1 #ifndef __CS_PHYSICAL_CONSTANTS_H__ 2 #define __CS_PHYSICAL_CONSTANTS_H__ const double cs_physical_constants_celsius_to_kelvin
Definition: cs_physical_constants.c:388
Fluid properties descriptor.
int ixyzp0
Definition: cs_physical_constants.h:63
double cp0
Definition: cs_physical_constants.h:81
cs_fluid_properties_t * cs_get_glob_fluid_properties(void)
real(c_double), dimension(:), pointer, save xyzp0
coordinates of the reference point for the total pressure.
Definition: cstphy.f90:206
double sleak
Definition: cs_physical_constants.h:98
Definition: cs_defs.h:512
const double cs_physical_constants_stephan
Definition: cs_physical_constants.c:393
double xmasmr
Definition: cs_physical_constants.h:88
double kleak
Definition: cs_physical_constants.h:99
const cs_physical_constants_t * cs_glob_physical_constants
cs_physical_constants_t * cs_get_glob_physical_constants(void)
double t0
Definition: cs_physical_constants.h:80
double pthermax
Definition: cs_physical_constants.h:96
const double cs_physical_constants_avogadro
int icv
Definition: cs_physical_constants.h:66
double r_pg_cnst
Definition: cs_physical_constants.h:85
void cs_fluid_properties_log_setup(void)
Definition: cs_defs.h:322
int irovar
Definition: cs_physical_constants.h:68
const double cs_physical_constants_r
Ideal gas constant ( )
Definition: cs_physical_constants.c:380
int icorio
Definition: cs_physical_constants.h:54
double viscv0
Definition: cs_physical_constants.h:74
double pther
Definition: cs_physical_constants.h:92
const double cs_physical_constants_kb
Definition: cs_physical_constants.c:384
double viscl0
Definition: cs_physical_constants.h:73
double clatev
Definition: cs_physical_constants.h:87
double lambda0
Definition: cs_physical_constants.h:83
void cs_physical_constants_log_setup(void)
int icp
Definition: cs_physical_constants.h:65
double cv0
Definition: cs_physical_constants.h:82
int ipthrm
Definition: cs_physical_constants.h:90
Definition: cs_defs.h:513
double pthera
Definition: cs_physical_constants.h:94
double p0
Definition: cs_physical_constants.h:76
Physical constants descriptor.
Definition: cs_physical_constants.h:51
double rvsra
Definition: cs_physical_constants.h:86
int ivsuth
Definition: cs_physical_constants.h:70
int ivivar
Definition: cs_physical_constants.h:69
double roref
Definition: cs_physical_constants.h:100
double pred0
Definition: cs_physical_constants.h:77
double ro0
Definition: cs_physical_constants.h:72
