7.3
cs_turbulence_model.h
1 #ifndef __CS_TURBULENCE_MODEL_H__
2 #define __CS_TURBULENCE_MODEL_H__
5  * Base turbulence model data.
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
45  * Type definitions
48 /*----------------------------------------------------------------------------
49  * turbulence models
50  *----------------------------------------------------------------------------*/
51
52 typedef enum {
53
70
72
73 /*----------------------------------------------------------------------------
74  * turbulence type of model
75  *----------------------------------------------------------------------------*/
76
77 enum {
78
83
84 };
85
87  * turbulence order of model
88  *----------------------------------------------------------------------------*/
89
90 enum {
91
95
96 };
97
98 /*----------------------------------------------------------------------------
99  * hybrid models
100  *----------------------------------------------------------------------------*/
101
102 enum {
103
109
110 };
111
112 /* turbulence model general options descriptor */
113 /*---------------------------------------------*/
114
115 typedef struct {
116
117  int iturb; /* turbulence model
118  CS_TURB_NONE: no turbulence model (laminar flow)
119  CS_TURB_MIXING_LENGTH: mixing length model
120  CS_TURB_K_EPSILON: standard k-epsilon model
121  CS_TURB_K_EPSILON_LIN_PROD: k-epsilon model with
122  Linear Production (LP) correction
123  CS_TURB_K_EPSILON_LS: Launder-Sharma low Re
124  k-epsilon model
125  CS_TURB_K_EPSILON_QUAD: Baglietto et al. low Re
126  k epsilon model
127  CS_TURB_RIJ_EPSILON_LRR: Rij-epsilon (LRR)
128  CS_TURB_RIJ_EPSILON_SSG: Rij-epsilon (SSG)
129  CS_TURB_RIJ_EPSILON_EBRSM: Rij-epsilon (EBRSM)
130  CS_TURB_LES_SMAGO_CONST: LES
131  (constant Smagorinsky model)
132  CS_TURB_LES_SMAGO_DYN: LES ("classical" dynamic
133  Smagorisky model)
134  CS_TURB_LES_WALE: LES (WALE)
135  CS_TURB_V2F_PHI: v2f phi-model
136  CS_TURB_V2F_BL_V2K: v2f BL-v2-k
137  CS_TURB_K_OMEGA: k-omega SST
138  CS_TURB_SPALART_ALLMARAS: Spalart-Allmaras model */
139  int itytur; /* class of turbulence model (integer value
140  iturb/10) */
141  int hybrid_turb; /* Type of Hybrid Turbulence Model
142  - CS_HYBRID_NONE: No model
143  - CS_HYBRID_DES: Detached Eddy Simulation
144  - CS_HYBRID_DDES: Delayed Detached Eddy
145  Simulation
146  - CS_HYBRID_SAM: Scale Adaptive Model
147  - CS_HYBRID_HTLES: Hybrid Temporal Large
148  Eddy Simulation */
149  int type; /* Type of turbulence modelling:
150  - CS_TURB_NONE: No model
151  - CS_TURB_RANS: RANS modelling
152  - CS_TURB_LES: LES modelling
153  - CS_TURB_HYBRID: RANS -- LES modelling */
154  int order; /* Order of the turbulence model:
155  - CS_TURB_ALGEBRAIC: 0th order algebraik model
156  - CS_TURB_FIRST_ORDER: 1st order Eddy Viscosity
157  type models
158  - CS_TURB_SECOND_ORDER: 2nd order Differential
159  Reynolds Stress type models */
161
162 /* Reference values for turbulence structure and associated pointer */
163 /*------------------------------------------------------------------*/
164
165 typedef struct {
166
167  double almax; /* characteristic macroscopic length of the
168  domain */
169  double uref; /* characteristic flow velocity */
170
172
173 /* RANS turbulence model descriptor */
174 /*----------------------------------*/
175
176 typedef struct {
177
178  int irccor; /* activation of rotation/curvature correction for
179  an eddy viscosity turbulence models
180  - 0: false
181  - 1: true */
182  int itycor; /* type of rotation/curvature correction for an
183  eddy viscosity turbulence models
184  - 1: Cazalbou correction (default when irccor=1
185  and itytur=2 or 5)
186  - 2: Spalart-Shur correction (default when
187  irccor=1 and iturb=60 or 70) */
188  int idirsm; /* turbulent diffusion model for second moment
189  closure
190  - 0: scalar diffusivity (Shir model)
191  - 1: tensorial diffusivity (Daly and Harlow
192  model, default model) */
193  int iclkep; /* clipping of k and epsilon
194  - 0: absolute value clipping
195  - 1: coupled clipping based on physical
196  relationships */
197  int igrhok; /* take (2/3 rho grad k) in the momentum
198  equation
199  - 1: true
200  - 0: false (default) */
201  int igrake; /* buoyant term in k-epsilon
202  - 1: true (default if rho is variable)
203  - 0: false */
204  int igrari; /* buoyant term in Rij-epsilon
205  - 1: true (default if rho is variable)
206  - 0: false */
207  int ikecou; /* partially coupled version of
208  k-epsilon (only for iturb=20)
209  - 1: true (default)
210  - 0: false */
211  int reinit_turb; /* Advanced re-init for EBRSM and k-omega models
212  - 1: true (default)
213  - 0: false */
214  int irijco; /* coupled solving of Rij
215  - 1: true
216  - 0: false (default) */
217  int irijnu; /* pseudo eddy viscosity in the matrix of momentum
218  equation to partially implicit div( rho R )
219  - 1: true
220  - 0: false (default) */
221  int irijrb; /* accurate treatment of R at the boundary (see
222  \ref condli)
223  - 1: true
224  - 0: false (default) */
225  int irijec; /* wall echo term of R
226  - 1: true
227  - 0: false (default) */
228  int idifre; /* whole treatment of the diagonal part of the
229  diffusion tensor of R and epsilon
230  - 1: true (default)
231  - 0: simplified treatment */
232  int iclsyr; /* partial implicitation of symmetry BCs of R
233  - 1: true (default)
234  - 0: false */
235  int iclptr; /* partial implicitation of wall BCs of R
236  - 1: true
237  - 0: false (default) */
238  double xlomlg; /* mixing length */
239
241
242 /* LES turbulence model descriptor */
243 /*---------------------------------*/
244
245 typedef struct {
246
247  int idries; /* Van Driest smoothing at the wall (only for
248  itytur=4)
249  - 1: true
250  - 0: false */
251
253
254 /* Hybrid turbulence model descriptor */
255 /*------------------------------------*/
256
257 typedef struct {
258
259  int iicc; /* Internal Consistency Constraint applied
260  (only for hybrid_turb=4)
261  - 1: true
262  - 0: false */
263  int ishield; /* Shielding function applied at the wall
264  (only for hybrid_turb=4)
265  - 1: true
266  - 0: false */
267
268  cs_lnum_t n_iter_mean; /* number of iteration for the exponential mean */
269  cs_lnum_t time_mean; /* time for the exponential mean, automatically
270  computed if n_iter_mean > 0 */
271
273
274 /*============================================================================
275  * Static global variables
276  *============================================================================*/
277
278 /* Pointer to main turbulence model descriptor structure */
279
280 extern const cs_turb_model_t *cs_glob_turb_model;
281
282 /* Pointer to reference values for turbulence descriptor structure */
283
285
286 /* Pointer to RANS turbulence model descriptor structure */
287
289
290 /* Pointer to LES turbulence model descriptor structure */
291
293
294 /* Pointer to hybrid turbulence model descriptor structure */
295
297
298 /* Constant for turbulence models */
299
300 extern double cs_turb_xkappa;
301 extern double cs_turb_vdriest;
302 extern double cs_turb_cstlog;
303 extern double cs_turb_cstlog_rough;
304 extern double cs_turb_cstlog_alpha;
305 extern double cs_turb_apow;
306 extern double cs_turb_bpow;
307 extern double cs_turb_dpow;
308 extern double cs_turb_cmu;
309 extern double cs_turb_cmu025;
310 extern double cs_turb_ce1;
311 extern double cs_turb_ce2;
312 extern double cs_turb_ce4;
313 extern double cs_turb_crij1;
314 extern double cs_turb_crij2;
315 extern double cs_turb_crij3;
316 extern double cs_turb_crijp1;
317 extern double cs_turb_crijp2;
318 extern double cs_turb_cssge2;
319 extern double cs_turb_cssgs1;
320 extern double cs_turb_cssgs2;
321 extern double cs_turb_cssgr1;
322 extern double cs_turb_cssgr2;
323 extern double cs_turb_cssgr3;
324 extern double cs_turb_cssgr4;
325 extern double cs_turb_cssgr5;
326 extern double cs_turb_cebms1;
327 extern double cs_turb_cebms2;
328 extern double cs_turb_cebmr1;
329 extern double cs_turb_cebmr2;
330 extern double cs_turb_cebmr3;
331 extern double cs_turb_cebmr4;
332 extern double cs_turb_cebmr5;
333 extern double cs_turb_csrij;
334 extern double cs_turb_cebme2;
335 extern double cs_turb_cebmmu;
336 extern double cs_turb_xcl;
337 extern double cs_turb_xa1;
338 extern double cs_turb_xct;
339 extern double cs_turb_xceta;
340 extern double cs_turb_cpale1;
341 extern double cs_turb_cpale2;
342 extern double cs_turb_cpale3;
343 extern double cs_turb_cpale4;
344 extern double cs_turb_cpalc1;
345 extern double cs_turb_cpalc2;
346 extern double cs_turb_cpalct;
347 extern double cs_turb_cpalcl;
348 extern double cs_turb_cpalet;
349 extern double cs_turb_ckwsk1;
350 extern double cs_turb_ckwsk2;
351 extern double cs_turb_ckwsw1;
352 extern double cs_turb_ckwsw2;
353 extern double cs_turb_ckwbt1;
354 extern double cs_turb_ckwbt2;
355 extern double cs_turb_ckwgm1;
356 extern double cs_turb_ckwgm2;
357 extern double cs_turb_ckwa1;
358 extern double cs_turb_ckwc1;
359 extern double cs_turb_cddes;
360 extern double cs_turb_csas;
361 extern double cs_turb_csas_eta2;
362 extern double cs_turb_chtles_bt0;
363 extern double cs_turb_cnl1;
364 extern double cs_turb_cnl2;
365 extern double cs_turb_cnl3;
366 extern double cs_turb_cnl4;
367 extern double cs_turb_cnl5;
368 extern double cs_turb_csab1;
369 extern double cs_turb_csab2;
370 extern double cs_turb_csasig;
371 extern double cs_turb_csav1;
372 extern double cs_turb_csaw1;
373 extern double cs_turb_csaw2;
374 extern double cs_turb_csaw3;
375 extern double cs_turb_cssr1;
376 extern double cs_turb_cssr2;
377 extern double cs_turb_cssr3;
378 extern double cs_turb_ccaze2;
379 extern double cs_turb_ccazsc;
380 extern double cs_turb_ccaza;
381 extern double cs_turb_ccazb;
382 extern double cs_turb_ccazc;
383 extern double cs_turb_ccazd;
384 extern double cs_turb_xlesfl;
385 extern double cs_turb_ales;
386 extern double cs_turb_bles;
387 extern double cs_turb_csmago;
388 extern double cs_turb_xlesfd;
389 extern double cs_turb_csmago_max;
390 extern double cs_turb_csmago_min;
391 extern double cs_turb_cdries;
392 extern double cs_turb_cv2fa1;
393 extern double cs_turb_cv2fe2;
394 extern double cs_turb_cv2fc1;
395 extern double cs_turb_cv2fc2;
396 extern double cs_turb_cv2fct;
397 extern double cs_turb_cv2fcl;
398 extern double cs_turb_cv2fet;
399 extern double cs_turb_cwale;
400 extern double cs_turb_xiafm;
401 extern double cs_turb_etaafm;
402 extern double cs_turb_c1trit;
403 extern double cs_turb_c2trit;
404 extern double cs_turb_c3trit;
405 extern double cs_turb_c4trit;
406 extern double cs_turb_cthafm;
407 extern double cs_turb_cthdfm;
408
409 /*=============================================================================
410  * Public function prototypes
411  *============================================================================*/
412
413 /*----------------------------------------------------------------------------
414  * Initialize turbulence model structures
415  *----------------------------------------------------------------------------*/
416
417 void
418 cs_turb_model_init(void);
419
420 /*----------------------------------------------------------------------------
421  * Set type and order of the turbulence model
422  *----------------------------------------------------------------------------*/
423
424 void
426
427 /*----------------------------------------------------------------------------
428  * Set global pointer to turbulence model structure
429  *----------------------------------------------------------------------------*/
430
431 void
433
434 /*----------------------------------------------------------------------------
435  * Provide write access to turbulence model structure
436  *----------------------------------------------------------------------------*/
437
440
441 /*----------------------------------------------------------------------------
442  * Compute turbulence model constants,
443  * some of which may depend on the model choice.
444  *----------------------------------------------------------------------------*/
445
446 void
448
449 /*----------------------------------------------------------------------------
450  * Provide access to cs_glob_turb_ref_values
451  *
452  * needed to initialize structure with GUI
453  *----------------------------------------------------------------------------*/
454
457
458 /*----------------------------------------------------------------------------
459  * Provide access to cs_glob_turb_rans_model
460  *
461  * needed to initialize structure with GUI
462  *----------------------------------------------------------------------------*/
463
466
467 /*----------------------------------------------------------------------------
468  * Provide access to cs_glob_turb_les_model
469  *
470  * needed to initialize structure with GUI
471  *----------------------------------------------------------------------------*/
472
475
476 /*----------------------------------------------------------------------------
477  * Provide access to cs_glob_turb_hybrid_model
478  *
479  * needed to initialize structure with GUI
480  *----------------------------------------------------------------------------*/
481
484
485 /*----------------------------------------------------------------------------*
486  * Print the turbulence model parameters to setup.log.
487  *----------------------------------------------------------------------------*/
488
489 void
491
492 /*----------------------------------------------------------------------------*
493  * Print the turbulent constants to setup.log.
494  *----------------------------------------------------------------------------*/
495
496 void
498
499 /*----------------------------------------------------------------------------*
500  * Clip turbulent fluxes
501  *----------------------------------------------------------------------------*/
502
503 void
504 cs_clip_turbulent_fluxes(int flux_id,
505  int ivartt);
506
507 /*----------------------------------------------------------------------------*/
524 /*----------------------------------------------------------------------------*/
525
526 void
527 cs_turbulence_function_k(int location_id,
528  cs_lnum_t n_elts,
529  const cs_lnum_t *elt_ids,
530  void *input,
531  void *vals);
532
533 /*----------------------------------------------------------------------------*/
550 /*----------------------------------------------------------------------------*/
551
552 void
553 cs_turbulence_function_eps(int location_id,
554  cs_lnum_t n_elts,
555  const cs_lnum_t *elt_ids,
556  void *input,
557  void *vals);
558
559 /*----------------------------------------------------------------------------*/
576 /*----------------------------------------------------------------------------*/
577
578 void
579 cs_turbulence_function_rij(int location_id,
580  cs_lnum_t n_elts,
581  const cs_lnum_t *elt_ids,
582  void *input,
583  void *vals);
584
585 /*----------------------------------------------------------------------------*/
586
588
589 #endif /* __CS_TURBULENCE_MODEL_H__ */
Definition: cs_turbulence_model.c:640
Definition: cs_turbulence_model.c:619
Definition: cs_turbulence_model.c:571
int itytur
Definition: cs_turbulence_model.h:139
double cs_turb_xa1
Definition: cs_turbulence_model.c:631
const cs_turb_rans_model_t * cs_glob_turb_rans_model
Definition: cs_turbulence_model.c:1009
double cs_turb_cnl1
Definition: cs_turbulence_model.c:970
Definition: cs_turbulence_model.c:1014
Definition: cs_turbulence_model.h:54
Definition: cs_turbulence_model.h:105
Definition: cs_turbulence_model.c:682
Definition: cs_turbulence_model.c:700
Definition: cs_turbulence_model.c:999
void cs_turb_constants_log_setup(void)
Definition: cs_turbulence_model.c:2038
Definition: cs_turbulence_model.c:851
Definition: cs_turbulence_model.c:722
Definition: cs_turbulence_model.h:79
double xlomlg
Definition: cs_turbulence_model.h:238
Definition: cs_turbulence_model.c:655
Definition: cs_turbulence_model.h:68
int irijec
Definition: cs_turbulence_model.h:225
Definition: cs_turbulence_model.c:801
Definition: cs_turbulence_model.c:958
cs_lnum_t time_mean
Definition: cs_turbulence_model.h:269
Definition: cs_turbulence_model.c:601
Definition: cs_turbulence_model.c:613
Definition: cs_turbulence_model.c:658
int order
Definition: cs_turbulence_model.h:154
Definition: cs_defs.h:512
cs_turb_les_model_t * cs_get_glob_turb_les_model(void)
Provide access to cs_glob_turb_les_model.
Definition: cs_turbulence_model.c:1672
Definition: cs_turbulence_model.h:104
Definition: cs_turbulence_model.c:729
Turbulence model general options descriptor.
Definition: cs_turbulence_model.h:115
int idries
Definition: cs_turbulence_model.h:247
int irijrb
Definition: cs_turbulence_model.h:221
Definition: cs_turbulence_model.c:530
double cs_turb_xct
Definition: cs_turbulence_model.c:634
double almax
Definition: cs_turbulence_model.h:167
Definition: cs_turbulence_model.c:643
Definition: cs_turbulence_model.h:82
Definition: cs_turbulence_model.h:107
Definition: cs_turbulence_model.c:524
Definition: cs_turbulence_model.h:94
Definition: cs_turbulence_model.c:432
double cs_turb_bpow
Definition: cs_turbulence_model.c:480
double cs_turb_ales
Definition: cs_turbulence_model.c:860
Definition: cs_turbulence_model.c:776
Definition: cs_turbulence_model.c:611
Definition: cs_turbulence_model.c:583
Definition: cs_turbulence_model.h:108
Definition: cs_turbulence_model.h:57
int igrari
Definition: cs_turbulence_model.h:204
int irccor
Definition: cs_turbulence_model.h:178
int itycor
Definition: cs_turbulence_model.h:182
int igrake
Definition: cs_turbulence_model.h:201
Definition: cs_turbulence_model.c:753
double cs_turb_apow
Definition: cs_turbulence_model.c:477
double cs_turb_cnl4
Definition: cs_turbulence_model.c:973
const cs_turb_les_model_t * cs_glob_turb_les_model
Definition: cs_turbulence_model.h:165
Definition: cs_turbulence_model.c:646
Definition: cs_turbulence_model.c:622
void cs_set_glob_turb_model(void)
Set global pointer to turbulence model structure.
Definition: cs_turbulence_model.c:1549
int ishield
Definition: cs_turbulence_model.h:263
Definition: cs_turbulence_model.h:81
Definition: cs_turbulence_model.c:922
Definition: cs_turbulence_model.c:964
Definition: cs_turbulence_model.c:652
Definition: cs_turbulence_model.c:742
Definition: cs_turbulence_model.c:984
int irijnu
Definition: cs_turbulence_model.h:217
Definition: cs_turbulence_model.c:736
Definition: cs_turbulence_model.h:56
int reinit_turb
Definition: cs_turbulence_model.h:211
Definition: cs_turbulence_model.h:268
int iclptr
Definition: cs_turbulence_model.h:235
Definition: cs_turbulence_model.c:688
double cs_turb_ce2
Definition: cs_turbulence_model.c:509
void cs_turb_model_log_setup(void)
Definition: cs_turbulence_model.c:1698
Definition: cs_turbulence_model.c:979
Definition: cs_turbulence_model.c:595
Definition: cs_turbulence_model.c:821
Definition: cs_turbulence_model.c:452
Definition: cs_turbulence_model.c:493
Definition: cs_turbulence_model.c:806
Definition: cs_turbulence_model.h:59
Definition: cs_turbulence_model.c:903
Definition: cs_turbulence_model.h:64
Definition: cs_turbulence_model.c:589
Definition: cs_turbulence_model.c:545
int type
Definition: cs_turbulence_model.h:149
Definition: cs_turbulence_model.c:994
Definition: cs_turbulence_model.c:1004
void cs_set_type_order_turbulence_model(void)
Initialize type and order members of turbulence model structure.
Definition: cs_turbulence_model.c:1491
Definition: cs_turbulence_model.c:441
Definition: cs_turbulence_model.h:67
Definition: cs_turbulence_model.c:811
Definition: cs_turbulence_model.c:831
int iicc
Definition: cs_turbulence_model.h:259
Definition: cs_turbulence_model.c:536
void cs_turb_model_init(void)
Initialize turbulence model structures.
Definition: cs_turbulence_model.c:1477
Definition: cs_turbulence_model.c:791
cs_turb_hybrid_model_t * cs_get_glob_turb_hybrid_model(void)
Provide access to cs_glob_turb_hybrid_model.
Definition: cs_turbulence_model.c:1686
double cs_turb_ce4
Definition: cs_turbulence_model.c:518
Definition: cs_turbulence_model.h:62
RANS turbulence model descriptor.
Definition: cs_turbulence_model.h:176
Definition: cs_turbulence_model.h:65
void cs_turbulence_function_rij(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Return or estimate the value of the Reynolds stresses over specified elements.
Definition: cs_turbulence_model.c:2543
Definition: cs_turbulence_model.h:69
void cs_turb_compute_constants(void)
Compute turbulence model constants, some of which may depend on the model choice. ...
Definition: cs_turbulence_model.c:1564
const cs_turb_ref_values_t * cs_glob_turb_ref_values
Definition: cs_turbulence_model.c:1019
Definition: cs_turbulence_model.h:80
Definition: cs_turbulence_model.c:553
cs_turb_model_type_t
Definition: cs_turbulence_model.h:52
double cs_turb_ce1
Definition: cs_turbulence_model.c:501
Definition: cs_turbulence_model.c:649
Definition: cs_turbulence_model.c:607
Definition: cs_turbulence_model.c:694
Definition: cs_turbulence_model.c:934
Definition: cs_turbulence_model.c:893
Definition: cs_turbulence_model.c:670
Definition: cs_turbulence_model.c:711
Definition: cs_turbulence_model.h:63
Definition: cs_turbulence_model.c:604
Definition: cs_turbulence_model.c:577
Hybrid turbulence model descriptor.
Definition: cs_turbulence_model.h:257
int ikecou
Definition: cs_turbulence_model.h:207
Definition: cs_turbulence_model.h:61
Definition: cs_defs.h:316
Definition: cs_turbulence_model.c:766
cs_turb_ref_values_t * cs_get_glob_turb_ref_values(void)
Provide access to cs_glob_turb_ref_values.
Definition: cs_turbulence_model.c:1644
int idifre
Definition: cs_turbulence_model.h:228
int iturb
Definition: cs_turbulence_model.h:117
void cs_turbulence_function_eps(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Return or estimate the value of the turbulent dissipation over specified elements.
Definition: cs_turbulence_model.c:2465
LES turbulence model descriptor.
Definition: cs_turbulence_model.h:245
double cs_turb_cnl3
Definition: cs_turbulence_model.c:972
Definition: cs_defs.h:513
Definition: cs_turbulence_model.c:625
int hybrid_turb
Definition: cs_turbulence_model.h:141
Definition: cs_turbulence_model.c:609
double cs_turb_cnl5
Definition: cs_turbulence_model.c:974
double cs_turb_xcl
Definition: cs_turbulence_model.c:628
cs_turb_model_t * cs_get_glob_turb_model(void)
Provide write access to turbulence model structure.
Definition: cs_turbulence_model.c:1535
Definition: cs_turbulence_model.c:816
Definition: cs_turbulence_model.c:637
Definition: cs_turbulence_model.h:60
double cs_turb_csas
Definition: cs_turbulence_model.c:748
Definition: cs_turbulence_model.c:989
Definition: cs_turbulence_model.c:610
Definition: cs_turbulence_model.h:93
int iclsyr
Definition: cs_turbulence_model.h:232
const cs_turb_hybrid_model_t * cs_glob_turb_hybrid_model
Definition: cs_turbulence_model.c:796
Definition: cs_turbulence_model.c:946
Definition: cs_turbulence_model.c:940
Definition: cs_turbulence_model.c:913
Definition: cs_turbulence_model.c:771
int iclkep
Definition: cs_turbulence_model.h:193
void cs_turbulence_function_k(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Return or estimate the value of the turbulent kinetic energy over specified elements.
Definition: cs_turbulence_model.c:2388
Definition: cs_turbulence_model.c:836
Definition: cs_turbulence_model.c:676
Definition: cs_turbulence_model.c:883
Definition: cs_turbulence_model.h:66
Definition: cs_turbulence_model.c:559
Definition: cs_turbulence_model.c:841
const cs_turb_model_t * cs_glob_turb_model
double uref
Definition: cs_turbulence_model.h:169
double cs_turb_cnl2
Definition: cs_turbulence_model.c:971
Definition: cs_turbulence_model.c:661
Definition: cs_turbulence_model.c:463
Definition: cs_turbulence_model.c:761
int igrhok
Definition: cs_turbulence_model.h:197
Definition: cs_turbulence_model.c:928
double cs_turb_cmu
Definition: cs_turbulence_model.c:490
Definition: cs_turbulence_model.c:786
Definition: cs_turbulence_model.c:952
void cs_clip_turbulent_fluxes(int flux_id, int ivartt)
Clipping for the turbulence flux vector.
Definition: cs_turbulence_model.c:2265
Definition: cs_turbulence_model.c:826
cs_turb_rans_model_t * cs_get_glob_turb_rans_model(void)
Provide access to cs_glob_turb_rans_model.
Definition: cs_turbulence_model.c:1658
int idirsm
Definition: cs_turbulence_model.h:188
double cs_turb_dpow
Definition: cs_turbulence_model.c:483
int irijco
Definition: cs_turbulence_model.h:214
Definition: cs_turbulence_model.h:58
Definition: cs_turbulence_model.h:106
Definition: cs_turbulence_model.h:92
Definition: cs_turbulence_model.h:55
Definition: cs_turbulence_model.c:565
double cs_turb_bles
Definition: cs_turbulence_model.c:869
Definition: cs_turbulence_model.c:612
Definition: cs_turbulence_model.c:474
Definition: cs_turbulence_model.c:664
Definition: cs_turbulence_model.c:781
