7.3
cs_field_pointer.h
1 #ifndef __CS_FIELD_POINTER_H__
2 #define __CS_FIELD_POINTER_H__
5  * Field pointers and ids for standard and model fields
31  * Local headers
34 #include "cs_defs.h"
35 #include "cs_field.h"
36
38
41 /*=============================================================================
42  * Macro definitions
45 /* Macro used for scoping of field pointer enums */
46
47 #define CS_ENUMF_(e) CS_FIELD_POINTER_ ## e
48
49 /* Macro used to return a field pointer by its enumerated value */
50
51 #define CS_F_(e) cs_glob_field_pointers[CS_FIELD_POINTER_ ## e].f
52
53 #define CS_FI_(e, i) cs_glob_field_pointers[CS_FIELD_POINTER_ ## e].p[i]
54
55 /*============================================================================
56  * Type definitions
58
61 typedef enum {
62
63  /* Base variables and properties */
64
113  /* Specific physics variables and properties */
114
198  /* Cooling tower fields */
208  /* NCFD fields */
245  /* Added variables (scalars) */
248  /* User-defined arrays */
250
251  /* End of attributes */
252
254
256
262 };
263
264 /*============================================================================
265  * Global variables
266  *============================================================================*/
267
268 /* Pointers */
269
271
272 /*=============================================================================
273  * Public function prototypes
274  *============================================================================*/
275
276 /*----------------------------------------------------------------------------
277  * Ensure field pointer array is initialized.
278  *----------------------------------------------------------------------------*/
279
280 void
282
283 /*----------------------------------------------------------------------------
284  * Free all field pointer data.
285  *----------------------------------------------------------------------------*/
286
287 void
289
290 /*----------------------------------------------------------------------------
291  * Map a simple field to an enumerated pointer.
292  *
293  * The associated field pointer may then be retreived using \ref CS_F_(e).
294  *
295  * parameters:
296  * e <-- field enumerator value
297  * f <-- pointer to field structure
298  *----------------------------------------------------------------------------*/
299
300 void
302  cs_field_t *f);
303
304 /*----------------------------------------------------------------------------
305  * Map a field to an (enumerated pointer, index) couple.
306  *
307  * This sort of mapping may be used for sets of fields whose size
308  * is not known in advance.
309  *
310  * The associated field pointer may then be retreived using \ref CS_F_(e, i).
311  *
312  * parameters:
313  * e <-- field enumerator value
314  * index <-- field enumerator index
315  * f <-- pointer to field structure
316  *----------------------------------------------------------------------------*/
317
318 void
320  int index,
321  cs_field_t *f);
322
323 /*----------------------------------------------------------------------------
324  * Map base fields to enumerated pointers.
325  *----------------------------------------------------------------------------*/
326
327 void
329
330 /*----------------------------------------------------------------------------
331  * Map some boundary fields to enumerated pointers.
332  *----------------------------------------------------------------------------*/
333
334 void
336
337 /*----------------------------------------------------------------------------
338  * Map base fields to enumerated pointers for atmospheric models
339  *
340  * parameters:
341  * n_chem_species <-- number of chemical species
342  * species_f_if <-- field id for each chemical species
343  *----------------------------------------------------------------------------*/
344
345 void
346 cs_field_pointer_map_atmospheric(int n_chem_species,
347  const int species_f_id[]);
348
349 /*----------------------------------------------------------------------------
350  * Map base fields to enumerated pointers for atmospheric models
351  *
352  * parameters:
353  * n_coals <-- number of coals
354  * n_classes <-- number of coal classes
355  *----------------------------------------------------------------------------*/
356
357 void
359  int n_classes);
360
361 /*----------------------------------------------------------------------------*
362  * Map base fields to enumerated pointers for compressible model
363  *----------------------------------------------------------------------------*/
364
365 void
367
368 /*----------------------------------------------------------------------------*
369  * Map base fields to enumerated pointers for gas mix model
370  *----------------------------------------------------------------------------*/
371
372 void
374
375 /*----------------------------------------------------------------------------
376  * Map base fields to enumerated pointers for gas combustion.
377  *----------------------------------------------------------------------------*/
378
379 void
381
382 /*----------------------------------------------------------------------------*/
383 /*
384  * Map base fields to enumerated pointers for groundwater flows
385  *----------------------------------------------------------------------------*/
386
387 void
389
390 /*----------------------------------------------------------------------------*/
391
393
394 #endif /* __CS_FIELD_POINTER_H__ */
Definition: cs_field_pointer.h:241
Definition: cs_field_pointer.h:164
Definition: cs_field_pointer.h:196
Definition: cs_field_pointer.h:224
Definition: cs_field_pointer.h:165
Definition: cs_field_pointer.h:160
Definition: cs_field_pointer.h:175
Definition: cs_field_pointer.h:204
void cs_field_pointer_map_base(void)
Definition: cs_field_pointer.c:277
Definition: cs_field_pointer.h:192
Definition: cs_field_pointer.h:104
Definition: cs_field_pointer.h:150
Definition: cs_field_pointer.h:169
Definition: cs_field_pointer.h:139
Definition: cs_field_pointer.h:166
Definition: cs_field_pointer.h:243
Definition: cs_field.h:130
Definition: cs_field_pointer.h:172
Definition: cs_field_pointer.h:106
Definition: cs_field_pointer.h:143
Definition: cs_field_pointer.h:77
void cs_field_pointer_ensure_init(void)
Definition: cs_field_pointer.c:173
Definition: cs_field_pointer.h:229
void cs_field_pointer_destroy_all(void)
Definition: cs_field_pointer.c:186
Definition: cs_field_pointer.h:227
Definition: cs_field_pointer.h:215
Definition: cs_field_pointer.h:202
Definition: cs_field_pointer.h:151
Definition: cs_field_pointer.h:161
Definition: cs_field_pointer.h:84
Definition: cs_field_pointer.h:237
Definition: cs_defs.h:512
Definition: cs_field_pointer.h:124
Definition: cs_field_pointer.h:216
Definition: cs_field_pointer.h:228
Definition: cs_field_pointer.h:73
Macro used for scoping of field pointer enums.
Definition: cs_field_pointer.h:47
Definition: cs_field_pointer.h:179
Definition: cs_field_pointer.h:133
Definition: cs_field_pointer.h:162
Definition: cs_field_pointer.h:230
Definition: cs_field_pointer.h:231
cs_field_t * f
Definition: cs_field_pointer.h:260
void cs_field_pointer_map_boundary(void)
Definition: cs_field_pointer.c:347
Definition: cs_field_pointer.h:214
Definition: cs_field_pointer.h:126
Definition: cs_field_pointer.h:145
void cs_field_pointer_map_gas_mix(void)
Map base fields to enumerated pointers for gas mix model.
Definition: cs_field_pointer.c:497
Definition: cs_field_pointer.h:67
Definition: cs_field_pointer.h:178
Definition: cs_field_pointer.h:100
void cs_field_pointer_map_compressible(void)
Map base fields to enumerated pointers for compressible model.
Definition: cs_field_pointer.c:460
Definition: cs_field_pointer.h:136
Definition: cs_field_pointer.h:212
Definition: cs_field_pointer.h:217
Definition: cs_field_pointer.h:200
Definition: cs_field_pointer.h:239
Definition: cs_field_pointer.h:223
Definition: cs_field_pointer.h:142
Definition: cs_field_pointer.h:154
Definition: cs_field_pointer.h:153
Definition: cs_field_pointer.h:234
void cs_field_pointer_map_coal_combustion(int n_coals, int n_classes)
Map base fields to enumerated pointers for coal combustion.
Definition: cs_field_pointer.c:393
Definition: cs_field_pointer.h:109
Definition: cs_field_pointer.h:177
Definition: cs_field_pointer.h:159
Definition: cs_field_pointer.h:188
Definition: cs_field_pointer.h:107
Definition: cs_field_pointer.h:253
void cs_field_pointer_map_groundwater(void)
Map base fields to enumerated pointers for groundwater flows.
Definition: cs_field_pointer.c:544
Definition: cs_field_pointer.h:206
Definition: cs_field_pointer.h:95
cs_field_t ** p
Definition: cs_field_pointer.h:261
struct cs_field_pointer_array_t * cs_glob_field_pointers
Definition: cs_field_pointer.c:130
Definition: cs_field_pointer.h:128
Definition: cs_field_pointer.h:115
Definition: cs_field_pointer.h:201
Definition: cs_field_pointer.h:176
Definition: cs_field_pointer.h:218
Definition: cs_field_pointer.h:222
Definition: cs_field_pointer.h:203
Definition: cs_field_pointer.h:123
Definition: cs_field_pointer.h:210
Definition: cs_field_pointer.h:209
Definition: cs_field_pointer.h:167
void cs_field_pointer_map_indexed(cs_field_pointer_id_t e, int index, cs_field_t *f)
Definition: cs_field_pointer.c:232
Definition: cs_field_pointer.h:152
void cs_field_pointer_map(cs_field_pointer_id_t e, cs_field_t *f)
Definition: cs_field_pointer.c:210
Definition: cs_field_pointer.h:91
Definition: cs_field_pointer.h:185
Definition: cs_field_pointer.h:141
Definition: cs_field_pointer.h:93
Definition: cs_field_pointer.h:226
Definition: cs_field_pointer.h:249
Definition: cs_field_pointer.h:89
Definition: cs_field_pointer.h:221
Definition: cs_field_pointer.h:190
Definition: cs_field_pointer.h:238
Definition: cs_field_pointer.h:81
Definition: cs_field_pointer.h:120
Definition: cs_field_pointer.h:225
Definition: cs_field_pointer.h:194
Definition: cs_field_pointer.h:111
Definition: cs_field_pointer.h:101
Definition: cs_field_pointer.h:94
Definition: cs_field_pointer.h:182
Definition: cs_field_pointer.h:213
Definition: cs_field_pointer.h:219
Definition: cs_field_pointer.h:233
Definition: cs_field_pointer.h:181
Definition: cs_field_pointer.h:199
Definition: cs_field_pointer.h:144
Definition: cs_field_pointer.h:183
Definition: cs_field_pointer.h:170
Definition: cs_field_pointer.h:156
Definition: cs_field_pointer.h:235
Definition: cs_field_pointer.h:232
Definition: cs_field_pointer.h:137
Definition: cs_field_pointer.h:80
Definition: cs_field_pointer.h:246
Definition: cs_field_pointer.h:186
Definition: cs_field_pointer.h:259
Definition: cs_defs.h:513
Definition: cs_field_pointer.h:146
Definition: cs_field_pointer.h:75
Definition: cs_field_pointer.h:205
Definition: cs_field_pointer.h:131
Definition: cs_field_pointer.h:163
Definition: cs_field_pointer.h:157
Definition: cs_field_pointer.h:147
Definition: cs_field_pointer.h:121
Definition: cs_field_pointer.h:148
Definition: cs_field_pointer.h:135
Definition: cs_field_pointer.h:149
Definition: cs_field_pointer.h:189
Definition: cs_field_pointer.h:211
Definition: cs_field_pointer.h:191
Definition: cs_field_pointer.h:103
Definition: cs_field_pointer.h:129
Definition: cs_field_pointer.h:61
Definition: cs_field_pointer.h:125
Definition: cs_field_pointer.h:240
Definition: cs_field_pointer.h:88
Definition: cs_field_pointer.h:155
Definition: cs_field_pointer.h:187
Definition: cs_field_pointer.h:110
Definition: cs_field_pointer.h:71
Definition: cs_field_pointer.h:168
Definition: cs_field_pointer.h:220
Definition: cs_field_pointer.h:119
Definition: cs_field_pointer.h:242
Definition: cs_field_pointer.h:173
void cs_field_pointer_map_atmospheric(int n_chem_species, const int species_f_id[])
Map base fields to enumerated pointers for atmospheric models.
Definition: cs_field_pointer.c:366
Definition: cs_field_pointer.h:86
Definition: cs_field_pointer.h:132
Definition: cs_field_pointer.h:140
Definition: cs_field_pointer.h:76
Definition: cs_field_pointer.h:236
Definition: cs_field_pointer.h:184
void cs_field_pointer_map_gas_combustion(void)
Definition: cs_field_pointer.c:510
Definition: cs_field_pointer.h:117
