#include "cs_gradient.h"
| void | cs_field_gradient_scalar (const cs_field_t *f, bool use_previous_t, int inc, cs_real_3_t *restrict grad) |
| | Compute cell gradient of scalar field or component of vector or tensor field. More...
| void | cs_field_gradient_potential (const cs_field_t *f, bool use_previous_t, int inc, int hyd_p_flag, cs_real_3_t f_ext[], cs_real_3_t *restrict grad) |
| void | cs_field_gradient_vector (const cs_field_t *f, bool use_previous_t, int inc, cs_real_33_t *restrict grad) |
| | Compute cell gradient of vector field. More...
| void | cs_field_gradient_tensor (const cs_field_t *f, bool use_previous_t, int inc, cs_real_63_t *restrict grad) |
| | Compute cell gradient of tensor field. More...
| void | cs_field_gradient_boundary_iprime_scalar (const cs_field_t *f, bool use_previous_t, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_real_t var_iprime[]) |
| | Compute the values of a scalar field at boundary face I' positions. More...
| void | cs_field_interpolate (cs_field_t *f, cs_field_interpolate_t interpolation_type, cs_lnum_t n_points, const cs_lnum_t point_location[], const cs_real_3_t point_coords[], cs_real_t *val) |
| | Interpolate field values at a given set of points. More...
| void | cs_field_local_extrema_scalar (int f_id, cs_halo_type_t halo_type, cs_real_t *local_max, cs_real_t *local_min) |
| | Find local extrema of a given scalar field at each cell. More...
| void | cs_field_set_volume_average (cs_field_t *f, const cs_real_t mean) |
| | Shift field values in order to set its spatial average to a given value. More...
| void | cs_field_synchronize (cs_field_t *f, cs_halo_type_t halo_type) |
| | Synchronize current parallel and periodic field values. More...
◆ cs_field_interpolate_t
Field interpolation modes.
| Enumerator |
| CS_FIELD_INTERPOLATE_MEAN | Mean element value (P0 interpolation)
| CS_FIELD_INTERPOLATE_GRADIENT | Mean element value + gradient correction (pseudo-P1)
◆ cs_field_gradient_boundary_iprime_scalar()
- Parameters
| [in] | use_previous_t | should we use values from the previous time step ? |
| [out] | grad | gradient |
◆ cs_field_gradient_potential()
- Parameters
◆ cs_field_gradient_scalar()
- Parameters
◆ cs_field_gradient_tensor()
- Parameters
◆ cs_field_gradient_vector()
- Parameters
◆ cs_field_interpolate()
- Parameters
| [in] | interpolation_type | interpolation type |
| [in] | n_points | number of points at which interpolation is required |
| [in] | point_location | location of points in mesh elements (based on the field location) |
| [out] | val | interpolated values |
◆ cs_field_local_extrema_scalar()
This assumes the field values have been synchronized.
- Parameters
| [in] | f_id | scalar field id |
| [in,out] | local_max | local maximum value |
| [in,out] | local_min | local minimum value |
◆ cs_field_set_volume_average()
- Parameters
| [in] | va | real value of volume average to be set |
- Parameters
| [in] | va | real value of fluid volume average to be set |
◆ cs_field_synchronize()
This function currently only upates fields based on CS_MESH_LOCATION_CELLS.
- Parameters
| [in,out] | f | pointer to field |
