algebraic operators.
31  * Local headers
34 #include "cs_defs.h"
35 #include "cs_field.h"
36 #include "cs_gradient.h"
42 /*=============================================================================
43  * Macro definitions
45
47  * Type definitions
49
50 /*----------------------------------------------------------------------------
51  * Field values interpolation type
52  *----------------------------------------------------------------------------*/
53
54 typedef enum {
55
56  CS_FIELD_INTERPOLATE_MEAN, /* mean element value (P0 interpolation) */
57  CS_FIELD_INTERPOLATE_GRADIENT /* mean + gradient correction (pseudo-P1) */
58
60
61 /*=============================================================================
62  * Public function prototypes
63  *============================================================================*/
64
65 /*----------------------------------------------------------------------------
66  * Compute cell gradient of scalar field or component of vector or
67  * tensor field.
68  *
69  * parameters:
70  * f <-- pointer to field
71  * use_previous_t <-- should we use values from the previous time step ?
72  * inc <-- if 0, solve on increment; 1 otherwise
73  * grad --> gradient
74  *----------------------------------------------------------------------------*/
75
76 void
78  bool use_previous_t,
79  int inc,
80  cs_real_3_t *restrict grad);
81
82 /*----------------------------------------------------------------------------
83  * Compute cell gradient of scalar field or component of vector or
84  * tensor field.
85  *
86  * parameters:
87  * f <-- pointer to field
88  * use_previous_t <-- should we use values from the previous time step ?
89  * inc <-- if 0, solve on increment; 1 otherwise
90  * hyd_p_flag <-- flag for hydrostatic pressure
91  * f_ext <-- exterior force generating the hydrostatic pressure
92  * grad --> gradient
93  *----------------------------------------------------------------------------*/
94
95 void
97  bool use_previous_t,
98  int inc,
99  int hyd_p_flag,
100  cs_real_3_t f_ext[],
101  cs_real_3_t *restrict grad);
102
103 /*----------------------------------------------------------------------------
104  * Compute cell gradient of scalar field or component of vector or
105  * tensor field.
106  *
107  * parameters:
108  * f <-- pointer to field
109  * use_previous_t <-- should we use values from the previous time step ?
110  * inc <-- if 0, solve on increment; 1 otherwise
111  * grad --> gradient
112  *----------------------------------------------------------------------------*/
113
114 void
116  bool use_previous_t,
117  int inc,
118  cs_real_33_t *restrict grad);
119
120 /*----------------------------------------------------------------------------
121  * Compute cell gradient of tensor field.
122  *
123  * parameters:
124  * f <-- pointer to field
125  * use_previous_t <-- should we use values from the previous time step ?
126  * inc <-- if 0, solve on increment; 1 otherwise
127  * grad --> gradient
128  *----------------------------------------------------------------------------*/
129
130 void
132  bool use_previous_t,
133  int inc,
134  cs_real_63_t *restrict grad);
135
136 /*----------------------------------------------------------------------------*/
147
148 void
150  bool use_previous_t,
151  cs_lnum_t n_faces,
152  const cs_lnum_t *face_ids,
153  cs_real_t var_iprime[]);
154
155 /*----------------------------------------------------------------------------
156  * Interpolate field values at a given set of points.
157  *
158  * parameters:
159  * f <-- pointer to field
160  * interpolation_type <-- interpolation type
161  * n_points <-- number of points at which interpolation
162  * is required
163  * point_location <-- location of points in mesh elements
164  * (based on the field location)
165  * point_coords <-- point coordinates
166  * val --> interpolated values
167  *----------------------------------------------------------------------------*/
168
169 void
171  cs_field_interpolate_t interpolation_type,
172  cs_lnum_t n_points,
173  const cs_lnum_t point_location[],
174  const cs_real_3_t point_coords[],
175  cs_real_t *val);
176
177 /*----------------------------------------------------------------------------*/
188 /*----------------------------------------------------------------------------*/
189
190 void
192  cs_halo_type_t halo_type,
193  cs_real_t *local_max,
194  cs_real_t *local_min);
195
196 /*----------------------------------------------------------------------------*/
204 /*----------------------------------------------------------------------------*/
205
206 void
208  const cs_real_t mean);
209
210 /*----------------------------------------------------------------------------*/
219 /*----------------------------------------------------------------------------*/
220
221 void
223  cs_halo_type_t halo_type);
224
225 /*----------------------------------------------------------------------------*/
226
228
229 #endif /* __CS_FIELD_OPERATOR_H__ */
#define restrict
Definition: cs_defs.h:142
Definition: cs_field.h:130
Definition: cs_defs.h:512
void cs_field_gradient_potential(const cs_field_t *f, bool use_previous_t, int inc, int hyd_p_flag, cs_real_3_t f_ext[], cs_real_3_t *restrict grad)
Compute cell gradient of scalar field or component of vector or tensor field.
Definition: cs_field_operator.c:624
Definition: cs_field_operator.h:57
void cs_field_local_extrema_scalar(int f_id, cs_halo_type_t halo_type, cs_real_t *local_max, cs_real_t *local_min)
Find local extrema of a given scalar field at each cell.
Definition: cs_field_operator.c:1120
Definition: cs_field_operator.h:56
Field interpolation modes.
Definition: cs_field_operator.h:54
Definition: cs_defs.h:322
void cs_field_gradient_tensor(const cs_field_t *f, bool use_previous_t, int inc, cs_real_63_t *restrict grad)
Definition: cs_field_operator.c:832
void cs_field_gradient_boundary_iprime_scalar(const cs_field_t *f, bool use_previous_t, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_real_t var_iprime[])
Compute the values of a scalar field at boundary face I&#39; positions.
Definition: cs_field_operator.c:904
void cs_field_set_volume_average(cs_field_t *f, const cs_real_t mean)
Shift field values in order to set its spatial average to a given value.
Definition: cs_field_operator.c:1163
cs_halo_type_t
Definition: cs_halo.h:56
void cs_field_synchronize(cs_field_t *f, cs_halo_type_t halo_type)
Synchronize current parallel and periodic field values.
Definition: cs_field_operator.c:1203
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
void cs_field_gradient_scalar(const cs_field_t *f, bool use_previous_t, int inc, cs_real_3_t *restrict grad)
Definition: cs_field_operator.c:512
Definition: cs_defs.h:316
void cs_field_interpolate(cs_field_t *f, cs_field_interpolate_t interpolation_type, cs_lnum_t n_points, const cs_lnum_t point_location[], const cs_real_3_t point_coords[], cs_real_t *val)
Definition: cs_field_operator.c:1076
Definition: cs_defs.h:513
void cs_field_gradient_vector(const cs_field_t *f, bool use_previous_t, int inc, cs_real_33_t *restrict grad)
Compute cell gradient of vector field.
Definition: cs_field_operator.c:733
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:344
cs_real_t cs_real_63_t[6][3]
Definition: cs_defs.h:352
